#21
I am the original poster, not MXSMANIC and since I have blocked his posts, some of the thread might be as well.
We were cruising and the flames were well behind the engine, sort of like a small afterburner effect. We flew on without incident. I always wondered what the difference between "running rich" and ENGINE FIRE! might be. On another AJ flight, the passenger beside me left his seat about the same time the FA was giving her speil about the life vest under the seat. I felt under my seat and found only an empty pocket. I rang the FA and told her that I had no life vest. She said "No problem" and pulled the one out from the temporarily vacant seat next to mine and put it under my seat! Google Plex wrote: MXSMANIC wrote: I was flying in an Air Jamaica jet many years ago and while cruising noticed large reddish flames from the exhaust of the Rolls Royce engine. How "normal" would that be? It depends on the exact conditions. Were you cruising? Climbing? Descending? What altitude? How did the engine sound? How long did the flames last, and what did they look like, exactly? Under which of these conditions, exactly, would large reddish flames from the exhaust of a Rolls Royce engine be 'normal'? Normally visible flames don't extend beyond the engine, although if you look directly into the exhaust of a jet engine you may well be able to see glowing internal parts. That's rather difficult to do from inside the plane. High-performance engines may glow externally as well. And of course afterburners can produce long flames that extend well beyond the engine. And so on. Does Air Jamaica use afterburners? -- Joe Leikhim K4SAT "The RFI-EMI-GUY"© "Treason doth never prosper: what's the reason? For if it prosper, none dare call it treason." "Follow The Money" ;-P |
On Mar 14, 3:59 pm, Dave wrote:
Soooo.. How come he (MX) was able to give a rather complete and correct answer to the poster's question? Care to give it a try? Dave On Tue, 13 Mar 2007 22:44:15 -0700, C J Campbell wrote: On 2007-03-13 17:43:50 -0700, megaMAX said: On Wed, 14 Mar 2007 01:18:33 +0100, Mxsmanic wrote: Most commercial flights are flown on autopilot for the vast majority of the trip. Thus you would have seen autopilot corrections, not pilot corrections. Just so you know, Msxmanic does not know any more about flight than you do. He is not a pilot. He is just some nut who hangs out here and pretends to know what he is talking about. MX's knowledge is very sophomoric, and heavily stilted towards biases introduced by inaccuracies in his simulations. As in this case. Minor Harmonic oscillations in flights are a natural byproduct of the dynamic stability of modern aircraft. The Autopilot has no part in it. When the oscillations are on the Longitudinal axis, they are called phugoid oscillations, I'm not sure if there is a similar term for the roll equivolents, but it is the same deal- Essentially what is happening is a battle between the aircraft's substantial momentum, and the aerodynamic forces which keep it pointed into the wind... Large out-of-trim deflections (both roll and pitch) are damped quickly, but there is a threshold at which the amplitude of the oscillations falls below the aerodynamics ability to produce large enough forces to damp the behavior... The period and amplitude of these harmonic functions are directly related to the configuration and chord of the aerodynamic surfaces vs. The aircraft's distribution of mass. In general, thinner aerodynamic surfaces create stronger off-center aerodynamic forces and hence better damping, and lighter aircraft produce weaker momentum forces and again, fewer oscillations. Granted, 'fewer' in this case is a matter of perception... the oscillations you were seeing were really very minor (less than a degree), its just that the solid horizon combined with the long arm of the wing made them more obvious than the same fraction of a degree roll oscillation would be in a smaller aircraft. No MX... it has nothing to do with the autopilot... FWIW, I remember reading somewhere that the 747 prototype actually had a problem on its first few flights - the engineers had designed the aerodynamic surfaces to damp the phugoid (longitudinal) harmonics based on a theoretical perfectly rigid aircraft, however, in reality, it turned out that the fuselage had a natural bending resonance frequency which matched the aerodynamic harmonic frequency, and they amplified eachother to produce an in flight longitudinal harmonic that was actually quite substantial... the result, IIRC, was a very sick planeload of journalists on the aircraft's first publicity flight. For more information, read up on both Phugoid oscillations and Roll stability via using wing dihedral. |
On Mar 15, 12:14 pm, Mxsmanic wrote:
writes: Yes, they can. No, they cannot, except under ideal conditions, and sometimes not even then. They do not have too. They only need to get the aircraft close enough for wing dihedral to do the rest. Its called a dynamically stable aircraft design, and its been a cornerstone of aviation almost since its inception. But what do I know, I only fly tiny planes. My thoughts exactly. That's funny, by your theory, stable flight was impossible until the mid-80s... |
