My plans call for the use of 2024 1.5mm to use in the forming of
brackets that will hold the bellcranks. Each part is doubled, (left and right bracket top and bottom parts on the bellcranks), so it seems to be extremly strong. Now, don't get me wrong, I can make a call today and order the material that it calls for, but at the moment I have quite a bit of the 6061 t-6 aluminum just sitting here. So can anyone give me good reasons why I shouldn't use this in place of the 2024? Although I've read the materials data sheets on the strengths of each, It does seem to click for me of what the reason is for the 2024. Any help? Lou |
Lou wrote:
My plans call for the use of 2024 1.5mm to use in the forming of brackets that will hold the bellcranks. Each part is doubled, (left and right bracket top and bottom parts on the bellcranks), so it seems to be extremly strong. Now, don't get me wrong, I can make a call today and order the material that it calls for, but at the moment I have quite a bit of the 6061 t-6 aluminum just sitting here. So can anyone give me good reasons why I shouldn't use this in place of the 2024? Although I've read the materials data sheets on the strengths of each, It does seem to click for me of what the reason is for the 2024. Any help? Lou 6061 is too brittle. 2024 is a little softer and much lees likely to crack. 6061 is more resistant to corrosion. |
Lou wrote:
My plans call for the use of 2024 1.5mm to use in the forming of brackets that will hold the bellcranks. Each part is doubled, (left and right bracket top and bottom parts on the bellcranks), so it seems to be extremly strong. Now, don't get me wrong, I can make a call today and order the material that it calls for, but at the moment I have quite a bit of the 6061 t-6 aluminum just sitting here. So can anyone give me good reasons why I shouldn't use this in place of the 2024? Although I've read the materials data sheets on the strengths of each, It does seem to click for me of what the reason is for the 2024. Any help? Lou You neglected to mention the temper of the 2024 called for. In any event, this seems like a question appropriate to the designer- only they know why they specified 2024 for sure. Sometimes the decision is the result of detailed analysis, sometimes it is non critical and only because they had a scrap the right size laying around when they built the prototype. Anyone else commenting is just speculating with the information available, with their accuracy at best directly proportional to the information given. I don't have a reference near to hand, but believe that 2024 in T3 temper is about twice as strong as 6061 in T6, and is more amenable to bending at sharper radii without cracking, but I could likely be mis remembering. Charles |
Earlier, Lou wrote:
My plans call for the use of 2024 1.5mm to use in the forming of brackets that will hold the bellcranks.... So can anyone give me good reasons why I shouldn't use this in place of the 2024? I've made bellcrank leaves and mounts out of .063" 6061-T6 where I was sure that the applied stresses fell within the material properties. For forming operations, one good reference is the table of minimum bend radii reproduced in the Aircraft Spruce catalog: http://www.aircraftspruce.com/catalo...s/aluminfo.php There's nothing magic about 2024-T3. It is stronger than 6061-T6, and a bit more expensive, and for many or most applications the extra strength is worth the extra money. However, it has the same stiffness as 6061, so for stiffness-bound applications there's not much point in using 2024. Control push-pull tubes is a good example of this - one of my favorite Stan Hall articles points out that push-pull tubes are pretty universally stiffness-bound by buckling properties. Anyhow, if you've done analysis on the mechanism and surrounding structure, if you're confident you've correctly estimated the maximum hinge moment, and also figured in reasonable (JAR 22 or Part 23 or other appropriate) maximum input forces, and accounted for appropriate safety factors, if you've accounted for 6061-T6's lower ultimate and yield stesses, and found this to be a valid substitution, I say go for it. If you haven't done that analysis and are just guessing, sticking with what the plans call for will save you some sleepless nights spent second-guessing yourself. As for another poster who says that 6061-T6 is too brittle, do you have a cite for that very general assertion? How does that reconcile with the fact that Zenith makes entire airplanes out of the stuff? Thanks, Bob K. http://www.hpaircraft.com/hp-24 |
On May 29, 12:02 pm, Bob Kuykendall wrote:
As for another poster who says that 6061-T6 is too brittle, do you have a cite for that very general assertion? How does that reconcile with the fact that Zenith makes entire airplanes out of the stuff? Thanks, Bob K.http://www.hpaircraft.com/hp-24 2024T3 (not Alclad) has a tensile ultimate of 70KSI and a yield of 50KSI, with elongation of 18% and a Brinell hardness of 120. 6061T6 has an ultimate of 45KSI and a yield of 40, elongation 12%, Brinell 95. So the 2024T3 is a LOT stronger but a little more ductile (so less brittle?) and at the same time, strangely, harder. I wouldn't replace the 2024 with the 6061 in anything I don't want to break. References from Machinery's Handbook, 24th Ed., 1992. Dan |
Thanks Guys,
I'll be ordering the 2024 tommorow. This is what I like about this group. Lou |
Michelle P wrote:
Lou wrote: My plans call for the use of 2024 1.5mm to use in the forming of brackets that will hold the bellcranks. Each part is doubled, (left and right bracket top and bottom parts on the bellcranks), so it seems to be extremly strong. Now, don't get me wrong, I can make a call today and order the material that it calls for, but at the moment I have quite a bit of the 6061 t-6 aluminum just sitting here. So can anyone give me good reasons why I shouldn't use this in place of the 2024? Although I've read the materials data sheets on the strengths of each, It does seem to click for me of what the reason is for the 2024. Any help? Lou 6061 is too brittle. 2024 is a little softer and much lees likely to crack. 6061 is more resistant to corrosion. Huh? About the brittleness. I thought it was the other way around... |
Richard Riley wrote:
On 29 May 2007 11:02:30 -0700, Bob Kuykendall wrote: As for another poster who says that 6061-T6 is too brittle, do you have a cite for that very general assertion? How does that reconcile with the fact that Zenith makes entire airplanes out of the stuff? Of course, that didn't work out so well when they made the Cricket. Uh, because it was designed for 6061-T6? |
On May 30, 7:43 am, Richard Riley wrote:
On Wed, 30 May 2007 06:33:10 GMT, cavelamb himself wrote: Richard Riley wrote: On 29 May 2007 11:02:30 -0700, Bob Kuykendall wrote: As for another poster who says that 6061-T6 is too brittle, do you have a cite for that very general assertion? How does that reconcile with the fact that Zenith makes entire airplanes out of the stuff? Of course, that didn't work out so well when they made the Cricket. Uh, because it was designed for 6061-T6? I'm not speaking from personal knowledge, but it's been on the CriCri mailing list several times. The Cri-Cri was designed for 2024-T3 for the spar fittings and a few other places. When Zenith struck a deal to sell kits in the US they substituted 6061 and called it the Cricket. The results were very bad. To this day the designer refuses to sell plans within the US. - Hide quoted text - - Show quoted text - The Hummelbird plans show 2024T3 for the wing spar attach fittings, but it's not really obvious and if the builder is busy cutting 6061 for all the other stuff he might just make them out of it. Could be bad. Dan |
For all or you that are interested. I've made the brackets out
of 2024 and the 2024 bends harder, but doesn't seem to snap as easy. Lou |
| Bending brake capacity: 2024-T3 vs. mild steel? | Ihab Awad | Home Built | 2 | June 6th 05 10:50 PM |
| need 2024 t3 5 foot by 12 foot .020 | groundloop | Home Built | 2 | August 22nd 03 05:29 PM |
