Does anyone know where I might find enough Douglas Fir suitable for
use for spars for the Woodstock 12 meter wing? I need pieces in the 12ft range. Does anyone know where I can have these spars made if I dont want to do them myself? This project doesnt go very far without spars! |
On Jun 21, 4:41 am, MartyH wrote:
Does anyone know where I might find enough Douglas Fir suitable for use for spars for the Woodstock 12 meter wing? I need pieces in the 12ft range. Does anyone know where I can have these spars made if I dont want to do them myself? This project doesnt go very far without spars! You might do a search on VG Fir (vertical grain). There's still some good stuff coming out British Columbia. http://www.vgfir.ca/ Best of luck with your project, Craig |
Does anyone know where I might find enough Douglas Fir suitable for use for spars for the Woodstock 12 meter wing? I need pieces in the 12ft range. Does anyone know where I can have these spars made if I dont want to do them myself? This project doesnt go very far without spars! P.S. you may want to avoid telling them it's for an airplane. This tends to send up everyone's liability antenna and they might refuse to supply material if they know it's going into a glider. |
![]() MartyH wrote: Does anyone know where I might find enough Douglas Fir suitable for use for spars for the Woodstock 12 meter wing? I need pieces in the 12ft range. Does anyone know where I can have these spars made if I dont want to do them myself? This project doesnt go very far without spars! One group that still uses long lengths of Douglas Fur is the sailboat industry. Try M.L.Condon Lumber, I have obtained long lengths of both high quality fur and spruce from them. I am sure there are other boat suppliers - check in Wooden Boat magazine for advertisements. Harry L. Clayton |
Does anyone know where I might find enough Douglas Fir suitable for use for spars for the Woodstock 12 meter wing? I need pieces in the 12ft range. Does anyone know where I can have these spars made if I dont want to do them myself? This project doesnt go very far without spars! A few things to try: See if the plans include a notation about substituting spruce for doug fir. The spruce is a bit lighter and a bit weaker by volume, but I've seen several plans sets that show spar cap sizes for both spruce and doug fir so you can choose based on what's available in your area. The spruce is pricey, but you can get it from Aircraft Spruce and Specialty and Wicks. For a first-time builder, that's a good option for peace of mind. Have a look at R.S. Hoover's blog for good tips about getting usable aircraft-grade wood from (I'm not kidding) big box stores like Home Despot and Lowes. Note that he's mostly interested in shorter chunks for cheap puddle-jumping Chugger airplanes, but the same general principles apply. It could be that you can do that sort of thing with a few scarf splices: http://bobhooversblog.blogspot.com/ Try your question on the rec.aviation.homebuilt usenet newsgroup. There's at least a few folks there plugged into the wood supply situation. Welcome to the awkward overlap between r.a.h and r.a.s common to all sailplane homebuilders on the Internet. Join the HomeSail forum on YahooGroups and ask your question the http://groups.yahoo.com/group/HomeSail See where builders of Dan Rihn's One Design and DR109 aerobatic airplanes get their doug fir. As for having the spars made by someone else, I would try to dissuade you from that. It's not rocket science, and if you build the tail surfaces first you will have all the skills and tools you need by the time you get to the spars. If someone else builds them, you're just paying someone else to have your fun for you. Further, my recommendation are to stick with the 12m wings, build fast and light, and don't worry too much about the aesthetics of the stuff on the inside. Good luck! Thanks, and best regards Bob K. http://www.hpaircraft.com/hp-24 |
On Jun 21, 10:25 am, Bob Kuykendall wrote:
On Jun 21, 4:41 am, MartyH wrote: Does anyone know where I might find enough Douglas Fir suitable for use for spars for the Woodstock 12 meter wing? I need pieces in the 12ft range. Does anyone know where I can have these spars made if I dont want to do them myself? This project doesnt go very far without spars! A few things to try: See if the plans include a notation about substituting spruce for doug fir. The spruce is a bit lighter and a bit weaker by volume, but I've seen several plans sets that show spar cap sizes for both spruce and doug fir so you can choose based on what's available in your area. The spruce is pricey, but you can get it from Aircraft Spruce and Specialty and Wicks. For a first-time builder, that's a good option for peace of mind. Have a look at R.S. Hoover's blog for good tips about getting usable aircraft-grade wood from (I'm not kidding) big box stores like Home Despot and Lowes. Note that he's mostly interested in shorter chunks for cheap puddle-jumping Chugger airplanes, but the same general principles apply. It could be that you can do that sort of thing with a few scarf splices: http://bobhooversblog.blogspot.com/ Try your question on the rec.aviation.homebuilt usenet newsgroup. There's at least a few folks there plugged into the wood supply situation. Welcome to the awkward overlap between r.a.h and r.a.s common to all sailplane homebuilders on the Internet. Join the HomeSail forum on YahooGroups and ask your question the