#41
"Cubdriver" usenet AT danford DOT net wrote in message
... On 15 May 2007 14:35:47 -0700, "Robert M. Gary" wrote: In the C140, the Aeronca, and the J-3 the carbs (probably all Stromburg), pulling the mixture all the way out at idle had no effect at all on the engine. I fly a J-3, and I've never seen one with a mixture control. In the C-120 I flew (IIRC it was a Stromberg) the mixture lever was safety wired in place - there was no mixture control on the panel. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
#42
On May 16, 2:52 am, Cubdriver usenet AT danford DOT net wrote:
On 15 May 2007 09:19:59 -0700, "Robert M. Gary" wrote: So I would pull the prop through with an open palm hand such that if the prop did start I would be ok (some of the old guys actually start the plane this way) That's what I was taught to do, and what I do if I'm propping from the front (rarely). As it happens, I was 68 at the time, but my instructor was 21. Blue skies! -- Dan Ford I still do the full kick when I'm actually starting the engine. Even when I was flying the float plane and propping from the back, I'd give a kick. Of course, if you prime the 65 cont hp engines correctly they take almost no effort to start. I can't imagine trying to start my Mooney that way!! -Robert |
#43
On May 15, 2:47 pm, "Morgans" wrote:
"Robert M. Gary" wrote BTW: I would never hand prop a nosewheel plane. I think I know the reason for this opinion, but I would still be interested in hearing your reasoning. Why no hand propping a nose dragger for you? Because the top arch of the prop is close to my head. When teaching students to hand prop the biggest challenge is to get them to stand close enough to the prop. Standing too far back is much more dangerous than standing too close. The worst thing that could happen is to fall into the prop, something that can only happen if you are standing back and leaning into it. -Robert |
#44
"Robert M. Gary" wrote Because the top arch of the prop is close to my head. When teaching students to hand prop the biggest challenge is to get them to stand close enough to the prop. Standing too far back is much more dangerous than standing too close. The worst thing that could happen is to fall into the prop, something that can only happen if you are standing back and leaning into it. I was wrong. I had not heard that exact variation, before. g Kicking though is still too close, even if you are swinging your body away from the tip? -- Jim in NC |
#45
However! I've never moved a prop unless someone was standing on the
brakes, and since if I'm propping the plane it's usually because the guy at the controls is a stranger who probably knows little about Cubs, I always prop from behind. Blue skies! -- Dan Ford I flew cubs for awhile 30+ years ago. If there was no one around to prop yours, the drill was to stand behind the prop on the right side and flip it with your right hand, The left was poised to adjust the throttle when it caught. I recall that they were amazingly easy to start (usually on the first or second try). David Johnson |
#46
On Tue, 15 May 2007 17:47:01 -0400, "Morgans"
wrote: Why no hand propping a nose dragger for you? I've done it a few times but found it very awkward, as the prop on, say, a C-150 or 172 is much lower than the prop on a taildragger like my T-Craft. On the T-Craft turning it backwards was the standard way of clearing it if it was flooded... but there was no impulse coupling nor vacuum pump. -Dana -- -- If replying by email, please make the obvious changes. ------------------------------------------------------------------------------- Congress shall make no law....What part of NO didn't you understand? |
#47
from the tip? What exactly is "kicking"? Jose -- There are two kinds of people in the world. Those that just want to know what button to push, and those that want to know what happens when they push the button. for Email, make the obvious change in the address. |
#48
On Thu, 17 May 2007 04:05:57 GMT, Jose
wrote: Kicking though is still too close, even if you are swinging your body away from the tip? What exactly is "kicking"? You're facing the prop from the front ot the plane. The blade is at 10 o'clock, at the start of a compression stroke,. You've previously primed the engine and pulled the prop through several compressions with the switch cold and the mixture rich. Now you holler "Hot!, Brakes!" (assuming somebody's in the cockpit -- otherwise you switch the mags to hot and check the chocks and tiedown. Reach up, pads of your fingers just over the top of the blade. Left leg on ground, right leg swings forward and smartly back at the same time that you snap the blade down. The leg swing propels your body backward, away from the propeller arc. That was the drill on the Taylorcraft. Cub pilots can swing the prop from behind because of the way the doors work. I guess you'd have to prop a T-craft on floats from behind, too, but it wouldn't be pretty to look at. It took the lady who sold me the plane about ten minutes to teach it to me. It feels kinda natural. If it's a big exertion, you're doing it wrong. Don |
#49
On 2007-05-15 16:28:54 -0700, EridanMan said:
Interesting topic, interesting discussion... but if I may expand on the original question a bit? The Original piper POH that came with my bird ('67 PA-28-140) actually recommends that that prop be pulled through two complete rotations backwards any time the engine is started after sitting for a long time (it actually says its a good idea for every flight, but should be mandatory any time the engine's been sitting for a while). I've NEVER heard or seen this advice anywhere else... I've never practiced it... It seems almost insane to me... but the book says what the book says. Anyone have any clue why? I can get the exact wording tpmogjt ... its in the 'preflight and takeoff' section of the book. This is also recommended in at least Cessna 172 manuals for cold weather starts. The idea is that oil that is cold or has been sitting awhile is thicker and more sluggish. Pulling the prop through limbers up the oil some, so the engine does not have to work as hard while starting. It can make all the difference in whether you are able to start the engine or not. -- Waddling Eagle World Famous Flight Instructor |
#50
On 2007-05-15 07:46:15 -0700, "Dudley Henriques" said:
"Doug Palmer" wrote in message ink.net... Several pilots found themselves in a debate at our field yesterday. The issue is weather it is safer to move the propeller on a (parked) aircraft in the direction of usual engine rotation, or opposite usual rotation. This is assuming that the propeller needs to move for some reason. The reasonings ranged from "you should not turn an engine backwards" to "turning the engine backwards disarms the impulse coupling", to several issues in between. Any thoughts from the groups collective wisdom? This is one issue where you don't want to get bogged down in the technicalities involving vacuum pumps and impulse couplings. The bottom line on this issue is that you should NEVER.....EVER...... trust a propeller not to kill you if you turn it by hand IN EITHER DIRECTION while it's attached to the airplane. Dudley Henriques People will say it is technically impossible, but I think it is wishful thinking. An engine may not run backwards very well, but I have seen too many malfunctioning magnetos to believe that it could never happen. It might be improbable, but I would not bet my life on the idea that it is impossible. -- Waddling Eagle World Famous Flight Instructor |
| I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 07:39 PM |
| Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 02:11 AM |
| Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 02:26 AM |
