#21
It is something that no one wants to talk about. We have spent trillions for defense, yet when one was needed there was not a single armed aircraft even parked on the ground anywhere in the Eastern Half of the USA... Well, shucks, that's called "living in a time of peace". I suppose it is a good thing the Russians never attacked... Prior to 1990, I'm sure there were plenty of armed interceptors around. Don't you remember how delighted we all were, that in the grand new era there would be no need to spend trillions on defending from attack by an imagined foe, so we would be safe from broken arrows and suchlike hazards attendant upon our Cold War footing? What a dizzy decade that was, when the only thing we had to puzzle us was the peculiarities of the president's member. all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
"matt weber" wrote in message ... On Sat, 30 Aug 2003 12:18:13 +0100, "Keith Willshaw" wrote: They show up on most ATC radars only because they have a transponder. Nonsense they show up on primary radar very well Note the difficulties US ATC had in locating 757's and 767's on 9/11 after the transponders were turned off, and 757 or 767 has a far far larger radar cross section than a single engine cessna. Again this is nonsense, the radar tracks of those aircraft have been produced in evidence primary radar is more than adequate ATC radars generally only see either very large targets, or very cooperative targets (transponders). Wrong, ATC radars track light aircraft every day. Hell the radars of WW2 had no problem tracking aircraft of the same size, its for damm sure that modern radars are better Keith |
On Sun, 31 Aug 2003 11:11:10 +0100, "Keith Willshaw"
wrote: "matt weber" wrote in message .. . On Sat, 30 Aug 2003 12:18:13 +0100, "Keith Willshaw" wrote: They show up on most ATC radars only because they have a transponder. Nonsense they show up on primary radar very well Note the difficulties US ATC had in locating 757's and 767's on 9/11 after the transponders were turned off, and 757 or 767 has a far far larger radar cross section than a single engine cessna. Again this is nonsense, the radar tracks of those aircraft have been produced in evidence primary radar is more than adequate It is more then adequate, as long as they never get more than about 35 miles away from the RADAR. After that, the combination of the inverse square law, and the very limited RCS of many light aircraft makes them just about impossible to see. that is one of the reasons that ATC in the USA also receives data from far more capable military RADAR systems that are not limited by Civilian energy exposure limits. Most of the track data for both JFK Jr's crash, and the EgyptAir crash came not from civilian ATC radars, but Military Radars which share data with ATC. I suggest you do the arithmetic sometime on what sort of power you need to radiate to be able to get a reliably detectable return on a 1 m^2 RCS at 50km. 1m^2 is fairly typical of Cessa single. Some of the older aircraft with fabric instead of metal are considerably smaller RCS. After you have done that calculation, decide how near you would like to live to that particular radar. ATC radars generally only see either very large targets, or very cooperative targets (transponders). Wrong, ATC radars track light aircraft every day. Only at short range. Hell the radars of WW2 had no problem tracking aircraft of the same size, its for damm sure that modern radars are better My father assures me that was not the case, and he WAS the Radar officer on a US Carrier in WW II. I'll take his word on that subject over yours anytime A TBD or a Betty could be seen at about 100 miles, but they are a whole lot bigger than a Cessna 172 The Radar in an F16 in Air to Air mode has a 50% probability of detecting a 1 m^2 RCS at 40km.. |
They show up on most ATC radars only because they have a transponder. Nonsense they show up on primary radar very well As posted, I seemed to be invisible to the PSM tower when I asked permission to descend through the Delta airspace earlier this summer. Flying a rag & tube Cub with no transponder. Can't speak for spam cans--all the local ones have transponders anyhow. all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
"matt weber" wrote in message ... On Sun, 31 Aug 2003 11:11:10 +0100, "Keith Willshaw" wrote: "matt weber" wrote in message .. . On Sat, 30 Aug 2003 12:18:13 +0100, "Keith Willshaw" wrote: They show up on most ATC radars only because they have a transponder. Nonsense they show up on primary radar very well Note the difficulties US ATC had in locating 757's and 767's on 9/11 after the transponders were turned off, and 757 or 767 has a far far larger radar cross section than a single engine cessna. Again this is nonsense, the radar tracks of those aircraft have been produced in evidence primary radar is more than adequate It is more then adequate, as long as they never get more than about 35 miles away from the RADAR. Actual range depends on height, RCS , transmitted power and the sensitivity of the radar, However its a matter of historical fact that during WW2 the primitive Chain Home system could detect aircraft out to 200 miles http://www.radarpages.co.uk/mob/chl/chl.htm However your original claim was that they couldnt be seen at all unless they had a transponder ! After that, the combination of the inverse square law, and the very limited RCS of many light aircraft makes them just about impossible to see. that is one of the reasons that ATC in the USA also receives data from far more capable military RADAR systems that are not limited by Civilian energy exposure limits. Come now make up your mind , are they impossible to see or is it just that the range is limited ? Most of the track data for both JFK Jr's crash, and the EgyptAir crash came not from civilian ATC radars, but Military Radars which share data with ATC. I suggest you do the arithmetic sometime on what sort of power you need to radiate to be able to get a reliably detectable return on a 1 m^2 RCS at 50km. 1m^2 is fairly typical of Cessa single. Some of the older aircraft with fabric instead of metal are considerably smaller RCS. A Cessna in the head on aspect may indeed have an RCS as small as 1 m2 , this is around the same as an F-16 ! After you have done that calculation, decide how near you would like to live to that particular radar. ATC radars generally only see either very large targets, or very cooperative