Twin engine aircraft have been operating routinely from USN carriers for nearly sixty years now. The earliest to routinely operate was the AJ Savage, (which actually had three engines, of course), I guess. The F2H was in the Fleet about that time as well - 1950ish. (I figure the F7F doesn't count since as far as I know no squadron ever deployed on a cruise.)
	Anyway... Has any twin-engine aircraft been authorized (per manual or NATOPS) to land with an engine inoperative? Has any twin-engine aircraft ever landed aboard with an engine out?  |
"Larry Cauble"  wrote...
	Has any twin-engine aircraft been authorized (per manual or NATOPS) to land with an engine inoperative? Has any twin-engine aircraft ever landed aboard with an engine out? Don't know of one off hand that has NOT! A-6, E-2, F-4, F/A-18...  |
	Larry Cauble wrote: Twin engine aircraft have been operating routinely from USN carriers for nearly sixty years now. The earliest to routinely operate was the AJ Savage, (which actually had three engines, of course), I guess. The F2H was in the Fleet about that time as well - 1950ish. (I figure the F7F doesn't count since as far as I know no squadron ever deployed on a cruise.) Anyway... Has any twin-engine aircraft been authorized (per manual or NATOPS) to land with an engine inoperative? Has any twin-engine aircraft ever landed aboard with an engine out? Dunno about the USN, but of RN types the Fairey Gannet could, of course. IIRC the Short Sturgeon was the first twin designed to be able to land on with an engine out, but of course it never went operational from 'carriers. -- Andy Breen ~ Not speaking on behalf of the University of Wales, Aberystwyth Feng Shui: an ancient oriental art for extracting money from the gullible (Martin Sinclair)  |
On Fri, 1 Jun 2007 23:07:44 +0100, Larry Cauble
	wrote: Twin engine aircraft have been operating routinely from USN carriers for nearly sixty years now. The earliest to routinely operate was the AJ Savage, (which actually had three engines, of course), I guess. The F2H was in the Fleet about that time as well - 1950ish. (I figure the F7F doesn't count since as far as I know no squadron ever deployed on a cruise.) Anyway... Has any twin-engine aircraft been authorized (per manual or NATOPS) to land with an engine inoperative? Has any twin-engine aircraft ever landed aboard with an engine out? Many times in the S-2/E-1/C-1 community. The barrier was rigged for the landing and it frequently resulted in serious (even "strike") damage to the aircraft. I would guess the same to be true for the E-2/C-2 community. And the S-3 community. Bill Kambic Member, RAFS  |
			 Quote:
			 "Larry Cauble" wrote in message ... 'John Weiss[_1_ Wrote: ;519294']"Larry Cauble" wrote...- Has any twin-engine aircraft been authorized (per manual or NATOPS) to land with an engine inoperative? Has any twin-engine aircraft ever landed aboard with an engine out?- Don't know of one off hand that has NOT! A-6, E-2, F-4, F/A-18... So when an A-6, F-4, F-14 or F-18 with one engine out lands, is it into the barrier like the props? Generally not. There's enough thrust single engine to bolter. R / John  |
	A-6, E-2, F-4, F/A-18... Any done at night? THAT would be a superman story! TV  |
	"John Carrier" wrote: "Larry Cauble" wrote in message ... 'John Weiss[_1_ Wrote: ;519294']"Larry Cauble" wrote...- Has any twin-engine aircraft been authorized (per manual or NATOPS) to land with an engine inoperative? Has any twin-engine aircraft ever landed aboard with an engine out?- Don't know of one off hand that has NOT! A-6, E-2, F-4, F/A-18... So when an A-6, F-4, F-14 or F-18 with one engine out lands, is it into the barrier like the props? Generally not. There's enough thrust single engine to bolter. R / John And / or the boat can make enough wind over the deck to make it reasonable.  |
I have one each S2 and S3 trap with one out, the S3 trap was at night.
	Neither case had the barrier rigged. Neither was a particular problem. In the case of the S3, the a/c was a bit more sensitive to glide slope control since the operating engine was at much higher power than either engine if both were operating. Allan Rypka VS 38, VS 22, VS 41 TV wrote: Don't know of one off hand that has NOT! A-6, E-2, F-4, F/A-18... Any done at night? THAT would be a superman story! TV  |
	So when an A-6, F-4, F-14 or F-18 with one engine out lands, is it into the barrier like the props? In general, no. The pilot will usually get a couple chances to make a normal approach and landing. However, bad weather may dictate the barricade for the first try.  |
| ATP wants a single engine add on | Emily | Piloting | 33 | September 22nd 06 12:06 AM |
| Working on the ideal single engine tug! | TugMan | Piloting | 13 | June 9th 06 01:37 AM |
| single engine owner? | [email protected] | Owning | 0 | May 31st 06 11:47 PM |
| Single-engine plane with the best range? | Bob | Piloting | 24 | February 25th 04 05:52 PM |
| Is taking off on single mag bad for engine | flyer | Home Built | 10 | September 21st 03 10:43 PM |
