Hobbs
Old July 3rd 07, 03:00 PM posted to rec.aviation.piloting
Gig 601XL Builder
Default Hobbs
B A R R Y wrote:
Orval Fairbairn wrote:
Sometimes, unscrupulous owners will wire the Hobbs to the master
switch, so you get charges whenever the MS is ON.
My Hobbs is on the master, but the airplane has never been rented.
Which brings up a very interesting question. I'm building a plane that will
be licensed as an Experimental. Once inspected I'll have to test fly for 40
hours for phase one. If I use a Hobbs as the official time and hook it to
the MS I would probably end up reducing the phase one time considerably.
Old July 3rd 07, 04:03 PM posted to rec.aviation.piloting
B A R R Y[_2_]
Default Hobbs
That is interesting. Does the FAA specify tach vs. oil pressure Hobbs,
vs. electric Hobbs?
Think of how many pilot logbooks are based on electric Hobbs time.
Old July 3rd 07, 05:21 PM posted to rec.aviation.piloting
Gig 601XL Builder
Default Hobbs
that will be licensed as an Experimental. Once inspected I'll have
to test fly for 40 hours for phase one. If I use a Hobbs as the
official time and hook it to the MS I would probably end up reducing
Hobbs, vs. electric Hobbs?
I can't think of a single second in my log book that isn't based on Hobbs
time. Some were oil pressure activated but the vast majority were MS
activated.
Old July 3rd 07, 06:44 PM posted to rec.aviation.piloting
B A R R Y[_2_]
Default Hobbs
activated.
Me too.
Old July 3rd 07, 07:11 PM posted to rec.aviation.piloting
Robert M. Gary
Default Hobbs
On Jul 2, 12:31 pm, Orval Fairbairn wrote:
B A R R Y wrote:
Larry R wrote:
Ok, I am *almost* embarrased to ask this question, but here goes. Do
Hobbs meters ever "go bad"?
Sure, it's a mechanical device.
On two occasions over the last few years, my Hobbs has failed to move.
For this reason, I always note my tach time and time off. The extra
start numbers will help just in case I don't notice for a while that the
Hobbs isn't running, and I need to have a fuel consumption figure.
Sometimes, unscrupulous owners will wire the Hobbs to the master switch,
My hobbs is wired to the master. Am I unscrupulous somehow??? What
would be the reason for someone to sit so long with the master on and
the engine not running?
-Robert
Old July 3rd 07, 07:26 PM posted to rec.aviation.piloting
B A R R Y[_2_]
Default Hobbs
Apparently the minute and a half (or less) that it takes you (and I) to
do the "electric loop" during preflight is flogging logs. G
At least in my case, I flip the switch, check the fuel pressure and
guages, do the lights / strobes / pitot heat / stall horn walk-around
checks, and turn it back off. That's pretty much it without the engine
running.
  #28
Old July 3rd 07, 09:45 PM posted to rec.aviation.piloting
Dave S
Default Hobbs
will be licensed as an Experimental. Once inspected I'll have to test
fly for 40 hours for phase one. If I use a Hobbs as the official time
and hook it to the MS I would probably end up reducing the phase one
time considerably.
vs. electric Hobbs?
If I understand, the stipulated value is "flight time". Not ground time.
Not hobbs time, not engine time.. nor master switch time.
But the feds are also taking it on the honor system that you will not
tie it down and let it run up 40 (or 25) hours on the ground, then sign
off phase 1.
My particular install has an engine monitor that records hobbs time,
when the engine is operating, and flight time, when the ASI is above 30 mph.
Dave
  #29
Old July 4th 07, 12:32 AM posted to rec.aviation.piloting
Robert M. Gary
Default Hobbs
running.
Yes. even when I'm flying the glass cockpit planes I don't think I
have the master on without the engine running for more than a couple
of minutes. I don't think it would be a good idea to sit there with
the master on for long periods. Seems like the smart FBO would wire
the hobbs to the master to prevent people from running the battery for
no reason.
  #30
Old July 4th 07, 12:53 AM posted to rec.aviation.piloting
Travis Marlatte
Default Hobbs
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message
will be licensed as an Experimental. Once inspected I'll have to test fly
for 40 hours for phase one. If I use a Hobbs as the official time and hook
it to the MS I would probably end up reducing the phase one time
considerably.
Maybe. At what RPM is your tach even with elapsed time?
All of the rentals and the only plane I have owned turn the tach faster than
elapsed time at higher RPM. (By the way, what do you call the counter thingy
in a tach?) My max RPM is 2650. I have to bring it back to around 2350 to be
even with elapsed time. That happens to be at the top of a restricted zone
so I would never be at an advantage using Hobbs to log flight time unless I
spent most of the flight idling around the airport.
I happened to do most of my renting from a club that charged by the tach
time. Everyone thought that was great - and maybe it was for students who do
less cruising - but the tach time was always more than elapsed for my
weekend trips.
Is there some specficiation or reg as to what RPM equals elapsed time? If
you're renting, fly slower. You'll log more hours cheaper. If your test
flying, fly faster. You'll chew up more tach time per elapsed hour.
Travis
Lake N3094P
PWK
fwd: For Hobbs Jack Soaring 9 November 26th 06 05:28 AM
Hampton Inn Hobbs, NM Kilo Charlie Soaring 5 July 10th 04 02:03 AM
Hobbs Day 5 7-08 # 711. TomnKeyLargo Soaring 2 July 9th 04 04:14 AM
Hobbs Day 2 7-05-04 TomnKeyLargo Soaring 0 July 6th 04 05:24 AM
LS8-18 FS after Hobbs (USA) SAM AND LEIGH ZIMMERMAN Soaring 1 April 5th 04 12:43 PM
