On Aug 6, 1:56 am, wrote
Someone mentioned secondary surveillance. This is mode-s. It is also on 1030/1090Mhz. However, the reply from the transponder is more detailed. It contains a unique code for each aircraft. The older transponders simply return the squawk code that was assigned by ATC and entered by the pilot. Some mode-s can return airspace and location. http://mit.edu/6.933/www/Fall2000/mo...sb.tc.faa.gov/ Secondary radar is the term for any transponder mode radar--A, C or S. |
On Aug 5, 4:43 pm, "Danny Deger" wrote:
In another thread I am in a discussion on radar capability for FAA "Centers". My recollection is that they typically have no primary radar, thus no capability to paint weather. Someone is telling me they do. Anybody out there have the answer. Maybe some do and some don't, and the ones I used in the past don't. -- Danny Deger NASA offered me $15,000 to take down my web site. Take a look and see why.www.dannydeger.net FAA Centers do have the capability to paint primary targets. The quality of radar coverage for primary targets is somewhat spotty. A primary may or may not be painted depending on a lot of different circumstances. Weather affects this capability too. Since we do have primary capability, it can paint flocks of birds, weather, non- transponder equipped planes, etc. We have recently gotten an upgrade to our scopes that allows better weather depiction. Previously weather depiction was very inaccurate. Our radar antennas turn at a speed twice that or normal weather radar so our depiction used to be very poor. I am an air traffic controller - 27+ years. |
"BT" wrote in message
... what was the altitude.. where you below the "radar horizon" for the range from the antenna? Was the "target aircraft" in a "blind radar area for the altitude" based on a close in obstruction such as earth or building? Good question, but wouldn't the things you talk about affect the secondary radar as well. They were out over the Atlantic Ocean in a miltary Warning Area under the control of Washington Center. After the acident, we were all briefed if we lost our transponder Washington Center could not paint us. Apparently this is not true for Centers in general. Maybe it had to do with Washington Center's radar coverage out over the Atlantic. You can read the details in my free book you can get at my web site www.dannydeger.net. Look on page 31. I have lots of other good flying stories in the book you might enjoy. Danny Deger B "Danny Deger" wrote in message ... "Bob" wrote in message ... On Sun, 5 Aug 2007 15:43:29 -0500, "Danny Deger" wrote: In another thread I am in a discussion on radar capability for FAA "Centers". My recollection is that they typically have no primary radar, thus no capability to paint weather. Someone is telling me they do. Anybody out there have the answer. Maybe some do and some don't, and the ones I used in the past don't. "FAA Primary En Route Long Range Radar Restructuring Program The FAA currently uses and supports 126 primary en route radar facilities. The FAA is chartered to provide Primary radar services to all federal agencies requiring this data to meet their operational missions." http://www.faa.gov/asd/ia-or/longrangeradar.htm Thanks for the link. I found it very useful. I think my confusion comes from an accident where a friend of mine died because Washington Center lost radar contact when he lost his transponder. He was out over the ocean in a warning area. We were briefed Washington Center had no ability to skin paint. I am starting to realize this probably had to do only with this situation of being over the ocean in a warning area and Centers in general have skin paint capable radars. If anyone is interested in the details of this fatal flight, I put them in my book, "Houston, You Have a Problem" and you can get it for free at www.dannydeger.net Danny Deger |
On Aug 6, 1:56 am, wrote:
Someone mentioned secondary surveillance. This is mode-s. It is also on 1030/1090Mhz. However, the reply from the transponder is more detailed. It contains a unique code for each aircraft. The older transponders simply return the squawk code that was assigned by ATC and entered by the pilot. Some mode-s can return airspace and location. http://mit.edu/6.933/www/Fall2000/mo...sb.tc.faa.gov/ Secondary "radar" is any type of system where the target is an active particpant in the radio direction and ranging system. In the US civil airways system this can be mode a/c/s and it is all the same (more or less) technical description... aka the main Secondary system sends out an interrogation pulse on one frequency and the target replies on another. The times are measured (ie time main pulse went out and secondary pulse recieved) and hence range is achieved. Direction is based on the pointing of the primary interrogator. "Beacon" Antennas are commonly (but not always) co located with main primary radar...they will generally be the "flat" rectangle on top of the main (larger) antenna. They can stand alone...and that is common in places like Canada and Austrailia...they require far less power then primary or skin paint radars. Beacon (ie secondary radar) was a US invention in WWII...It was called "IFF" identification friend or foe". What seperates a primary radar for ATC and one for WX are the characteristics of the radar. Frequency is important but more so are pulse repetition rate (PRR), polarization, and antenna rotation rate. Most people think that there is one "echo returned" from a target...this is not correct. The PRR and antenna rotation rate are designed to maximise the number of "Paints" of a target on a particular sweep. Robert |
On Aug 6, 8:30 am, ATControlr wrote:
On Aug 5, 4:43 pm, "Danny Deger" wrote: In another thread I am in a discussion on radar capability for FAA "Centers". My recollection is that they typically have no primary radar, thus no capability to paint weather. Someone is telling me they do. Anybody out there have the answer. Maybe some do and some don't, and the ones I used in the past don't. -- Danny Deger NASA offered me $15,000 to take down my web site. Take a look and see why.www.dannydeger.net FAA Centers do have the capability to paint primary targets. The quality of radar coverage for primary targets is somewhat spotty. A primary may or may not be painted depending on a lot of different circumstances. Weather affects this capability too. Since we do have primary capability, it can paint flocks of birds, weather, non- transponder equipped planes, etc. We have recently gotten an upgrade to our scopes that allows better weather depiction. Previously weather depiction was very inaccurate. Our radar antennas turn at a speed twice that or normal weather radar so our depiction used to be very poor. I am an air traffic controller - 27+ years. You seem amazingly lucid for having been a controller for almost 30 years. Congratulations. I would have blown a fuse in about 2 days! Robert |
