I use my A24 lots, for listening to ASOS, communicating to aircraft at
fly-ins, ordering fuel, etc... I rarely use it with a headset. The other night, I had a full-on comm failure and needed to use it while aloft, with a headset. It took me a few minutes to remember, but my radio keys only the radio's onboard mic when keyed with the onboard PTT, not the headset mic. To use it with a headset, I need to put the radio to my mouth and talk into the radio, the mic in the headset is not used. My adapter is a genuine Icom product, with phones, mic, and PTT connections. I'm only connected to the phones and mic jack. Can anyone confirm to me that an external PTT will in fact key the headset mic? My Googling has come up with lots of yeas and neahs in conflict. |
I have an older ICOM A22, my headset adapter includes both headset jacks and
a smaller 3mm plug for a PTT which I had to order for that size plug. Keying the 3mm PPT works the headset mic. I do not know if installing the headset adapter jacks to the A22 disables the radio's on board mic, I believe that it will because I also have the "speaker/mic" combination that I use in sail planes, clipping the speaker/mic to the seat belt and letting the radio sit beside. That connection disables the "on board" mic and it is the same style plug set for the headsets adapter. BT "B A R R Y" wrote in message ... I use my A24 lots, for listening to ASOS, communicating to aircraft at fly-ins, ordering fuel, etc... I rarely use it with a headset. The other night, I had a full-on comm failure and needed to use it while aloft, with a headset. It took me a few minutes to remember, but my radio keys only the radio's onboard mic when keyed with the onboard PTT, not the headset mic. To use it with a headset, I need to put the radio to my mouth and talk into the radio, the mic in the headset is not used. My adapter is a genuine Icom product, with phones, mic, and PTT connections. I'm only connected to the phones and mic jack. Can anyone confirm to me that an external PTT will in fact key the headset mic? My Googling has come up with lots of yeas and neahs in conflict. |
On Sun, 2 Sep 2007 14:42:06 -0700, "BT" wrote:
I have an older ICOM A22, my headset adapter includes both headset jacks and a smaller 3mm plug for a PTT which I had to order for that size plug. Keying the 3mm PPT works the headset mic. I do not know if installing the headset adapter jacks to the A22 disables the radio's on board mic, I believe that it will because I also have the "speaker/mic" combination that I use in sail planes, clipping the speaker/mic to the seat belt and letting the radio sit beside. That connection disables the "on board" mic and it is the same style plug set for the headsets adapter. Thanks, BT! The closest place I can get a proper PTT is ~ 30-40 minute one-way drive, your info makes it sound like it's worth my while. |
On Sun, 02 Sep 2007 19:56:50 GMT, B A R R Y
wrote: I use my A24 lots, for listening to ASOS, communicating to aircraft at fly-ins, ordering fuel, etc... I rarely use it with a headset. The other night, I had a full-on comm failure and needed to use it while aloft, with a headset. It took me a few minutes to remember, but my radio keys only the radio's onboard mic when keyed with the onboard PTT, not the headset mic. To use it with a headset, I need to put the radio to my mouth and talk into the radio, the mic in the headset is not used. My adapter is a genuine Icom product, with phones, mic, and PTT connections. I'm only connected to the phones and mic jack. Can anyone confirm to me that an external PTT will in fact key the headset mic? It does on my ICOM IC-A5, but the A5 connects to the radio with a single plug instead of the A24's double plug. But it looks like the adaptor for the A24 has the jack to plug in the PTT switch, same as my adaptor. One caution: The radio PTT switch will still work, but it will key both mikes. The adaptor PTT on my A5 only keys the headset mike. Ron Wanttaja |
A24,
headset adapter OPC-499 (http://www.spinnerspilotshop.com/cgi...html?E+scstore) and this PTT: http://www.mypilotstore.com/MyPilotStore/sep/3313 work the way you'd want them to. |
On Sun, 02 Sep 2007 22:30:39 GMT, Tom L.
wrote: A24, headset adapter OPC-499 (http://www.spinnerspilotshop.com/cgi...html?E+scstore) and this PTT: http://www.mypilotstore.com/MyPilotStore/sep/3313 work the way you'd want them to. Thanks, Tom & Ron! I have that exact headset adaptor. I noticed in the manual that the PTT simply closes a loop, so the Icom PTT's sold by a local Fire/PD/EMS/Ham radio shop, with the same connector, should work. I didn't want to drop the cash for the PTT to find that the radio mic wasn't cut off. It turns out my comm failure was related to my Narcos getting loose in the rack. |
I have the same setup, with the PTT. Works just fine with the headset.
I didn't check the links from some of the other posts, but I got my PTT from Marv Golden. IIRC, it was $20, or very close. Carl "B A R R Y" wrote in message ... I use my A24 lots, for listening to ASOS, communicating to aircraft at fly-ins, ordering fuel, etc... I rarely use it with a headset. The other night, I had a full-on comm failure and needed to use it while aloft, with a headset. It took me a few minutes to remember, but my radio keys only the radio's onboard mic when keyed with the onboard PTT, not the headset mic. To use it with a headset, I need to put the radio to my mouth and talk into the radio, the mic in the headset is not used. My adapter is a genuine Icom product, with phones, mic, and PTT connections. I'm only connected to the phones and mic jack. Can anyone confirm to me that an external PTT will in fact key the headset mic? My Googling has come up with lots of yeas and neahs in conflict. |
On Sun, 02 Sep 2007 20:09:18 -0400, john smith
wrote: Google the following: ICOM HS-10SB THANKS! That looks like it's worth a good look, as it'll let me match the mic to the HH. I'd never heard of it. |
wrote: Google the following: ICOM HS-10SB NG with the A6/24, headset adaptor, and Bose X headset. I think I need a simple PTT to plug into the vacant jack on the connector. |
| FA: Icom A21 Nav-Com handheld with headset and accessories. United States. | [email protected] | Home Built | 1 | February 27th 06 04:06 PM |
| FA: Icom A21 Nav-Com handheld with headset and accessories. United States. | [email protected] | Soaring | 1 | February 27th 06 04:06 PM |
| FA: Icom A21 Nav-Com handheld with headset and accessories. United States. | [email protected] | Aviation Marketplace | 1 | February 27th 06 04:06 PM |
| ICOM A-20 HEADSET ADAPATER | henrys12 | Home Built | 0 | December 1st 05 02:10 AM |
| ICOM Headset Adaptor Plug | Ron Wanttaja | Home Built | 3 | June 2nd 05 08:54 AM |
