#11
Tank Fixer wrote:
In article , says... Since taking up aviation as a hobby, I have wondered why gasoline, and similar oil-derived liquid fuels, have become the defacto standard for all forms of general aviation and commercial and military aircraft. Comparing Jet fuel to something like natural gas, Jet fuel is four times as expensive. Liquid fuels are extremely heavy, and certainly airplanes do not need extra weight. Perhaps because in the early development of aircraft it was found to be a sutible fuel ? This leads me to wonder why haven't engines been commercialized that can burn gas-based fuels? Is the only reason safety, because of the explosive nature of gas fuels like natural gas or hydrogen? You will find any number fo ground vehicles that use LPG for fuel. Isn't there some way you could use two separate gases, which in their separate state are inert, but combined together under high pressure, become explosive? Such a combination would not ignite if the airplane crashed (you could separate the gases into separate containers on each side of the airplane, at the wingtips), but in controlled injection into a high pressure compartment could be made explosive in a controlled way, in a very limited space. Think how much fuel is being wasted each day on airplanes, simply to support the extra weight required to carry the fuel itself. Think how dangerous airplanes are during relatively survivable impacts to the ground, primarily because they are gasoline bombs. I would be very interested to read about efforts to develop gas based engines for general aviation or commercial aircraft. I would appreciate any pointers to web sites or books. Think how safe airplanes would be if they were powered by coal fired steam engines.... No wait, that won't work either.. coal dust = explosions.. I think that they've found that jet fuel (kerosene etc) has the greatest energy pound for pound, it doesn't require special handling (as LNG etc does) etc so it's the best and cheapest available. You can bet yer butt that if another type were cheaper then they'd be using that. A lot of good minds are involved in the 'big bux' aviation world. They don't miss much. -- -Gord. |
In article , "Gord Beaman"
) says... Tank Fixer wrote: In article , says... Since taking up aviation as a hobby, I have wondered why gasoline, and similar oil-derived liquid fuels, have become the defacto standard for all forms of general aviation and commercial and military aircraft. Comparing Jet fuel to something like natural gas, Jet fuel is four times as expensive. Liquid fuels are extremely heavy, and certainly airplanes do not need extra weight. Perhaps because in the early development of aircraft it was found to be a sutible fuel ? This leads me to wonder why haven't engines been commercialized that can burn gas-based fuels? Is the only reason safety, because of the explosive nature of gas fuels like natural gas or hydrogen? You will find any number fo ground vehicles that use LPG for fuel. Isn't there some way you could use two separate gases, which in their separate state are inert, but combined together under high pressure, become explosive? Such a combination would not ignite if the airplane crashed (you could separate the gases into separate containers on each side of the airplane, at the wingtips), but in controlled injection into a high pressure compartment could be made explosive in a controlled way, in a very limited space. Think how much fuel is being wasted each day on airplanes, simply to support the extra weight required to carry the fuel itself. Think how dangerous airplanes are during relatively survivable impacts to the ground, primarily because they are gasoline bombs. I would be very interested to read about efforts to develop gas based engines for general aviation or commercial aircraft. I would appreciate any pointers to web sites or books. Think how safe airplanes would be if they were powered by coal fired steam engines.... No wait, that won't work either.. coal dust = explosions.. I think that they've found that jet fuel (kerosene etc) has the greatest energy pound for pound, it doesn't require special handling (as LNG etc does) etc so it's the best and cheapest available. You can bet yer butt that if another type were cheaper then they'd be using that. A lot of good minds are involved in the 'big bux' aviation world. They don't miss much. Well aware of the extra handling and storage requirments for LPG. The original poster is ignoring the history of aircraft development. They used those fuel's that were available and cheap. I'd have to get into the SG and BTU content of the various fuels but the current crop of jet fuels have a good balance of stored energy to safety. -- When dealing with propaganda terminology one sometimes always speaks in variable absolutes. This is not to be mistaken for an unbiased slant. |
separate state are inert, but combined together under high pressure, become explosive? Such a combination would not ignite if the airplane crashed (you could separate the gases into separate containers on each side of the airplane, at the wingtips), but in controlled injection into a high pressure compartment could be made explosive in a controlled way, in a very limited space. We've been using this for years in spacecraft. The Titan II that launched Gemini capsules was powered by hypergolics. Mainly, though, these fuels are used for in-orbit engines (Apollo, Soyuz, space shuttle, and Shenzhou all use hypergolic propellants). The most common ones used are unsymmetrical dimethyl hydrazine (UDMH) and nitrogen tetraoxide (NO4). These two chemicals are EXTREMELY toxic. Also, the Russian Proton rocket, and the launch vehicle the Chinese used to launch their taikonaut, are powered by hypergolic fuels. |
| Thread Tools | |
| Display Modes | |
| The answer to the gasoline problem | Veeduber | Home Built | 4 | May 22nd 04 09:58 PM |
| $3.00 a gallon gasoline by summer(read all of this, it just might work) | Fastglasair | Home Built | 8 | March 10th 04 01:12 AM |