I would like thank everybody for all of the information. I have made
changes to my book to reflect Centers in general have skin paint capability. There must be something unique about Washington Center's radar out over the Atlantic Ocean Warning Areas that prevented them from getting a skin paint on my friend's F-4. The short summary of my friend's fatal flight is: he lost all electrical power and decided to rejoin on another F-4 in the warning area. The lights he picked out were not an F-4, but an airliner out over the ocean headed to Miami (we were off the coast of North Carolina). By the time they realized their mistake, they didn't have enough fuel to get back to land and ended up bailing out in the ocean. 6 days later a fishing trawler picked up the back seater and the front seater was never found. Without a skin paint, the search and rescue forces looked in the wrong place. More details in my book you can get for free from my web site. Feel free to download and email to your friends. -- Danny Deger NASA offered me $15,000 to take down my web site. Take a look and see why. www.dannydeger.net |
On Aug 6, 11:34 am, "Danny Deger" wrote:
I would like thank everybody for all of the information. I have made changes to my book to reflect Centers in general have skin paint capability. There must be something unique about Washington Center's radar out over the Atlantic Ocean Warning Areas that prevented them from getting a skin paint on my friend's F-4. The short summary of my friend's fatal flight is: he lost all electrical power and decided to rejoin on another F-4 in the warning area. The lights he picked out were not an F-4, but an airliner out over the ocean headed to Miami (we were off the coast of North Carolina). By the time they realized their mistake, they didn't have enough fuel to get back to land and ended up bailing out in the ocean. 6 days later a fishing trawler picked up the back seater and the front seater was never found. Without a skin paint, the search and rescue forces looked in the wrong place. More details in my book you can get for free from my web site. Feel free to download and email to your friends. -- Danny Deger NASA offered me $15,000 to take down my web site. Take a look and see why.www.dannydeger.net Danny I would add this "thing" ...it might not be all that unique. it just might be "how it is"...for all centers. The SSR range for a "radar" is (because of the active particpant) must longer then skin paint. I dont know what year it was, but the "computer" system probably rejected the target in part because of some "angle" issues (ie two systems were painting it and it fell out of a "cell" ie both radars present information to the computer and the computer gets confused because it cannot corelate teh target(s) and just drops the target). On 9/11 when the airlines went "primary" it was only some really quick thinking by the folks at NY center that held them as targets. The sad thing (different topic) is that more or less the FAA worked "as advertised" on 9/11. They were about the only one. Robert |
Danny Deger wrote: In another thread I am in a discussion on radar capability for FAA "Centers". My recollection is that they typically have no primary radar, thus no capability to paint weather. There is no connection whatever between 'primary radar' and 'weather radar'. The ability to detect storm clouds is related purely to the wavelength of the radar transmission. A radar that was swamped by cloud returns would be utterly useless as a primary radar ! Graham |
In rec.aviation.piloting Danny Deger wrote:
I would like thank everybody for all of the information. I have made changes to my book to reflect Centers in general have skin paint capability. There must be something unique about Washington Center's radar out over the Atlantic Ocean Warning Areas that prevented them from getting a skin paint on my friend's F-4. Or the F-4 was too small to paint, or the radar was broken that day, or lots of other things could have been in play. Having spent more hours than I care to remember behind military air defense radar systems, I can say with some authority that a single fighter is tough for any radar to see at long ranges. -- Jim Pennino Remove .spam.sux to reply. |
In rec.aviation.piloting Eeyore wrote:
Danny Deger wrote: In another thread I am in a discussion on radar capability for FAA "Centers". My recollection is that they typically have no primary radar, thus no capability to paint weather. There is no connection whatever between 'primary radar' and 'weather radar'. The ability to detect storm clouds is related purely to the wavelength of the radar transmission. A radar that was swamped by cloud returns would be utterly useless as a primary radar ! Bzzzt, wrong answer. The ablility of radar to detect weather is related to frequency, antenna polarization, antenna sweep rate, type (as in pure pulse versus doppler) and signal processing (if any). Most search radar used for finding airplanes won't see ordinary clouds at all and are generally marginal for seeing precipitation unless you've put something in the design to do both. -- Jim Pennino Remove .spam.sux to reply. |
| FWD: Article "Logan to get radar to detect ships - Monitoring could improve flow of air traffic" | Jon | Piloting | 0 | April 18th 07 10:22 PM |
| FWD: Article "Logan to get radar to detect ships - Monitoring could improve flow of air traffic" | Jon | Instrument Flight Rules | 0 | April 18th 07 10:22 PM |
| Old polish aircraft TS-8 "Bies" ("Bogy") - for sale | >pk | Aviation Marketplace | 0 | October 16th 06 08:48 AM |
| "Are you worried about all those non-green colors on the radar?" | Peter R. | Instrument Flight Rules | 35 | May 26th 06 02:19 AM |
