#21
Phil wrote in
: I know they call it the Windy City, but this is ridiculous... http://www.aero-news.net/index.cfm?C...2-d205-411d-89 15-86c169181d87& Happens all the time. The fins are huge and some airplanes weathervane easily. It happened to one of our airplanes (727) years ago unbeknowst to the crew. The FE did the walkaround and noticed that the Radome had two nostrils. Further investigations revealed that the airplane had turned around in high winds and had ridden up on top of the GPU. The handling agent needed their GPU for another airplane, but found a 727 inconvieniently parked on top of it, so they lifted the nose of the airplane with a forklift in order to get it out. They went right through the radome and into the forward pressure bulkhead. I've had two airplanes weathervane on me, though, both undamaged. Bertie |
"Robert M. Gary" wrote in
: On Dec 27, 1:55*pm, wrote: So it doesn't roll away in the wind all on it's own with no one on board? Or, if they were expecting to tow it in the immediate future, where were the chocks to make sure it doesn't roll away in the wind all on it's own until they got around to towing it? While its possible that someone does it, I'm not aware of any operator that sets the brake on aircraft when its not occupied. We do. Our's are pretty lightly stressed, though. Usually chalks work just fine and are easier to move when you need to tow. In smaller aircraft there are other reasons to avoid setting the brake, like changes in outside pressure could burst the brake seals. Mmm, doubt that. The best reason I can think of for not relying on the parking brake in a wind is that they are not very reliable. Schwinn could make a better arrangement than you see on most Cessnas, for instance. Brakes are next to useless in very high winds anyway. After all, if the wing is being lifted.... Bertie |
"RST Engineering" wrote in
: Anyone who watched the Bears game on Sunday and saw Brent Fabre say that it was the coldest game he'd ever played it knows that it was an absolute ice rink at Midway. You could have set those brakes at a thousand psi and that sucker would have fancydanced across the ice in that wind. Wel, they would have been set at 3,000 PSI in fact, No chocks, only tiedowns could have kept that aircraft from moving. True. Bertie |
Mike Beede writes:
I was told during primary training that if you left the parking brake on the pads could rust to the disks or drum and make it hard to get moving. I ride my bike to work, so often I don't drive my car for a week or more. This happens to me fairly often in my car -- I don't see why it wouldn't happen in a plane even more often. Chris |
On Dec 28, 12:23*am, Bertie the Bunyip wrote:
Phil wrote : I know they call it the Windy City, but this is ridiculous... http://www.aero-news.net/index.cfm?C...2-d205-411d-89 15-86c169181d87& Happens all the time. The fins are huge and some airplanes weathervane easily. It happened to one of our airplanes (727) years ago unbeknowst to the crew.. The FE did the walkaround and noticed that the Radome had two nostrils. Further investigations revealed that the airplane had turned around in high winds and had ridden up on top of the GPU. The handling agent needed their GPU for another airplane, but found a 727 inconvieniently parked on top of it, so they lifted the nose of the airplane with a forklift in order to get it out. They went right through the radome and into the forward pressure bulkhead. I've had two airplanes weathervane on me, though, both undamaged. Bertie Interesting. I've never heard of this before. When it weathervanes, how does that work? Does it pivot around the mains and drag the nosewheel? Phil |
#28
Phil wrote in
: On Dec 28, 12:23*am, Bertie the Bunyip wrote: Phil wrote innews:549d11fb-44f9-414a-ac63-af2923f7 : I know they call it the Windy City, but this is ridiculous... http://www.aero-news.net/index.cfm?C...161c7642-d205- 411d- 89 15-86c169181d87& Happens all the time. The fins are huge and some airplanes weathervane easily. It happened to one of our airplanes (727) years ago unbeknowst to the crew . The FE did the walkaround and noticed that the Radome had two nostrils. Further investigations revealed that the airplane had turned around in hig h winds and had ridden up on top of the GPU. The handling agent needed their GPU for another airplane, but found a 727 inconvieniently parked on top of it, so they lifted the nose of the airplane with a forklift in order to ge t it out. They went right through the radome and into the forward pressure bulkhead. I've had two airplanes weathervane on me, though, both undamaged. Bertie Interesting. I've never heard of this before. When it weathervanes, how does that work? Does it pivot around the mains and drag the nosewheel? Exactly. Chocks will ordinarily keep the airplane in place. Some outfits don't chock properly and/or use crap chocks. A friend of mine ran up to the flight deck of another 737 when he saw it crush the only chock it had, a nosewheel chock on one wheel and roll towad the terminal. It damaged it's airstairs, but that's all. They were lucky. Bertie |
#29
On Dec 27, 10:32*pm, Bertie the Bunyip wrote:
The best reason I can think of for not relying on the parking brake in a wind is that they are not very reliable. Schwinn could make a better arrangement than you see on most Cessnas, for instance. Brakes are next to useless in very high winds anyway. After all, if the wing is being lifted.... I've never had occasion to stand on an airplane's brake but when I use the same amount of foot pressure on my Mooney as in my Saturn the Saturn will stop in 1/2 the distance. -Robert |
#30
On Dec 27, 6:16*pm, Matt Whiting wrote:
Robert M. Gary wrote: On Dec 27, 3:18 pm, "Bob Gardner" wrote: Chocks, Robert, chocks. Use your dictionary. How do you know I don't use chalks? Given your demonstrated knowledge about parking aircraft ... I suspect that you do use chalks. Hey, they're multi use and no one takes them. -Robert |
| Thread Tools | |
| Display Modes | |
| Proof FAA Managers are full blown certified IDIOTS | SOS | Instrument Flight Rules | 1 | December 1st 07 06:05 AM |
| Proof FAA Managers are full blown certified IDIOTS | SOS | Piloting | 1 | November 29th 07 08:44 PM |
| Ramp riders 5 | Paul | Aviation Photos | 0 | November 19th 06 11:09 PM |
| MMU ramp fee | Peter Gottlieb | Piloting | 25 | August 9th 03 01:49 AM |
| Flight TWA 800 was shot down/blown up by Al Quadea? | Tiger | Military Aviation | 0 | July 3rd 03 06:38 PM |
