#151
Probably because the water test with a graduated tube was a lot easier, cheaper and probably more accurate. I wonder why he quit packaging it and selling the stuff. Actually the test kit was very fast and easy. I was able to test a sample before I filled my 5 gallon cans. when I tested the kit against known gasohol it did indeed show positive with the color matching what a 10% mixture would show. Paul N1431A KPLU |
#152
On May 30, 7:13 pm, "Blueskies" wrote:
Is it true that there is no longer any requirement to label gasoline contaminated with alcohol? Good article hehttp://motorcycleinfo.calsci.com/Gasoline.html I just did the add water to gas test on a couple of local gas sources and all contain alcohol, and none of the pumps said anything about it. The feds just dropped the requirement to label the pumps and we all missed it? Jay, where do you fill the grape from and how do you know there is no evil alcohol in it? When MTBE was outlawed, the only financially feasable alternative was alcohol. It is mantdated to be used in about 20 states, mostly on the two coasts, but several other states have 5-10% alcohol mandates - Missouri is the latest - their mandate begins Jan 08. Becides entire states most of the nations major cities have mandates that require alcohol to be added to increase the oxygen content of the gasoline to reduce emmissions. Retail pump labeling is not a federal requirement, it varies state by state. Some states require that retail pumps be labled if the gasoline contains alcohol, other states do not have such a requirement. Even if you do not live in a state that requires the addition of alcohol to auto gas, that is no guarantee that your gasoline does not contain alcohol. Currently retailers can make an extra 5-7 cents per gallon by adding 10% aclohol to their auto gas. I recently did a presentation on alcohol in auto gas for an aviation group. I took several samples of 87 octane auto gas and added 10 % alcohol to some samples and to some of these mixture samples I added 20% water. You could not see the water in the sample. Alcohol absorbs water - this is the danger of using it in aircrft. I then lowered the temperature on the samples and the water froze and settled out. This would have been a sure way to plug and line or injector. "Pure" auto gas will generally be available at FBO's - then can order it delivered without alcohol, but I would not use any auto fuel that I bought at a retail outlet (Convenience Store) and hauled to the airport with out doing an alcohol test. |
#153
On Jun 5, 12:22 pm, Cubdriver usenet AT danford DOT net wrote:
On Sun, 3 Jun 2007 12:37:37 -0400, "Morgans" wrote: But, it is _very_ difficult (it takes some expensive chemistry tricks) to get all of the water distilled out of alcohol, in other words, stronger than around 98% alcohol. I think that's correct. When I was a student in England years ago, we used to buy a liquor known as Polish White Spirits, which was 180 proof or 90 percent. The local wisdom (university students) held that anything stronger would promptly dilute itself back to 180 proof from water in the air (this was England, remember, very humid). Google tells me that one can buy 190 proof (95 percent) "Everclear" grain alcochol in British stores today. Blue skies! -- Dan Ford (Proof = the concentration of alcohol at which gunpowder soaked with it will still explode, or rather flash up. It was therefore called "proof", which later became 100 proof. It just happened to be 50 percent alcohol, so 200 proof is 100 percent. (More student wisdom.) (Wiki tells me that 100 proof is actually 49.28 percent alcohol BY WEIGHT. By volume, it's less, so the student wisdom is a bit shaky.) Blue skies! -- Dan Ford Claire Chennault and His American Volunteers, 1941-1942 forthcoming from HarperCollinswww.flyingtigersbook.com The only real difference between the 190 proof Everclear you refer to and the alcohol that is added to auto gas is that the alcohol to be added to auto fuel is "denatured". All this means is that it has been poisioned so that it is unfit for human consumption. This is usually done with natural gasoline and the regulations allow them to vary the amount they add to 3-5%. |
#154
As it is perhaps well known, gentian violet dye is chemically methylrosaniline chloride and has been used as both a bacteriological and histological stain ... http://dermatology.about.com/library...gentviolet.htm Definition: Gentian Violet is a purple dye that is used to treat vaginal yeast infections and thrush. The dye is "painted" on the infection and kills the fungus. It can stain clothing. |
#155
Want to emphesize that ALL gasoline has some water in it. It leaves the refinery with some non-zero amount. It's stored in floating roof tanks [1] that will let some in. It's in a truck in the rain... it's there. The question is getting rid of same. We all know how -- let it sit quietly and it shall settle out. Then open the bottom drain and watch. That might be under your wing, or on a tank or inbetween... [1] Gas does not go kabboom; gas vapor does. So it's stored not in tanks as much as 4 million gallon cylinders with closed bottoms. On top of the gas there's a big heavy floating roof that has a gasket all the way around the edge. It floats directly atop the gas; ergo no vapor space. Then there's a sliding ladder deal so the pipeline operator can climb up over the cylinder lip and back down onto the roof. BUT, with the tank half full; there's a 2 million gallon trap atop the roof to collect rainwater and snow; some of which leaks past that gasket. Most is SUPPOSED to go through an articulated downspout gadget INSIDE the tank and out the side at the bottom; but that's only when the temperature is well above freezing...and they leak a little too... This was obvious to many pilots & few ground-dwellers, but now many of the tanks also have a cap on top to keep some of the rain and snow out. I was looking for a GoogleMap photo and all the ones I worked on are now capped. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
