Does anybody know the diameter of the Pegasus rudder cables? Will
eighth-inch work? Thanks, Bill |
On Jun 22, 6:20 pm, Bill wrote:
Does anybody know the diameter of the Pegasus rudder cables? Will eighth-inch work? Thanks, Bill Yes JJ |
"JJ Sinclair" wrote in message
ps.com... On Jun 22, 6:20 pm, Bill wrote: Does anybody know the diameter of the Pegasus rudder cables? Will eighth-inch work? Yes Thanks much. -- Posted via NewsDemon.com - Premium Uncensored Newsgroup Service -------http://www.NewsDemon.com------ Unlimited Access, Anonymous Accounts, Uncensored Broadband Access |
Hmmm. Yes, I know the cable size? Or, yes, one eighth inch will work? It made me wonder why the removed/removing/extant cable size hadn't been measured. But sometimes I have a way too logical moment to really be blonde. By the way JJ, congrats on racing that US design to a high placing finish. Best to all, Cindy B On Jun 24, 10:27 am, "El Alumbrado" wrote: "JJ Sinclair" wrote in message Yes Thanks much. -- |
"CindyASK" wrote in message
oups.com... Hmmm. Yes, I know the cable size? Or, yes, one eighth inch will work? It made me wonder why the removed/removing/extant cable size hadn't been measured. But sometimes I have a way too logical moment to really be blonde. It's not you being blonde, it's me not telling the whole story. The airplane and I were not co-located, making measuring problematical. I was guessing 1/8th inch 7x19, but wanted to order some cable ASAP, so I thought I'd ask my friends and neighbors for confirmation. Hope you don't mind. Thanks, Bill -- Posted via NewsDemon.com - Premium Uncensored Newsgroup Service -------http://www.NewsDemon.com------ Unlimited Access, Anonymous Accounts, Uncensored Broadband Access |
By the way JJ, congrats on racing that US design to a high placing finish. Best to all, Cindy B Thanks Cindy, It was a good race with good tasking, like Bishop-Basalt and Mammouth- Mina, even called Independance with a circle one day. On the last day it was blowing like stink, 30 knots at 10K. The bat-wing just couldn't penetrate as fast as the heavy Ventus-2 CM, so my speed wasn't enough to hold on to first place. Got me fored up and I'm still hoping to get into Parowan, may even try to make it down to Hobbs. Best regards, JJ |
Just be aware that the "new" rudder pedals for the AD have a plastic sleeve
that is slightly smaller in diameter than the old one, so the cable may not slide through it easily when adjusting the pedals, and may pull the sleeve out of the "S" tubing. Gotta love these rudder AD's. Doug "JJ Sinclair" wrote in message ps.com... On Jun 22, 6:20 pm, Bill wrote: Does anybody know the diameter of the Pegasus rudder cables? Will eighth-inch work? Thanks, Bill Yes JJ |
"Doug" wrote in message
. .. Just be aware that the "new" rudder pedals for the AD have a plastic sleeve that is slightly smaller in diameter than the old one, so the cable may not slide through it easily when adjusting the pedals, and may pull the sleeve out of the "S" tubing. Gotta love these rudder AD's. Thanks for the tip. I've got to believe it's safer to leave the existing bits in place than go monkeying about installing new pedals and cables. How hard do you have to stomp on the pedals to crack them, anyway? I suspect I could beat the old pedals with a hammer for a few hours with no ill effect. -- El Alumbrado Tempus Fugit, Memento Mori -- Posted via NewsDemon.com - Premium Uncensored Newsgroup Service -------http://www.NewsDemon.com------ Unlimited Access, Anonymous Accounts, Uncensored Broadband Access |
I suspect I
could beat the old pedals with a hammer for a few hours with no ill effect. In an accident, like a high speed ground-loop, the pilot may end up more or less standing on the rudder pedals. I have seen cracked rudder pedals where there was no damage to the nose of the glider.......................I suspect this was the issue that lead to this AD. JJ |
In our case, there was a small crack starting on one of the rudder pedals at
the weld. The area actually looked slightly compressed as though it had been squeezed in a vise. Still, it would have taken a mighty heavy foot to actually break it. I suspect a vertical nose down landing, ouch, would have accomplished that. I wish we could have just welded on a reinforcing plate, like they did on the new pedals, to solve the problem because the new pedals are narrower and much more uncomfortable to use. Doug "JJ Sinclair" wrote in message oups.com... I suspect I could beat the old pedals with a hammer for a few hours with no ill effect. In an accident, like a high speed ground-loop, the pilot may end up more or less standing on the rudder pedals. I have seen cracked rudder pedals where there was no damage to the nose of the glider.......................I suspect this was the issue that lead to this AD. JJ |
| New PDA data cables for EW microRecorder | Paul Remde | Soaring | 0 | January 4th 07 09:31 PM |
| FS: Piper Booster cables | Ottprivatesale | Owning | 0 | July 11th 06 05:36 AM |
| unsticking cables | dlevy | Owning | 12 | January 8th 06 10:39 AM |
| MiG-29 cables | alcatraz | Military Aviation | 0 | March 1st 04 11:01 PM |
| Control cables for gliders | mike maskell | Soaring | 10 | January 1st 04 06:08 AM |
