I'm sure this was discussed for a while after it happened...I wanted
	to bring this up again...I was just reading an article that I came across explaining how Corey Lidle's crash into a Manhattan Building could have happened. Some people say it was mechanical failure, others say it because he flew into a cloud...So i started thinking about it and I came up with this explanation: The east river is a very narrow corridor. Continuing flight north would put him in LaGuardia Airspace. To Avoid the airspace Lidle needed to make a 180 degree turn back. Since the East River is so narrow a turn of 30 or more degrees would probably be needed to avoid flying over Manhattan. Once you bank an airplane over 30 degrees, you would no longer see the tops of any building. Your line of sight would be towards the bottom of the building. He probably didn't even bother looking to the left to see if there are any obstacles before starting the turn. He also probably didn't realize that his rate of turn wasn't quick enough to avoid the building until it was too late. Is this a possible explanation or am I completely wrong here? Felix  |
			 "Felix" wrote: Some people say it was mechanical failure, others say it because he flew into a cloud... Who says that? What mechanical failure? What cloud? He also probably didn't realize that his rate of turn wasn't quick enough to avoid the building until it was too late. Is this a possible explanation or am I completely wrong here? That appears to be what happened, but not because he wasn't looking. Most likely he ran out of room in the turn because of the crosswind that was pushing the ground track of the airplane towards the buildings. -- Dan T-182T at BFM  |
The article said that it might have been mechanical failure, or he
	flew into a cloud and got disoriented. It was an old article I suppose. I always avoid flying down the East River, it's just too narrow. Even the Hudson River needs a large bank when making a 180 after the George Washington Bridge. On Jul 13, 3:09 pm, "Dan Luke" wrote: "Felix" wrote: Some people say it was mechanical failure, others say it because he flew into a cloud... Who says that? What mechanical failure? What cloud? He also probably didn't realize that his rate of turn wasn't quick enough to avoid the building until it was too late. Is this a possible explanation or am I completely wrong here? That appears to be what happened, but not because he wasn't looking. Most likely he ran out of room in the turn because of the crosswind that was pushing the ground track of the airplane towards the buildings. -- Dan T-182T at BFM  |
Felix wrote:
	I'm sure this was discussed for a while after it happened...I wanted to bring this up again...I was just reading an article that I came across explaining how Corey Lidle's crash into a Manhattan Building could have happened. Some people say it was mechanical failure, others say it because he flew into a cloud...So i started thinking about it and I came up with this explanation: The east river is a very narrow corridor. Continuing flight north would put him in LaGuardia Airspace. To Avoid the airspace Lidle needed to make a 180 degree turn back. Since the East River is so narrow a turn of 30 or more degrees would probably be needed to avoid flying over Manhattan. Once you bank an airplane over 30 degrees, you would no longer see the tops of any building. Your line of sight would be towards the bottom of the building. He probably didn't even bother looking to the left to see if there are any obstacles before starting the turn. He also probably didn't realize that his rate of turn wasn't quick enough to avoid the building until it was too late. Is this a possible explanation or am I completely wrong here? Felix You are probably exactly right. At in the wind that was there and you are even more right. There has been no evednce that there was a mechanical failure and I never even hear the cloud theory. If it were true it would still me pilot error.  |
"Dan Luke"  wrote:
	Is this a possible explanation or am I completely wrong here? That appears to be what happened, but not because he wasn't looking. Most likely he ran out of room in the turn because of the crosswind that was pushing the ground track of the airplane towards the buildings. I am not familiar with the buildings but had he flown around the one he hit he might have been fine. He could have flown along the west side and turned right (if appropriate). He could have talked to ATC and been cleared into a bit of airspace he tried to avoid. He could have started the turn from the east side of the river and banked steeper. Bottom line: He screwed up. Ron Lee  |
Ron Lee wrote:
	Bottom line: He screwed up. Therefo sue the manufacturer of the airplane, the FAA, the family of the instructor that was with him and the owner of the building that he hit.  |
			 "kontiki" wrote in message ... Ron Lee wrote: Bottom line: He screwed up. Therefo sue the manufacturer of the airplane, the FAA, the family of the instructor that was with him and the owner of the building that he hit. Everybody take a dollar out of their wallet and pass it to the left. Take the dollar from the person to the right and put it in your wallet. Corey Lidle and the instructor are still dead, and a bunch of money got shuffled around. The only difference is, a bunch of lawyers didn't take it all. -c  |
	"Felix" wrote in message oups.com... ... Once you bank an airplane over 30 degrees, you would no longer see the tops of any building. Your line of sight would be towards the bottom of the building. ... HUH??? Since when? Perhaps in a simulator where you only have a little screen to look at... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate  |
("Felix" wrote)
	Is this a possible explanation or am I completely wrong here? My take on this crash is: If they could have a do-over ...at the moment they decided to turn around, they would choose (this time) to bust the airspace, and write up a NASA form later. I think they got a little behind the situation, decided NOT to bust ANY of the airspace around them, and things went south from there. Paul-Mont  |
"Montblack"  wrote in message
	... ("Felix" wrote) Is this a possible explanation or am I completely wrong here? My take on this crash is: If they could have a do-over ...at the moment they decided to turn around, they would choose (this time) to bust the airspace, and write up a NASA form later. I think they got a little behind the situation, decided NOT to bust ANY of the airspace around them, and things went south from there. Paul-Mont That pretty much sums up all that we really know. The report(s) can be found at http://www.ntsb.gov/ntsb/query.asp by typing in the registration number N929CD and selecting any or each of the three reports. However, none depict any reconstrucion of the exact flight path--so all that can really be said is that your solution, advanced by many of us at the time, would have worked. Peter  |
| MLBPA Insurance, The Lidle Crash & A Closet Full of Suits | PPL-A (Canada) | Piloting | 5 | May 17th 07 03:25 AM |
| Recent C421 crash is related to Cory Lidle | jbskies | Piloting | 5 | December 5th 06 02:48 PM |
| More journalistic delirium about the Lidle crash | Greg Farris | Piloting | 3 | November 28th 06 07:07 AM |
| Winds A Factor In Lidle Crash | Larry Dighera | Piloting | 72 | November 10th 06 09:43 PM |
| Lidle crash: who is wrong? | Blasto | Piloting | 57 | October 20th 06 09:05 AM |
