O2 filling
Old November 20th 07, 03:51 AM posted to rec.aviation.piloting
Morgans[_2_]
Default O2 filling
"Dan" wrote
BTW, US Airweld in the Phoenix area will fill tanks (not just exchange
them), which was a bit hard to find.
Around here, it isn't hard to find someone to fill your own bottle, but you
will have to wait a few days for it.
Jim in NC
  #62
Old November 20th 07, 12:23 PM posted to rec.aviation.piloting
Ron Natalie
Default O2 filling
Tina wrote:
Thomas, I would think some vendor, probably local, is either buying or
generating oxygen, and compressing it.
Commercial oxygen is genereted by cryogenic separation which involves
compressing it to levels so high that the atmospheric differences are
completely lost.
  #63
Old November 20th 07, 02:29 PM posted to rec.aviation.piloting
gwengler
Default O2 filling
Anyone go to jail for this?- Hide quoted text -
I don't know. Here is a write-up by Peter Garrison (Flying magazine):
http://stage.flyingmag.com/article.a...ection_id= 19
Gerd
  #65
Old November 20th 07, 03:57 PM posted to rec.aviation.piloting
Jim Macklin
Default O2 filling
If you refill at an airport, they usually pull a cart up to the airplane
with a series of oxygen bottles manifold.
The begin filling slowly, so as not to generate too much heat that will
raise the pressure. They start with the lowest pressure tank on their cart
and fill until flow stops. Then they close the valve on that tank and open
the valve on the next higher pressure tank, until the pressure has reached
the same as the source tank.
The source tank cools as compressed gas comes out and the aircraft tank get
hotter as gas goes in. That means the tank will read 2300 ponds when it is
full and an hour later it will be at 2000 when it is cooler and a cruise
altitude in the cold, the tank will be down to 1800 PSI. If the tank can be
refilled out of the airplane, it can and should be placed in a tank of cold
water to speed the refill process and efficiency and to provide protection
if it blows up during the filling.
An generator produces low pressure gas which can be accumulated and
breathed. Your lungs would rupture if you tried to breathe high pressure,
more than a pound above the outside air pressure at your altitude.
Over-pressure breathing is measured in "inches of water" and a foot of water
is only a 1/2 pound.
"gwengler" wrote in message
Gerd
  #66
Old November 20th 07, 07:55 PM posted to rec.aviation.piloting
Dan Youngquist
Default O2 filling
On Mon, 19 Nov 2007, Dan wrote:
What adaptor do you use for the transfilling? Do you have a welding
bottle(s) that you exchange? Most of the transfilling adaptors I've
seen are more than $100.
I got one from this guy: http://search.ebay.com/_W0QQsassZjohnclairowens
I got an extra yoke end so I can connect any combination of welding or
medical cylinders.
Also have another one I found used for a lot cheaper.
I don't have my own welding cylinder, I fill from a friend's. If I used
more I'd get my own cylinder.
-Dan
Filling Aluminum Lou Home Built 3 December 27th 06 02:41 AM
Filling with nitrogen scott moore Owning 21 December 8th 06 07:48 PM
Filling Holes AKperson Owning 1 July 20th 05 03:54 PM
Filling oxygen tanks Bruce McFadden Owning 49 December 28th 04 11:41 PM
Minden's filling up! JJ Sinclair Soaring 12 February 15th 04 11:46 AM
