Hi peoples.. Hopefully this is an easy one for you experts out
there... Hot start on a fuel injected Lycoming commonly seems to call for leaving the mixture at ICO and cranking. Bearing in mind the engine stopped because the mixture was set to ICO, and if you're then not moving the mixture before cranking, how does the engine then fire?? What's in there for it to fire??? Shouldn't the same lack of fuel that caused it to stop also prevent it from starting again?? Are we saying the injection system leaks after the engine is shut down?? And is that dribbling from the injectors what causes flooding?? Cheers Chris |
chris wrote:
/snip/ Are we saying the injection system leaks after the engine is shut down?? And is that dribbling from the injectors what causes flooding?? Cheers Chris Chris, That is *precisely* what we are saying! Now, the subject of how to best re-start said hot injected Lycoming is on par with the greatest political and/or religeous discussions of the ages, but here's my 0 cents worth: Since we are, in fact, presented with a flooded engine, per se, the idea that one should turn "on" the boost pump during this procedure, thus shoving *more* fuel past the leaky flow divider and in to the cylinders, is counter-productive. When the engine was last shut down, the throttle was set at a nice idle RPM. LEAVE IT THERE, and leave the mixture in cutoff when you start to crank. As the engine begins to fire, advance the mixture to full, then back to "ground lean". If, after running, the engine begins to falter, THATS when the boost pump may be required to purge vapor out of the lines. This procedure produces nice, smooth hot starts, with none of that 3000 RPM-panicky-grab-the-throttle-quick-before-we-go-flying-into-the-next-tiedown-row BS that a lot of procedures seem to produce. IMHO, YMMV, yada yada... Happy Flying! Scott Skylane |
On May 11, 2:45 pm, Scott Skylane wrote:
chris wrote: /snip/ Are we saying the injection system leaks after the engine is shut down?? And is that dribbling from the injectors what causes flooding?? Cheers Chris Chris, That is *precisely* what we are saying! Now, the subject of how to best re-start said hot injected Lycoming is on par with the greatest political and/or religeous discussions of the ages, but here's my 0 cents worth: Since we are, in fact, presented with a flooded engine, per se, the idea that one should turn "on" the boost pump during this procedure, thus shoving *more* fuel past the leaky flow divider and in to the cylinders, is counter-productive. When the engine was last shut down, the throttle was set at a nice idle RPM. LEAVE IT THERE, and leave the mixture in cutoff when you start to crank. As the engine begins to fire, advance the mixture to full, then back to "ground lean". If, after running, the engine begins to falter, THATS when the boost pump may be required to purge vapor out of the lines. This procedure produces nice, smooth hot starts, with none of that 3000 RPM-panicky-grab-the-throttle-quick-before-we-go-flying-into-the-next-tiedo*wn-row BS that a lot of procedures seem to produce. IMHO, YMMV, yada yada... Happy Flying! Scott Skylane That makes sense to me!! I had wondered how it all works, and now I think that since I understand it a lot better, I am in a better position to know what to do.. Since I began flying injected engines I so far have not had a engine that wouldn't start when started according to the book, but the time will come!!! |
Lycoming seems to be the worst to start in these situations. I have an
IO-520 and have similar problems. First off the vapor lock is not in the spider lines sitting just above the engine. The vapor lock is in the engine driven fuel pump. Mixture at cut off and run the aux pump for about a minute. This will run cool fuel thru the engine driven pump and then back to the tank. The last five seconds that you are doing this push the mixture control in and leave it there. That allows the fuel to now go into the spider lines. Throttle all the way out. Start cranking, while slowly advancing throttle. About 1/2 way in engine will fire and run. Adjust throttle for about 1000 rpm. If engine wants to stumble because you let off the starter at the wrong time bump the aux pump for about 1 second at a time. Never had to do this more than twice to keep engine running. I very rarely have to bump the pump and get successful starts about 95% of the time when the engine is hot. chris wrote: That makes sense to me!! I had wondered how it all works, and now I think that since I understand it a lot better, I am in a better position to know what to do.. Since I began flying injected engines I so far have not had a engine that wouldn't start when started according to the book, but the time will come!!! |
On May 11, 3:28 pm, Newps wrote:
Lycoming seems to be the worst to start in these situations. I have an IO-520 and have similar problems. First off the vapor lock is not in the spider lines sitting just above the engine. The vapor lock is in the engine driven fuel pump. Mixture at cut off and run the aux pump for about a minute. This will run cool fuel thru the engine driven pump and then back to the tank. The last five seconds that you are doing this push the mixture control in and leave it there. That allows the fuel to now go into the spider lines. Throttle all the way out. Start cranking, while slowly advancing throttle. About 1/2 way in engine will fire and run. Adjust throttle for about 1000 rpm. If engine wants to stumble because you let off the starter at the wrong time bump the aux pump for about 1 second at a time. Never had to do this more than twice to keep engine running. I very rarely have to bump the pump and get successful starts about 95% of the time when the engine is hot. That sounds a bit different - mixture rich for a hot start?? Is this because it's a IO520??? I am using a IO360 in an Arrow, if that makes any difference.. Now reading this I remember when I was a passenger in a Twin Comanche a few times and the engines on that kept trying to die just after start and the pilot had to give it a blast of boost pump a few times until it stabilised.. |