#156
Given the issue with alcohol, and the fact it is injected at the last stage - truck loading -- why aren't the STA owners such as EAA running campaigns to set up procedures for FBO's to procure untainted autogas? I can see the average truck loading terminal saying "we can't do that" until they get a memo saying that they can... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
#157
David Lesher wrote:
This was obvious to many pilots & few ground-dwellers, but now many of the tanks also have a cap on top to keep some of the rain and snow out. I was looking for a GoogleMap photo and all the ones I worked on are now capped. Here's some uncaped ones. http://tinyurl.com/ypupkd |
#158
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net writes:
David Lesher wrote: This was obvious to many pilots & few ground-dwellers, but now many of the tanks also have a cap on top to keep some of the rain and snow out. I was looking for a GoogleMap photo and all the ones I worked on are now capped. Here's some uncaped ones. http://tinyurl.com/ypupkd and one photo I just found: https://www.piersystem.com/posted/42...017.125127.JPG -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
#159
On Tue, 5 Jun 2007, Morgans wrote:
I did think I understood that the problem with gasohol for airplanes was incompatibility with some rubber parts of the fuel system. That's what I've always heard too, but I've never been able to get anyone to back it up with info about SPECIFIC parts that are in danger. In particular, I'd really like to know what SPECIFIC parts I have to change in my IO-360-A1A's fuel system so I don't have to worry about alcohol. (It's in an experimental, so legality isn't an issue.) At the same time, I see all manner of decades-old cars & trucks running for many years on gas that's part alcohol, with all original fuel system parts, with no ill effects whatsoever. So I'm pretty close to writing off the whole ethanol fuel system damage thing as an old wives' tale, but not yet willing to bet the farm on it. -Dan |
#160
"Dan Youngquist" wrote That's what I've always heard too, but I've never been able to get anyone to back it up with info about SPECIFIC parts that are in danger. In particular, I'd really like to know what SPECIFIC parts I have to change in my IO-360-A1A's fuel system so I don't have to worry about alcohol. (It's in an experimental, so legality isn't an issue.) Well, let's think about it. I'm not an A&P, and have never torn an airplane carb or injector or fuel pump, or ..... apart. Nevertheless, we can take some very educated guess, and hopefully, some others with specific knowledge can jump in with some specifics of the systems. Let's look at the fuel system, from tank, all of the way until it goes "bang." (the gas in the fuel system, that is!) Fuel tank. Not a bladder, in an experimental, I would guess. Is it sloshed sealed? Some sloshes will definitely NOT hold up to alcohol. Some will. Is it sealed with other seam sealers? Again, some will hold up to alcohol, and some will not. What did you use, if you did use them? How about the seals or O-rings from the tank to fuel line fitting? What did you use there? My suggestion for this, and most all of the other replaceable parts, is to get an exact replacement and soak it in some E- 85. If that does not cause the part to do strange things, 10% gasohol should not cause a problem. Fuel line, and flexible transitions, if used? Again, test what you used, or find the manufacturer's recommendations, based on tests. Fuel Valve. Lots of O-rings, there. Will they test alright? Oh, back up. Fuel level indication sender, or sight glass and connections. Test them. Fuel pump, both electric auxiliary, and engine driven fuel pump. Use manufacturer's recommendations, as there are so many variables, possibly more in an electric. The engine driven pump recommendations will probably not allow gasohol, but you, or someone who knows how could tear one down, and soak test all of the non metal parts. Gasolater and other filters. Test, to verify they will hold up. Injector controls, spiders, and O-rings in all of these should be verified. All of the non metal parts if it is a carburetor, for some people. Then the injectors themselves will need a manufacturer's recommendation, or a test. Does that cover it all? What did I miss? How about everyone, and you, Dan? Do you think this kind of step by step investigation would uncover all of the weak parts, and prove them OK, or vulerenable? Is it all worth it? That would be a question you would have to answer. Perhaps another valid approach would be to contact groups that have flown gasohol, or pure ethanol airplanes. The EAA has done it; are there other groups that have? Would they be willing to share what they have learned? I await everyone's opinions. I agree with the premise that I think Dan has; that it should be possible, and practical to develop a gasohol safe airplane. "Some will no doubt shout, you will crash and burn!" This could be an interesting discussion. -- Jim in NC |
| Thread Tools | |
| Display Modes | |
| How scary is gasohol? | Charles Talleyrand | Owning | 27 | March 1st 04 12:39 PM |