![]() Correction: Actually, Mxsmanic knows a great deal, _despite_ not being a pilot. I cannot disagree with this. The problem is that you do not know what you do not know, and lack of practical experience has left your knowledge with a great number of holes that you refuse to acknowledge. It is a typically sophomoric attitude (hence my initial impression that you were an adolescent). This is particularly true with respect to large aircraft, since most of the pilots here are familiar only with the tiny aircraft they fly, whereas he has studied both small and large aircraft. That is a GROSS generalization. Yes, some pilot's only care about the planes that they fly... I would say that is actually the exception rather than the rule, however. The rest of us have just as much a passion for aviation as yourself AND we fly. When we're not spending our spare time in a cockpit, we spend it learning about aircraft and aircraft systems... Aircraft design (A particular favorite topic of mine) and other aviation related topics... and hell, even flying sims... More to the point: If you see an error in anything I've said, feel free to point it out. Your explanation of the cause of the roll oscillations was utterly wrong, and your desire to attribute ultimate aircraft stability to autopilot design is also largly incorrect (Except in a few isolated (almost always military) cases of relaxed stability aircraft. He doesn't have to pretend. This might be a low blow but... Isn't that the fundamental definition of Simulation? ![]() Nor is he so insecure that he must engage in personal attacks if someone else seems to know more. I actually agree that the personal attacks against you have grown more disruptive than your actual sophomoric nature. One of the aggravations I have had, however - is you do not seem to respond to anything BUT the personal attacks - I have seen MANY knowledgeable, polite corrections and responses to your assertions go un-heeded while you chose only to argue with those who attacked you. It gives the impression that you seek the negative attention over actual helpfulness. I still wish you'd take some time to get your information from sources OTHER than public forums however... So many of your questions could be answered so much easier and faster via a quick Google search. And It would also be nice if you added an occasional "my understanding is" disclaimer to some of your more authoritative-toned posts... |
On 2007-03-14 15:59:45 -0700, Dave said:
Soooo.. How come he (MX) was able to give a rather complete and correct answer to the poster's question? Care to give it a try? Dave The fact that he is right once in awhile is no indication that he knows what he is talking about. He is not a pilot. He is a flight-sim guy. Even Mxs should be able to learn something. But what he says should in no way be considered reliable. -- Waddling Eagle World Famous Flight Instructor |
Understood, and we agree...
But he is right some of the time, along with many others here.. There are also a couple of other guys I know of who could answer this question, probably better than anyone here.... One is a designer of autopilots, the other is an aeronautical engineer.... .....neither is a pilot, nor has any interest in becoming one... So, I guess many here would chastise them if they posted their opinions here, because they are not "pilots"... But, I guess that all works out, because Bombardier PAYS THEM BOTH VERY WELL for their thoughts/opinions/ideas. But, alas, like MX, they are not pilots.. ![]() D On Thu, 15 Mar 2007 18:43:25 -0700, C J Campbell wrote: On 2007-03-14 15:59:45 -0700, Dave said: Soooo.. How come he (MX) was able to give a rather complete and correct answer to the poster's question? Care to give it a try? Dave The fact that he is right once in awhile is no indication that he knows what he is talking about. He is not a pilot. He is a flight-sim guy. Even Mxs should be able to learn something. But what he says should in no way be considered reliable. |
#28
EridanMan writes:
The problem is that you do not know what you do not know ... A greater problem is that a lot of pilots here don't know, either, although many think that they know it all once they have a license (and that, conversely, anyone without one knows nothing). The truth is considerably less extreme. ... and lack of practical experience has left your knowledge with a great number of holes that you refuse to acknowledge. The "holes" pointed out to me consist almost exclusively of physical sensations of flying. The mistake made by pilots here is to think that these sensations are 99% of flying, when in fact their importance varies with the type of flying under consideration. This is a consequence of many pilots here being tin-can, seat-of-the-pants pilots, with little or no experience or knowledge of other types of aircraft. They see everything from the cockpit of a Cessna, and they think that's all there is. That is a GROSS generalization. It's also a very accurate one. It's painfully obvious that many of the pilots here are low-time, small-aircraft pilots. Everything they say reflects this viewpoint. Yes, some pilot's only care about the planes that they fly... I would say that is actually the exception rather than the rule, however. Most of them only _know_ about the plane(s) they fly. They don't know about other planes, so they don't care about them. They think that knowing the fine details of control pressures in a Cessna is vitally important, but when I point out that many large aircraft don't work this way at all, they dismiss that as unimportant. But it's not unimportant