http://groups.yahoo.com/group/HomeSail See where builders of Dan Rihn's One Design and DR109 aerobatic airplanes get their doug fir. As for having the spars made by someone else, I would try to dissuade you from that. It's not rocket science, and if you build the tail surfaces first you will have all the skills and tools you need by the time you get to the spars. If someone else builds them, you're just paying someone else to have your fun for you. Further, my recommendation are to stick with the 12m wings, build fast and light, and don't worry too much about the aesthetics of the stuff on the inside. Good luck! Thanks, and best regards Bob K.http://www.hpaircraft.com/hp-24 A few years ago, someone was looking at using the pultruded carbon rods for the spar caps on the Woodstock. I wonder if that went anywhere. It would seem an interesting adaption, especially with spruce. Frank Whiteley |
On Jun 21, 9:34 am, Frank Whiteley wrote:
A few years ago, someone was looking at using the pultruded carbon rods for the spar caps on the Woodstock. I wonder if that went anywhere. It would seem an interesting adaption, especially with spruce. I've heard rumors to that effect, but nothing solid. It sounds like a good idea to me, and I know how I'd do it, but I don't know where I'd find the time to get it done. Thanks, Bob K. |
Does anyone know where I might find enough Douglas Fir suitable for use for spars for the Woodstock 12 meter wing? I need pieces in the 12ft range. Does anyone know where I can have these spars made if I dont want to do them myself? This project doesnt go very far without spars! yes, contact Bill Scheunemann at that's Bill at woodwings.com He has the best Douglas Fir I've ever seen and has plenty of it. He can also mill the boards per your plans at a very resonable price. Good luck, Dan Rihn Rihn Aircraft Corp. |
Does anyone know where I might find enough Douglas Fir suitable for use for spars for the Woodstock 12 meter wing? I need pieces in the 12ft range. Does anyone know where I can have these spars made if I dont want to do them myself? This project doesnt go very far without spars! Try Pete Plumb, Woodwing Specialty, 330 Aviation Street, Shafter, CA 93263. E-mail: wood()wing()doc(at)yahoo.com. Phone 661-391-9464 and remove the () |
On Jun 21, 12:25 pm, Bob Kuykendall wrote:
On Jun 21, 4:41 am, MartyH wrote: Does anyone know where I might find enough Douglas Fir suitable for use for spars for the Woodstock 12 meter wing? I need pieces in the 12ft range. Does anyone know where I can have these spars made if I dont want to do them myself? This project doesnt go very far without spars! A few things to try: See if the plans include a notation about substituting spruce for doug fir. The spruce is a bit lighter and a bit weaker by volume, but I've seen several plans sets that show spar cap sizes for both spruce and doug fir so you can choose based on what's available in your area. The spruce is pricey, but you can get it from Aircraft Spruce and Specialty and Wicks. For a first-time builder, that's a good option for peace of mind. Have a look at R.S. Hoover's blog for good tips about getting usable aircraft-grade wood from (I'm not kidding) big box stores like Home Despot and Lowes. Note that he's mostly interested in shorter chunks for cheap puddle-jumping Chugger airplanes, but the same general principles apply. It could be that you can do that sort of thing with a few scarf splices: http://bobhooversblog.blogspot.com/ Try your question on the rec.aviation.homebuilt usenet newsgroup. There's at least a few folks there plugged into the wood supply situation. Welcome to the awkward overlap between r.a.h and r.a.s common to all sailplane homebuilders on the Internet. Join the HomeSail forum on YahooGroups and ask your question the http://groups.yahoo.com/group/HomeSail See where builders of Dan Rihn's One Design and DR109 aerobatic airplanes get their doug fir. As for having the spars made by someone else, I would try to dissuade you from that. It's not rocket science, and if you build the tail surfaces first you will have all the skills and tools you need by the time you get to the spars. If someone else builds them, you're just paying someone else to have your fun for you. Further, my recommendation are to stick with the 12m wings, build fast and light, and don't worry too much about the aesthetics of the stuff on the inside. Good luck! Thanks, and best regards Bob K.http://www.hpaircraft.com/hp-24 To respond to a bunch of what you said, first, I am not a first time builder and a lot of the wood for my Horizon 2 came from the big box stores. White pine and Douglas Fir for example. No, I cannot substitute for the Douglas Fir in the spars. The plans are clear that Spruce is NOT a satisfactory substitute. I intend to build the 12 meter wings. There is VERY LITTLE data about the 13 meter wings and even though I have the 13 meter plans and construction manual, I wouldn't touch that with a 10 ft. pole. I think contacting the sailboat people might not be a bad idea. Thank you! |
Woodstock Plans | [email protected] | Soaring | 4 | August 10th 06 11:11 PM |
Query on the Woodstock | Stealth Pilot | Soaring | 3 | July 25th 06 08:02 PM |
Woodstock Plans F/S | [email protected] | Soaring | 0 | May 16th 05 10:06 PM |
Titanium spars and composites on F-22 | Scott Ferrin | Military Aviation | 1 | December 4th 03 03:21 PM |
S-H Spars: Anyone check for voids laterally? | Mark Grubb | Soaring | 1 | September 20th 03 04:27 AM |