chris wrote:
This will run cool fuel thru the engine driven pump and then back to the tank. This works for me on the IO-550. Cold start is: Mixture rich, throttle cracked, boost pump on, pressure comes up, boost pump off, clear prop, crank Hot start is the same except the boost pump is run much longer before attempting to crank. Actually, hot starts are only an issue if you shut down, go away for a while and try to start up (the worst case is your average fuel stop). The thing starts right back up again if you crank it up after it was running (good thing too if you run a tank dry). |
On May 10, 10:16 pm, chris wrote:
Hot start on a fuel injected Lycoming commonly seems to call for leaving the mixture at ICO and cranking. Bearing in mind the engine stopped because the mixture was set to ICO, and if you're then not moving the mixture before cranking, how does the engine then fire?? What's in there for it to fire??? Shouldn't the same lack of fuel that caused it to stop also prevent it from starting again?? In my experience, the six cylinder Lycs are bitchier during hot starts than the fours. The only Conti experience I have is with the Baron and those engines seemed easier to start hot than Lycs. |
Chris,
It seems like you're getting plenty of Continental tips, this is what we do for the IO540's in our Aztec. Aztec's are known for difficult hot starts due to their tight cowlings that rap their IO-540 Lycoming engines. Only a week ago a fellow Aztec driver arrived at STE and refused an immediate refueling because he could never get it re-started when hot. The following is our method and it hasn't failed us yet. Throttles full open. Mixtures full rich. Boost pumps on ONLY until you see the slightest movement from the fuel flow indicator. Immediately turn pumps off, mixtures idle cut off, throttles off then cracked open. Now crank. While we crank we can watch the compression build as the prop slows slightly, within the next full turn the engine will fire. As the engine fires, mixture up to ONLY 1/3-1/2 position. Hand back to throttle to jockey it slightly if the engine stumbles. One point that I try to enforce when teaching students about hot starts is to remind themselves about the density altitude INSIDE the cylinder, where combustion takes place. The correct fuel/air mixture "window" is relatively small but this is your goal. Hot engine, thin air... it won't take much fuel to reach the proper mixture for combustion. Some POH's, including the Aztec's advocate putting the engine into a "known condition". Basically intentionally flooding the engine and then cranking to pump air through the cylinders until the additional air added to the excess fuel finally brings the overly rich mixture down to combustible level. When I gave air rides in an Archer with a typical O-360, I would simply start with the throttle at idle, mixture rich then as I cranked pulled the mixture towards idle cut off. Without fail it would fire right up as I reached about 1/2 position on the mixture. Jim |
In a previous article, chris said:
Hot start on a fuel injected Lycoming commonly seems to call for leaving the mixture at ICO and cranking. Bearing in mind the engine That's how we start our Lance's IO-540 both hot and cold. Leave the mixture, prop and throttle exactly where they were at shut down. If cold, turn on the electric fuel pump and open the mixture for a few seconds to get some fuel into the cylinders and then back to ICO. Crank, and as soon as it catches, mixture to full rich until it stops sounding like it's only running on a couple of cylinders, then lean. -- Paul Tomblin http://blog.xcski.com/ O Canada, we stand ready to sit down and discuss our problems in a civilized fashion for thee. -- wednesday |
On Fri, 11 May 2007 08:16:54 -0400, Ron Natalie
wrote: chris wrote: This will run cool fuel thru the engine driven pump and then back to the tank. This works for me on the IO-550. Cold start is: Mixture rich, throttle cracked, boost pump on, pressure comes up, boost pump off, clear prop, crank Hot start is the same except the boost pump is run much longer before attempting to crank. The only difference on mine is running the boost pump first with the mixture at cut off to clear out the vapor in the lines. I have no problems with a leaky distribution block. This is a case where I think "old is better" with and ignition switch/mags and a starter switch that are independent of each other. Actually, hot starts are only an issue if you shut down, go away for a while and try to start up (the worst case is your average fuel stop). The thing starts right back up again if you crank it up after it was running (good thing too if you run a tank dry). |
Going IFR from the start | Dylan Smith | Piloting | 9 | May 23rd 05 11:47 PM |
Hopefully not the start of a new trend ... | Cockpit Colin | Piloting | 4 | February 5th 05 06:11 AM |
Cold Start Question | Andy Shane | Piloting | 7 | January 12th 05 01:35 PM |
I want to start | Carlos Estopier | Owning | 16 | May 12th 04 07:09 PM |