to an Airbus pilot. The rest of us have just as much a passion for aviation as yourself AND we fly. Some people have resources, and others don't. When we're not spending our spare time in a cockpit, we spend it learning about aircraft and aircraft systems... Aircraft design (A particular favorite topic of mine) and other aviation related topics... and hell, even flying sims... Some do, some don't. Some stop half-way and then pretend about the rest. Your explanation of the cause of the roll oscillations was utterly wrong ... Provide the correct explanation, then. ... and your desire to attribute ultimate aircraft stability to autopilot design is also largly incorrect (Except in a few isolated (almost always military) cases of relaxed stability aircraft. See above. This might be a low blow but... Isn't that the fundamental definition of Simulation? ![]() Not really. Pretending depends on imagination alone. Simulation removes part of the need for imagination, so simulation is much less pretending than non-simulation. One of the aggravations I have had, however - is you do not seem to respond to anything BUT the personal attacks ... Many posts contain nothing else, and in fact I let most personal attacks drop, as they are unrelated to the discussion at hand. It's hard to get people to discuss the topic, rather than me. This post is a case in point. You say I was wrong, but you provide no further information and no corrections, which I find odd. You spend the rest of the post talking about me, rather than the topic at hand. I have seen MANY knowledgeable, polite corrections and responses to your assertions go un-heeded while you chose only to argue with those who attacked you. The fact that I do not reply to a post doesn't mean that I haven't read it or understood it. It usually just means that I have no quarrel with it and no further questions about it. Those who engage in personal attacks also tend to be those who give wrong answers or incomplete answers or no answers, and so I press them for answers. People who are aggressive in this way are often being defensive because they know that their opinions were adopted wholesale from someone else and are fundamentally baseless. I press them for answers in order to compel them to look at their opinions and decide whether they are really worth clinging to when they cannot be substantiated. I consider this a public service. It gives the impression that you seek the negative attention over actual helpfulness. I'm not worried about the impression I create. I've found that people have an enormous tendency to believe what they want to believe, and it's an exercise in futility to try to make them think more critically. But I try to err on the side of optimism and so I still do the above. I still wish you'd take some time to get your information from sources OTHER than public forums however ... Most of my information comes from other sources, since it is hard to find people here who actually know what they are talking about. USENET is just one of many sources. So many of your questions could be answered so much easier and faster via a quick Google search. I do Google searches regularly, although I don't have as much faith in them as you might. And It would also be nice if you added an occasional "my understanding is" disclaimer to some of your more authoritative-toned posts... Why? To spare the overinflated egos of a minority? Why would I say something that is _not_ my understanding? How could anything I say (or anything anyone else says) be anything _other_ than an understanding? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#29
EridanMan writes:
They do not have too. They only need to get the aircraft close enough for wing dihedral to do the rest. Its called a dynamically stable aircraft design, and its been a cornerstone of aviation almost since its inception. Until Airbus came along. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#30
EridanMan writes:
Minor Harmonic oscillations in flights are a natural byproduct of the dynamic stability of modern aircraft. The Autopilot has no part in it. Do these oscillations cause control surfaces to move by themselves? Are they asymmetrical? When the oscillations are on the Longitudinal axis, they are called phugoid oscillations, I'm not sure if there is a similar term for the roll equivolents ... Dutch roll and spiral come to mind, although they are not limited exclusively to the roll axis. No MX... it has nothing to do with the autopilot... If the control surfaces are moving, either the pilot or the autopilot is acting upon them. If the corrections are asymmetrical, this would tend to exclude the hypothesis of harmonic oscillations. Also, roll harmonics often extend over periods of minutes in large aircraft and would not be obvious just by watching the wing outside the window. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Commercial 250nm VFR flight - all 3 landings on the same day? | Jim Macklin | Instrument Flight Rules | 39 | December 20th 06 12:11 PM |
Mooney Engine Problems in Flight | Paul Smedshammer | Piloting | 45 | December 18th 04 09:40 AM |
Looping during a commercial flight | LordAvalon | Aerobatics | 10 | October 23rd 04 04:05 PM |
Nixon on Commercial Flight | Flyin'[email protected] | Piloting | 1 | June 16th 04 05:51 PM |
Flight Unlimited 2 on Windows Xp .- any known problems? | tw | Simulators | 2 | April 25th 04 05:05 PM |