targets (transponders). Wrong, ATC radars track light aircraft every day. Only at short range. Take a look at the free space coverage diagram for the Raytheon ASR-23SS surveilance radar at http://www.raytheon.com/products/asr...docs/asr23.pdf You'll find that this civil aradt ssytem is quite capable of detecting a 2 sq m target at 10,000 ft at 40 nautical miles Range isnt the problem, height is, if the aircraft is down in the weeds you will indeed be limited to 20 miles or less Thats why we have AWACS Keith Keith Hell the radars of WW2 had no problem tracking aircraft of the same size, its for damm sure that modern radars are better My father assures me that was not the case, and he WAS the Radar officer on a US Carrier in WW II. I'll take his word on that subject over yours anytime Yet 1930's era radar could detect an Me-109 over France from the UK, the Me-109 has a wingspan roughly the same as a Cessna at 32 ft The US Army SCR-270 could detect aircraft at around 120 miles out. One such set detected the Pearl Harbor raid 30 minutes before the attack. A TBD or a Betty could be seen at about 100 miles, but they are a whole lot bigger than a Cessna 172 A Cessna Skylane has a wingspan of 35 ft, a TBD had a wingspan of 50ft and an Aichi Val a wingspan of 47.1 ft The Radar in an F16 in Air to Air mode has a 50% probability of detecting a 1 m^2 RCS at 40km.. We arent talking about an F-16 radar, we are talking about the more capable search radars at ground stations. Keith |
I have been waiting for someone to mention the drug runner intercepted or
chased by the RAAF C130 [?] up around Darwin many years ago. Something about relative speeds and the C130 having to slow down enough? Cheers Peter Cokley David Bromage wrote in message .. . The RAAF came close to sending a fully armed fighter jet to shoot down a light plane during last year's Commonwealth Heads Of Government Meeting. The light plane was detected flying towards restricted air space around the conference venue. Air Commodore Dave Pietsch said a fully armed F/A-18 Hornet fighter was prepared to intercept the aircraft and commanders had full authority to order the Hornet to shoot it down. http://www.smh.com.au/articles/2003/...050611557.html |
Keith Willshaw wrote in message ... We arent talking about an F-16 radar, we are talking about the more capable search radars at ground stations. Keith And now you will explain how FA18s picked up and intercepted an intruder (a Cherokee Arrow - about a week ago) without having "more capable search radars at ground stations" during a live firing exercise at a range, using their on-board stuff. When, in fact, the intruder had disappeared from civil radar some time before. In other words, you don't have the faintest ****ing clue about what you're mouthing off about. But since you know it all, you can doubtless nominate the range involved, the destination of the Arrow and the actions taken by the FA18 pilots and civil ATC. "more capable search radars at ground stations" - mmm - radar is not really your forte, eh?....... or do you think they are going to chop the wings and u/c off the Wedgetail and sell that for scrap while they set up the remainder propped up by a coupla fenceposts on a deserted airfield? Keith, baby - you just stick to raising guinea pigs and leave the wheels and levers stuff to people who have a clue, eh? |
#28
"RT" wrote in message ... Keith Willshaw wrote in message ... We arent talking about an F-16 radar, we are talking about the more capable search radars at ground stations. Keith And now you will explain how FA18s picked up and intercepted an intruder (a Cherokee Arrow - about a week ago) without having "more capable search radars at ground stations" during a live firing exercise at a range, using their on-board stuff. When, in fact, the intruder had disappeared from civil radar some time before. Not being familiar with that precise incident I'll refrain from comment In other words, you don't have the faintest ****ing clue about what you're mouthing off about. But since you know it all, you can doubtless nominate the range involved, the destination of the Arrow and the actions taken by the FA18 pilots and civil ATC. See above but is normal for fighters to be vectored to their tagets as AI radars tend to have limited cones of coverage "more capable search radars at ground stations" - mmm - radar is not really your forte, eh?....... or do you think they are going to chop the wings and u/c off the Wedgetail and sell that for scrap while they set up the remainder propped up by a coupla fenceposts on a deserted airfield? Nope thats why I mentioned AWACS as being used for detecting low flying aircraft Keith, baby - you just stick to raising guinea pigs and leave the wheels and levers stuff to people who have a clue, eh? Resort to ad-hominem ignored Keith |
#29
"Peter and Susan" wrote in message ... I have been waiting for someone to mention the drug runner intercepted or chased by the RAAF C130 [?] up around Darwin many years ago. Something about relative speeds and the C130 having to slow down enough? Cheers Peter Cokley That rather depends on what the intent of the intercepting aircraft is. The cubans had little problem shooting down a couple of Cessna's in 1996 as I recall. They had been detected on both Cuban and US radar systems. Keith |
#30
David Bromage wrote:
matt weber wrote: In addition, the speeds are so low, that you don't get any leading edge heating. In short I am not at all convinced that an IR guided missile would be able to lock onto a prop powered 100hp aircraft. It just isn't much of an IR or a radar target... Plus speeds are so low that it would be hard to line up a cannot shot. This was the problem the RAAF had with the pilotless Auster in 1955. The Auster was going 30mph slower than the stall speed of a Meteor. Cheers David So... maybe they should have stood off a little ways and treated it as a stationary target..... Coop |
| Thread Tools | |
| Display Modes | |
| Kit Plane Instrument light dimmer | Mickey | Home Built | 1 | December 3rd 03 06:46 PM |
| A Good Story | Badwater Bill | Home Built | 15 | September 3rd 03 04:00 PM |
| OT but very funny after some of the posts we have had of late. | Mycroft | Military Aviation | 1 | August 8th 03 11:09 PM |
| Looking for a fast light plane | Dave lentle | Home Built | 2 | August 6th 03 04:41 AM |
| Slats and Fowler Flaps On Light Plane | Brock | Home Built | 28 | July 31st 03 11:12 PM |
