This article: http://www.thestar.com/Business/article/213475
claims that the tuburcles on the leading edge of whale fins actually improve efficiency in fluid by lowering stall speed. I expect someone here might have a good sense if this has any likelihood of working. |
![]() "RichardFreytag" wrote in message ups.com... This article: http://www.thestar.com/Business/article/213475 claims that the tuburcles on the leading edge of whale fins actually improve efficiency in fluid by lowering stall speed. I expect someone here might have a good sense if this has any likelihood of working. I'm not so sure, Richard. I remember about a decade ago there was an independent double-blind study done on the aerodynamics of humpback whales. Best they could achieve was an L/D of about 0/1 when dropped from 10,000 feet. bumper Minden, NV ZZ |
On May 14, 12:37 pm, "bumper" wrote:
"RichardFreytag" wrote in message ups.com... This article:http://www.thestar.com/Business/article/213475 claims that the tuburcles on the leading edge of whale fins actually improve efficiency in fluid by lowering stall speed. I expect someone here might have a good sense if this has any likelihood of working. I'm not so sure, Richard. I remember about a decade ago there was an independent double-blind study done on the aerodynamics of humpback whales. Best they could achieve was an L/D of about 0/1 when dropped from 10,000 feet. bumper Minden, NV ZZ As I recall pretty much came out about the same as a bowl of petunias. |
On Mon, 14 May 2007 16:37:06 GMT, "bumper"
wrote: "RichardFreytag" wrote in message oups.com... This article: http://www.thestar.com/Business/article/213475 claims that the tuburcles on the leading edge of whale fins actually improve efficiency in fluid by lowering stall speed. I expect someone here might have a good sense if this has any likelihood of working. I'm not so sure, Richard. I remember about a decade ago there was an independent double-blind study done on the aerodynamics of humpback whales. Best they could achieve was an L/D of about 0/1 when dropped from 10,000 feet. But they did achieve a successful calibration of the Norden Whalesight. rj |
Whale of a 'tail.'
At 17:30 14 May 2007, Ralph Jones wrote: On Mon, 14 May 2007 16:37:06 GMT, 'bumper' wrote: 'RichardFreytag' wrote in message roups.com... This article: http://www.thestar.com/Business/article/213475 claims that the tuburcles on the leading edge of whale fins actually improve efficiency in fluid by lowering stall speed. I expect someone here might have a good sense if this has any likelihood of working. I'm not so sure, Richard. I remember about a decade ago there was an independent double-blind study done on the aerodynamics of humpback whales. Best they could achieve was an L/D of about 0/1 when dropped from 10,000 feet. But they did achieve a successful calibration of the Norden Whalesight. rj |
RichardFreytag writes:
This article: http://www.thestar.com/Business/article/213475 claims that the tuburcles on the leading edge of whale fins actually improve efficiency in fluid by lowering stall speed. I expect someone here might have a good sense if this has any likelihood of working. Was worked on in the wind tunnel by one of the east coast US unis, Princton?, and they got up to about a 28deg AoA with a perspex replica of a Humpback fin. |
Earlier, RichardFreytag wrote:
This article:http://www.thestar.com/Business/article/213475 claims that the tuburcles on the leading edge of whale fins actually improve efficiency in fluid by lowering stall speed... Lower the stall speed? Probably. I can see them having the same effect as adding typical blade-type turbulators in that regard. Improve efficiency? It depends on what your measure of efficiency is. I strongly doubt that it could make any improvement in best L/D. My guess would tend the other way. I'd reckon that sucker-punching your boundary layer is a sure ticket for a trip through the weeds. Thanks, Bob K. http://www.hpaircraft.com/hp-24 |
Thermal Core Tip Stalling | Derek Copeland | Soaring | 7 | February 2nd 06 02:55 PM |
Stalling and spinning generally | Ian Strachan | Soaring | 0 | February 1st 04 08:40 PM |
Spinning or the after effects of stalling. | Dave Martin | Soaring | 0 | January 29th 04 11:24 PM |
Wingdrop while stalling | drake | Home Built | 28 | January 17th 04 12:43 PM |
Tow plane airspeed vs. glider being towed airspeed? | MHende6388 | Soaring | 2 | September 28th 03 09:35 AM |
