Steve Fossett
Old September 7th 07, 02:51 AM posted to rec.aviation.soaring
Brian Milner
Default Steve Fossett
Does anyone know if the plane had a fixed ELT installed?
Old September 7th 07, 03:38 AM posted to rec.aviation.soaring
BT
FARs said it should have had one.
91.207, unless it was exempt according to 91.207 (f)(3), training operations
within 50nm of where training began.
BT
"Brian Milner" wrote in message
Old September 7th 07, 08:56 PM posted to rec.aviation.soaring
danlj
BT
Well, the alternatives in this situation are pretty simple:
A] No ELT signal has been detected, therefore perhaps
1: It failed to function (dead battery; destroyed in crash)
2: The aircraft did not experience an 'impact' strong enough to
activate it
3: Mr. Fossett did not or was unable to activate it manually.
B] No radio distress calls have been heard, therefore perhaps
4: The aircraft's battery was destroyed in the crash
5: The radios were destroyed in the crash
6: Mr. Fossett exited the airplane and was unable to return to it
(lost, incapacitated)
7: The battery shorted out.
8: Mr. Fossett has been incapacitated or had sudden cardiac death,
without a crash.
9: (hardly likely) Mr. Fossett has deliberately disappeared.
Or some combination (e.g., 2 + 6 -- landing on a dry lake that was
crusty, the wheels fell through; Mr. Fossett exited the aircraft to
investigate and fell through himself and was incapacitated thereby;
not very likely, especially in August)
But none of this helps find the airplane, a tough thing to do if it's
not on level ground.
DJ
Old September 8th 07, 08:26 AM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
Immersed in water?
Bagger
Steve Fossett missing? Rob Turk[_2_] Home Built 32 September 8th 07 12:53 AM
Steve Fossett [email protected] Owning 15 September 7th 07 08:45 PM
Steve Fossett - Missing [email protected] Soaring 18 September 6th 07 08:16 PM
Steve Fossett missing? Wayne Paul Soaring 0 September 6th 07 03:29 PM
