Alloys for certified parts?
Old July 31st 07, 05:28 AM posted to rec.aviation.homebuilt
Default Alloys for certified parts?
I have run across someone who insists that
6061 T6 is not "aircraft grade aluminum".
He claims that there are no certified parts made
from 6061. I find that hard to believe. Aren't there
certified aircraft with welded aluminum frames?
FF
Old July 31st 07, 03:40 PM posted to rec.aviation.homebuilt
That is a pretty broad statement.
Parts are made from any materials that the manufacturer
desires/specifies. Wood, aluminum, brass, glass and anything in between.
That includes 6061 of all tempers.
That is kinda what I thought. I'd like to find some specific examples
of certified aircraft parts made from 6061. I took a gander at
Aircraft
Spruce's online catalog, but the search function isn't set up for
that.
I'm thinking that certified metal props will probably be 6061 too.
FF
Old July 31st 07, 05:26 PM posted to rec.aviation.homebuilt
On Jul 31, 2:30 pm, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
FF
The LSA certified Zeniths are 6061-T6.
Aha!.
I see that Aircraft Manufacturing & Development Co. (AMD)
sells FAA certified SLSA Zodiacs.
FF
Old August 1st 07, 04:52 AM posted to rec.aviation.homebuilt
Phil
I worked for one of the major A/C manufactures and they used 6061 for
several welded assemblies including the nosewheel fork , they formed the
parts cold and we pre-heated and welded the assemblies and they were sent
out for heat treat to bring the parts back to the T6 condition or about 35 K
Tensel , I can't ever remember seeing a piece of alum. or steel that said
aircraft on it , a Mil. spec no. might be stenciled on sheet , most
structural alum. used in A/C construction is 2024-T3 . Phil L.
ps.com...
FF
Old August 1st 07, 12:12 PM posted to rec.aviation.homebuilt
Vaughn Simon
ps.com...
While I believe you are on the winning side in your argument about aircraft
materials, the Zodiac may not be the best example to prove your point. As an
LSA, tt is certified to an industry standard, not an FAA standard. I recently
checked out in one and it even has a "warning" in the cockpit to that effect.
Vaughn
Old August 1st 07, 02:17 PM posted to rec.aviation.homebuilt
Morgans[_2_]
aircraft materials, the Zodiac may not be the best example to prove your
point. As an LSA, tt is certified to an industry standard, not an FAA
standard. I recently checked out in one and it even has a "warning" in
Yes, BUT don't let that warning read with too much meaning, either.
The warning is there, just as the warning in experimentals. It reads that
this aircraft does not meet the qualifications of FAA certified aircraft, or
something like that. I'm sure most of you remember exactly what that says.
It should be noticed that while it has not been compared directly to the FAA
standards, there are many, many homebuilts that far exceed the FAA
standards. Some of the quality in homebuilts make certified aircraft look
like erector set airplanes, in comparison. g
Jim in NC
Non-certified parts for a certified plane? Dico Owning 10 August 22nd 06 04:11 AM
"certified' parts Jimmy B. Owning 51 March 18th 05 07:04 PM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 06:36 PM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Home Built 0 January 10th 04 03:20 AM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Aviation Marketplace 0 January 10th 04 03:20 AM
