Dynamic Prop Balancer
Old March 6th 07, 03:23 PM posted to rec.aviation.owning
Default Dynamic Prop Balancer
On Mar 6, 6:16 am, ---@--- (Robert Scott) wrote:
On 5 Mar 2007 06:41:42 -0800, " wrote:
The only way to get perfect results is for the wind to be calm. A 10
MPH breeze give you false readings, At least it does on the Acers
unit.. YMMV...
Are you saying that a 10 MPH breeze causes a perfectly balanced prop to vibrate
noticeably?
Robert Scott
Ypsilanti, Michigan
Nope... What happens is the wind gusts during the actual balancing
operation will affect the unit from stabilizing and giving you a good
location and amount of weight to add. You can balance in the wind and
get close but why not get it perfect. If there is a row of T hangars
or something to block the wind just get behind them. No reason to not
use a wind break,.. YMMV
Old March 7th 07, 12:39 PM posted to rec.aviation.owning
Robert Scott
unit.. YMMV...
noticeably?
Robert Scott
Ypsilanti, Michigan
location and amount of weight to add...
How long does it normally take, running at full RPM, to get a stable reading on
one of these balancer systems?
Robert Scott
Ypsilanti, Michigan
Old March 7th 07, 01:54 PM posted to rec.aviation.owning
Allen[_1_]
"Robert Scott" ---@--- wrote in message
unit.. YMMV...
vibrate
noticeably?
Robert Scott
Ypsilanti, Michigan
reading on
Robert Scott
Ypsilanti, Michigan
The machine tells you when it is getting a good reading (usually after about
30 seconds or so at power depending on conditions) then you hit the record
button and and 3-4 seconds later you have your reading. I am not sure if we
are talking about the same machine, ours is an Aces.
Allen
Old March 7th 07, 03:03 PM posted to rec.aviation.owning
unit.. YMMV...
vibrate
noticeably?
Robert Scott
Ypsilanti, Michigan
reading on
Robert Scott
Ypsilanti, Michigan
Allen- Hide quoted text -
- Show quoted text -
It's the same machine and the same time to aquire the info...
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 11:18 PM
dynamic prop balancing George A. Graham Home Built 2 April 21st 05 02:20 PM
Dynamic prop balance Ben Jackson Owning 18 June 27th 04 02:45 AM
Need Micro Balancer Jim Products 39 August 26th 03 02:34 AM
Need Micro Balancer Jim Rotorcraft 35 August 26th 03 02:34 AM
