#42
JGalban via AviationKB.com wrote:
RST Engineering wrote: No chocks, only tiedowns could have kept that aircraft from moving. Chocks aren't perfect. At my home field we often get violent downbursts from thunderstorms in the summer. Peak gusts of 60-70 kts aren't unusual. I use both chocks and tiedowns, and I've found that after a particularly bad storm, the chocks were often blown away from wheels and the plane was sitting slightly sideways with the tiedowns pulled tight. Yes, chocks are temporary restraints and no better on ice than are the tires and brakes. Tie downs are the only way to go for permanent restraint (other than a hangar!). Matt |
#43
F. Baum wrote:
On Dec 28, 1:28 pm, "JGalban via AviationKB.com" u32749@uwe wrote: No chocks, only tiedowns could have kept that aircraft from moving. Chocks aren't perfect. They may not be perfect but close. The chocks typicaly used on airlines could have prevented this. There are no provisions for tying down a jet. The 737 manual does recommend leaving the parking brake set in windy conditions. Parking brake? Who woulda thunk it? :-) Matt |
#44
On Dec 29, 9:53*am, Matt Whiting wrote:
The main reason I know of that most people park airplanes with the brakes released is to facilitate movement of the airplane when the owner isn't around. Matt, As it relates to the OP, the parking brake is never relied upon and the plane is always chocked with or without the brake on. An airline does not tow an airplane without a qualified person (Either a pilot or mechanic who has been checked out for towing) in the front seat. FB |
#45
F. Baum writes:
As it relates to the OP, the parking brake is never relied upon and the plane is always chocked with or without the brake on. An airline does not tow an airplane without a qualified person (Either a pilot or mechanic who has been checked out for towing) in the front seat. I don't understand how a small pair of chocks can hold an aircraft in place. It seems like a trivial obstacle to overcome when the wind is hitting all those aerodynamic surfaces. |
#46
Mxsmanic wrote in
: F. Baum writes: As it relates to the OP, the parking brake is never relied upon and the plane is always chocked with or without the brake on. An airline does not tow an airplane without a qualified person (Either a pilot or mechanic who has been checked out for towing) in the front seat. I don't understand how a small pair of chocks can hold an aircraft in place. That's because you don;t fly, fjukkwit. Bertie |
#47
"Mxsmanic" wrote in message
... I don't understand how a small pair of chocks can hold an aircraft in place. Gee, There's a surprise. I'm gonna have a heart attack and die from that surprise. |
#48
On Dec 29, 11:57*am, Matt Whiting wrote:
JGalban via AviationKB.com wrote: RST Engineering wrote: No chocks, only tiedowns could have kept that aircraft from moving. * Chocks aren't perfect. * At my home field we often get violent downbursts from thunderstorms in the summer. *Peak gusts of 60-70 kts aren't unusual. *I use both chocks and tiedowns, and I've found that after a particularly bad storm, the chocks were often blown away from wheels and the plane was sitting slightly sideways with the tiedowns pulled tight. Yes, chocks are temporary restraints and no better on ice than are the tires and brakes. *Tie downs are the only way to go for permanent restraint (other than a hangar!). Matt Do small planes have parking brakes? I don't remember having ever seen one that I could set the brakes. Wil |
#49
William Hung wrote in
: On Dec 29, 11:57*am, Matt Whiting wrote: JGalban via AviationKB.com wrote: RST Engineering wrote: No chocks, only tiedowns could have kept that aircraft from moving. * Chocks aren't perfect. * At my home field we often get violent dow nbursts from thunderstorms in the summer. *Peak gusts of 60-70 kts aren't unus ual. *I use both chocks and tiedowns, and I've found that after a particularly b ad storm, the chocks were often blown away from wheels and the plane was si tting slightly sideways with the tiedowns pulled tight. Yes, chocks are temporary restraints and no better on ice than are the tires and brakes. *Tie downs are the only way to go for permanent restraint (other than a hangar!). Matt Do small planes have parking brakes? I don't remember having ever seen one that I could set the brakes. Most modern ones do. Lots of old ones too. Bertie |
#50
William Hung wrote:
Do small planes have parking brakes? Look closer. G |
| Thread Tools | |
| Display Modes | |
| Proof FAA Managers are full blown certified IDIOTS | SOS | Instrument Flight Rules | 1 | December 1st 07 06:05 AM |
| Proof FAA Managers are full blown certified IDIOTS | SOS | Piloting | 1 | November 29th 07 08:44 PM |
| Ramp riders 5 | Paul | Aviation Photos | 0 | November 19th 06 11:09 PM |
| MMU ramp fee | Peter Gottlieb | Piloting | 25 | August 9th 03 01:49 AM |
| Flight TWA 800 was shot down/blown up by Al Quadea? | Tiger | Military Aviation | 0 | July 3rd 03 06:38 PM |
