USN grounds 39 P-3s over faulty wings
Old December 17th 07, 11:03 PM posted to rec.aviation.military.naval,nl.defensie.marine,rec.aviation.military
Marco P.J. Borst
Default USN grounds 39 P-3s over faulty wings
(From: www.navytimes.com)
Navy grounds 39 P-3s over faulty wings
By Chris Amos - Staff writer
Posted : Monday Dec 17, 2007 13:54:07 EST
The Navy on Monday grounded 39 P-3 Orion anti-submarine patrol planes -
nearly one in four of its inventory - because of concerns that a structural
defect could cause either of the aircraft's wings to break off in flight.
The grounding was the result of engineering analysis and computer modeling
and was not caused by any actual structural failures, said John Milliman,
spokesman for Naval Air Systems Command.
Navy engineers looked at several factors, Milliman said, including the
number of hours a particular aircraft has flown, the maneuvers it performed
while in flight, the altitude the aircraft have operated at and the climate
in areas where it has been based in determining which aircraft should be
grounded and which should be kept flying.
Milliman said each grounded aircraft will be flown to a repair depot in
Jacksonville, Fla. Those that can be repaired will be out of service for
between 18 and 24 months. Those that can't will be retired.
Navy officials have not determined how much the repairs will cost or whether
retired aircraft will be replaced, he said.
Navy officials will rotate P-3s from other parts of the fleet to replace the
10 grounded aircraft that are currently deployed, and commanders plan to
ensure that each squadron can meet all of its operational requirements.
The Navy has 161 P-3s. Their average age is 28 years old; the oldest
aircraft is 44 and the youngest 18. Milliman was unable to say whether the
age or flight time of the grounded planes was greater than that of the P-3
fleet as a whole.
Old December 19th 07, 09:05 AM posted to rec.aviation.military.naval,nl.defensie.marine,rec.aviation.military
PieterW
On Mon, 17 Dec 2007 23:03:53 +0100, "Marco P.J. Borst"
yep daar hadden die oude L-188's in de jaren 60 ook al last van.
haarscheurtjes in de vleugels.
toen ontstond danook het grapje dat de oplossing zou bestaan uit het
boren van een reeks gaatjes in de haarscheuren.
De diepere filosofie was dat pleepapier ook nooit scheurde bij de
gaatjes.
Cheers, Pieter
Vernuft is een sublimatie van domheid.©
Old December 22nd 07, 04:39 AM posted to rec.aviation.military.naval, nl.defensie.marine,rec.aviation.military
Mr.Smartypants[_2_]
On Dec 17, 3:03*pm, "Marco P.J. Borst" wrote:
(From:www.navytimes.com)
fleet as a whole.
Gee, all America's flying stuff is suddenly being grounded.
However will y'all start new wars?
Old January 6th 08, 09:09 AM posted to rec.aviation.military.naval
fudog50[_2_]
I see you are from canada smarty pants?
This "redstripe" doesn't include the CP-140 aurora dip**** do you
even know what that is? Because you guys hardly fly i like we fly
ours? Although your crews are great.
How about all the "wars we started" you guys always manage to limp in
with minimal support, which however weak is appreciated. (except for
WW2, you guys certainly went above and beyond)
Which brings up the point, who is in charge in Canada, the world as a
whole has no clue? Does anyone really care?
On Fri, 21 Dec 2007 19:39:29 -0800 (PST), "Mr.Smartypants"
age or flight time of the grounded planes as greater than that of the P-3
fleet as a whole.
Faulty Becker AR-3201 Pepin Andr? R. Soaring 3 March 7th 10 03:22 PM
Emergency AD Grounds 172s and 182s C J Campbell Owning 4 March 10th 05 04:41 AM
MX 20 -another faulty display [email protected] Instrument Flight Rules 14 January 29th 05 06:54 PM
Radio outage at ZLA grounds flights A Guy Called Tyketto Piloting 0 September 15th 04 06:56 AM
Flying w/faulty gas gauge Yossarian Piloting 48 November 18th 03 04:18 PM
