Welding a 5052-0 Fuel Tank
Old April 3rd 07, 01:52 AM posted to rec.aviation.homebuilt
jls
Default Welding a 5052-0 Fuel Tank
Anybody got any pointers on this. A friend had an aluminum tank
welded and it leaked. He thinks it was because a different aluminum
was used for the welding rod. I dunno. I'm a novice on welding.
This tank has a big dent on top and we may need to drill a hole or two
from the bottom of the pancake-shaped tank to work the dent out. Will
this 5052-0 aluminum get hard and brittle? It's .040 thick. The dent
needs to be worked out because we need an airfoil shape on the top of
the tank, and we lost the desired shape with the big dent which made
the tank's top bulge around the inlet. It's an 18-gallon wing tank.
Thank you for your kind support.
Yes, thanks and I'm kinda enjoying (but a tiny bit ashamed because
schadenfreude is a sin) watching the group of ravenous piranhas
picking the bones of Jim Campbell, as if he deserves anything better.
Poor guy. He just can't help himself. He's innately evil. Besides
being an irrepressible narcissist. And I think he fibs sometimes too.
And tells cock-and-bull stories. I got a feeling Ron Wanntaja has
Campbell assessed correctly. His credibility is shot. So I tend to
believe Wanttaja, who more often than not demonstrates sterling
character. Or at least better than average character.
Ok, help us out a little now with this welding thing.
Old April 3rd 07, 05:33 AM posted to rec.aviation.homebuilt
Ernest Christley
I've found the 5052 to be very forgiving, as far as work hardening, but
I haven't pushed it very hard.
Look up Ken White's internet site.
http://www.tinmantech.com/index.php
Loads of information there. His glasses for gas welding makes all the
difference. Use lots of flux, and a bigger tip than what you think is
necessary.
Old April 3rd 07, 06:12 AM posted to rec.aviation.homebuilt
Orval Fairbairn
Before welding the tank MUST be purged! I have had success with dry ice,
from local dairies, who use it to pack ice cream for shipment.
My local welding guru uses his argon as a purge before welding. It
displaces the air and inhibits combustion, as doe the CO2 from the dry
ice.
Tanks are finicky regarding vibration. They don't like to be tied (or
strapped) down too tightly and like to rest on something soft, like felt.
If they encounter stress concentrations, they can leak in unexpected
places.
Old April 3rd 07, 04:51 PM posted to rec.aviation.homebuilt
Dan[_2_]
ice.
places.
Unexpected? No one expects the Spanish Inquisition!
OK, I could have resisted, but I didn't feel like it
Dan, U.S. Air Force, retired
Old April 3rd 07, 08:14 PM posted to rec.aviation.homebuilt
Montblack
("Dan" wrote)
places.
Let's face it - you can't Torquemada anything!
places.
Comicus: I'm fighting with cardboard!
Montblack
Old April 4th 07, 11:26 PM posted to rec.aviation.homebuilt
ChuckSlusarczyk
In article , jls says...
I'm assuming your going to TIG the tank. My technique is to
#1 be sure tank has no fuel residue and flush with water if possible .
#2 Set up an inert gas purge I use the argon from my tig bottle.
#3 clean with a stainless steel wire brush the area to be welded
#4 Slightly preheat the tank with an acytelene torch in the area of the weld.Use
a soft flame.
#5 Use proper rod and weld and allow to cool by itself do not quench with water.
This works for me. Ain't blowed up yet :-)Hope this helps
Good idea to believe Ron over zoom you won't go wrong :-) I agree with your
assessment of zoom as well he will lie when the truth would work just as well.
Credibility it was always about credibility.
Chuck S RAH-14/1 ret
Old April 5th 07, 01:26 AM posted to rec.aviation.homebuilt
Dan[_2_]
Montblack wrote:
("Dan" wrote)
places.
places.
Montblack
And the rest of you will run with Mucus.
OK, I'm going to ask another fuel tank question. Lou Home Built 9 April 22nd 07 01:46 AM
Sealant for polyethylene fuel tank? TerryJ Home Built 0 March 3rd 07 04:10 AM
Fuel tank balance Mxsmanic Piloting 101 October 3rd 06 08:56 AM
fuel tank plumbing pwm Home Built 18 January 27th 05 05:54 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 03:57 AM
