#11
The engine is not designed to turn in a specific direction. Some
accessories are, such as mags, vacuum pumps, starter, alternator. The engine itself will happily run in the other direction, several twins do just that. Mark T. Dame wrote: Ron Natalie wrote: The argument against it is that people claim it hurts the vacuum pump. That was what I was taught many moons ago. I have never confirmed it, but my brain tells me that the engine is designed to turn in one direction, so don't turn it in the other. No real proof (I'm not an A&P and have never played one on TV), but just my own logic. Except when absolutely necessary (like to get the tow bar connected) you shouldn't be turning the prop at all. There's no good reason to justify the dangers. If the engine is properly shutdown (boost pump off, throttle slightly above idle, and mixture to cut off) the chances are greatly reduced than if you just kill the engine by turn off the mags. Additionally, some people recommend checking your mags before shutdown to make sure you don't have a broken P lead which would also help. A flying club I used to belong to had a "policy" (not a rule, just a suggestion that it would be nice if you did it) of turning the prop vertical after parking it to keep the birds from sitting on it and pooing on the plane. Obviously the safest way to prevent an accidental fire while hand turning the prop is to not do it. When I do turn a prob by hand, I try to do it in the direction it turns while running, turn slowly to minimize any compression (don't know if that is true either, just what I was taught), and only use the palms of my hand on the face of the prop to minimize the possibility of the prop smacking the back of my hand should it fire. YMMV. -m |
"Barry" wrote in message ... A flying club I used to belong to had a "policy" (not a rule, just a suggestion that it would be nice if you did it) of turning the prop vertical after parking it to keep the birds from sitting on it and pooing on the plane. We turn the prop vertical in the winter to prevent water from pooling inside the spinner and then freezing into a block of ice. This happened to me once, and the vibration it caused was impressive. We shut down, pulled the plane into a heated hangar, turned the prop vertical, and waited for the ice to melt and drain out. Interesting, and worth remembering. There is also a much older version of the advise--recommending that wooden props be left horizontal when parked for long periods so that moisture in the wood will not migrate to one blade, causing an imbalance. Peter |
On May 15, 10:59 am, "Mark T. Dame" wrote:
Ron Natalie wrote: The argument against it is that people claim it hurts the vacuum pump. That was what I was taught many moons ago. I have never confirmed it, but my brain tells me that the engine is designed to turn in one direction, so don't turn it in the other. No real proof (I'm not an A&P and have never played one on TV), but just my own logic. Except when absolutely necessary (like to get the tow bar connected) you shouldn't be turning the prop at all. There's no good reason to justify the dangers. If the engine is properly shutdown (boost pump off, throttle slightly above idle, and mixture to cut off) the chances are greatly reduced than if you just kill the engine by turn off the mags. Additionally, some people recommend checking your mags before shutdown to make sure you don't have a broken P lead which would also help. A flying club I used to belong to had a "policy" (not a rule, just a suggestion that it would be nice if you did it) of turning the prop vertical after parking it to keep the birds from sitting on it and pooing on the plane. Obviously the safest way to prevent an accidental fire while hand turning the prop is to not do it. When I do turn a prob by hand, I try to do it in the direction it turns while running, turn slowly to minimize any compression (don't know if that is true either, just what I was taught), and only use the palms of my hand on the face of the prop to minimize the possibility of the prop smacking the back of my hand should it fire. YMMV. Although I agree with the dangers of accidental engine starts, what I would like to know if there really have been any cases of inadvertant engines starts when the prop is turned half a rotation with the mixture in cut-off even if the magnetos were on. All the cases I am aware of are related to hand-propping, which is not the same as turning the prop to reposition the blades. |
On May 15, 5:59 am, "Doug Palmer" wrote:
Several pilots found themselves in a debate at our field yesterday. The issue is weather it is safer to move the propeller on a (parked) aircraft in the direction of usual engine rotation, or opposite usual rotation. This is assuming that the propeller needs to move for some reason. The reasonings ranged from "you should not turn an engine backwards" to "turning the engine backwards disarms the impulse coupling", to several issues in between. Any thoughts from the groups collective wisdom? Of course turning it backward may damage the vac pump but I've never flown a hand prop'ped airplane that had a vac system. The problem with turning it backwards is that it can still on forward. If you turn it and stop near the compression, it will then turn back the other way. So, either way assume its hot. Once you've been flying a hand propped airplane for awhile you will realize that it is not safe or reasonable to use a full body kick every time you turn the prop. So I would pull the prop through with an open palm hand such that if the prop did start I would be ok (some of the old guys actually start the plane this way). Then, when its time to start, I hit the mags and do a full kick. If you primed the engine correctly it should only take about an 1/8 of a turn for it to fire. BTW: I would never hand prop a nosewheel plane. -Robert |
On May 15, 8:20 am, wrote:
We also check the mag grounding at idle just before mixture cutoff. Dan What type of plane are you handpropping that has mixture cutoff? Must not be the traditional Stromburg carb. -Robert |
"Newps" wrote in message . .. If the engine is properly shutdown (boost pump off, throttle slightly above idle, and mixture to cut off) the chances are greatly reduced than if you just kill the engine by turn off the mags. Additionally, some people recommend checking your mags before shutdown to make sure you don't have a broken P lead which would also help. A flying club I used to belong to had a "policy" (not a rule, just a suggestion that it would be nice if you did it) of turning the prop vertical after parking it to keep the birds from sitting on it and pooing on the plane. Obviously the safest way to prevent an accidental fire while hand turning the prop is to not do it. When I do turn a prob by hand, I try to do it in the direction it turns while running, turn slowly to minimize any compression (don't know if that is true either, just what I was taught), and only use the palms of my hand on the face of the prop to minimize the possibility of the prop smacking the back of my hand should it fire. YMMV. That's only true with 2 cyclce engines, even then, ignition timing is a factor. The rotational derection of a 4 cycle engine is determined by the cam, valve and ignition timing. Twin engine aircraft with counter rotating props/engines have beend designed specifically to do so. The engines as a whole, are not interchangable. |
Robert M. Gary wrote:
BTW: I would never hand prop a nosewheel plane. Personally, I wouldn't hand prop any plane. I got too many nicks and cuts as a kid finger propping model airplanes. (-: Which reminds me of a story. One winter a few years ago the FBO had a 152 that was being stubborn in the cold weather, so one of the line guys helped out by hand propping it for the pilot. He was wearing gloves and when the plane started, one of his gloves came off. The prop threw the glove about 30 feet and the pilot freaked out because he thought the guy's hand was still in the glove! He shut the engine down to check on him. The line guy wasn't happy about having to hand prop it again... -m -- ## Mark T. Dame ## CP-ASEL, AGI ## insert tail number here ## KHAO, KISZ "In accord with UNIX philosophy, Perl gives you enough rope to hang yourself." -- Programming perl, Larry Wall and Randal L. Schwartz |
Doug Palmer wrote:
Several pilots found themselves in a debate at our field yesterday. The issue is weather it is safer to move the propeller on a (parked) aircraft in the direction of usual engine rotation, or opposite usual rotation. This is assuming that the propeller needs to move for some reason. The reasonings ranged from "you should not turn an engine backwards" to "turning the engine backwards disarms the impulse coupling", to several issues in between. Any thoughts from the groups collective wisdom? Never, ever turn a Rotax 912/914 backwards. It will break the suction in the oil line. To regain oil pressure you have to undo oil lines and refill them. |
BTW: I would never hand prop a nosewheel plane. Just out of curiosity, why does a nosewheel make a difference? I used to have an old 172 (with the cheesey 20 amp generator) that required a handprop after most night flights. I didn't seem any different than handpropping a tailwheel equiped 170. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200705/1 |
"Robert M. Gary" wrote in message ps.com... On May 15, 8:20 am, wrote: We also check the mag grounding at idle just before mixture cutoff. Dan What type of plane are you handpropping that has mixture cutoff? Must not be the traditional Stromburg carb. -Robert This could be just a nomenclature issue. I was taught to call the lean position of the mixture control "idle cut off" even though it really doesn't cut anything off. However, it is too lean to keep the engine running at 1000 rpm. I'm curious about what others think Peter |
| Thread Tools | |
| Display Modes | |
| I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 07:39 PM |
| Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 02:11 AM |
| Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 02:26 AM |
