#181
In rec.aviation.piloting Montblack wrote:
wrote) The coefficient of drag for motorcycles is usually pretty bad unless they are faired, and it still ain't great. The power required to overcome drag is 1/2(p*v^3*A*C) p is the densitity of the fluid v is the airspeed A is the area C is the coefficient of drag 80-ft length of the semi (vs.) 8-ft length of the motorcycle Does this play (much) of a role here? Is that role expressed (adequately/sufficiently) in the above formula, through "C" ...drag? The C is the catchall variable that is determinded by the object's overall shape and for all but the most simple shapes (i.e. flat plate, sphere, etc.) determined by measurement. As to what length does specifically, it depends. Smooth sides are going to be less "draggy" than lumpy sides. A flat back end is going to be more "draggy" than a tapered back end. -- Jim Pennino Remove .spam.sux to reply. |
#182
This new silicon nanowire technology claims to produce ten times the
amount of electricity of existing lithium-ion cells. It could be the enabling technology for electric aircraft, not to mention what it might do for automobiles: http://news-service.stanford.edu/new...re-010908.html Stanford Report, December 18, 2007 Stanford's nanowire battery holds 10 times the charge of existing ones BY DAN STOBER Stanford researchers have found a way to use silicon nanowires to reinvent the rechargeable lithium-ion batteries that power laptops, iPods, video cameras, cell phones, and countless other devices. The new version, developed through research led by Yi Cui, assistant professor of materials science and engineering, produces 10 times the amount of electricity of existing lithium-ion, known as Li-ion, batteries. A laptop that now runs on battery for two hours could operate for 20 hours, a boon to ocean-hopping business travelers. "It's not a small improvement," Cui said. "It's a revolutionary development." The breakthrough is described in a paper, "High-performance lithium battery anodes using silicon nanowires," published online Dec. 16 in Nature Nanotechnology, written by Cui, his graduate chemistry student Candace Chan and five others. The greatly expanded storage capacity could make Li-ion batteries attractive to electric car manufacturers. Cui suggested that they could also be used in homes or offices to store electricity generated by rooftop solar panels. "Given the mature infrastructure behind silicon, this new technology can be pushed to real life quickly," Cui said. ... On Sun, 05 Aug 2007 16:52:46 GMT, Larry Dighera wrote in : Electrically Powered Ultralight Aircraft Below is a report of an electrically powered ultralight aircraft. Further down is information about Sonex's electrically powered home-built aircraft, and below that is information about Royal Aeronautical Society's 2007-8 design competition (submissions close May 2, 2008). Personally, I'd like to see an electrically powered parachute (http://skyhighflying.com/homepage.html) design attempted. Surly the lighter weight would require less power. It would seem that lithium-ion polymer batteries are a potential enabling technology. AVGAS? WHO NEEDS IT? TRIKE RUNS ON BATTERIES (http://www.avweb.com/eletter/archive...ll.html#195816) While concerns over price, availability and environmental impact have aviators worried about the future of fuel, one ultralight flyer in New Jersey has already solved that problem. Randall Fishman has been testing lithium-ion polymer battery packs to drive the prop on his ultralight trike, and he says they work great. They are powerful, smooth, sturdy, safe and quiet, Fishman claims. "The closest thing to a magic carpet ride ever," he says on his Web site (http://www.electraflyer.com/). The quiet is not only enjoyable for the pilot, it improves relations with neighbors, he notes. The batteries will run for up to two hours and cost about 60 cents to charge via a standard electric outlet. However, the batteries are expensive -- $3,800 to $7,500, depending on size. http://www.avweb.com/eletter/archive...ll.html#195816 First attempted takeoff video: http://www.youtube.com/watch?v=Wksx-jmhY7c Brochu http://www.electraflyer.com/brochure.pdf Technical Specifications: Motor - 18 H.P. High Torque - 90% Efficient at Cruise Controller - Electronic, Pulse Width Modulation, For High Efficiency and Smooth Control Battery Packs - Custom Built, Lithium Ion Polymer, Super High Capacity Choose the Size You Want Voltmeter - To Monitor How Much Power Is Available Ammeter - To Monitor How Much Power You Are Using Thrust - With Folding Prop - 140 Pounds With Big, Ultra Quiet Prop - 155 Pounds Duration - Up to Two Hours Depending on Battery Pack Chosen, Total Weight and Efficiency of the Wing - 1 to 1.5 Hour Flights Most Common Total Weight - 210 to 250 Pounds Complete With Wing and Battery Packs The ElectraFlyer is a True Legal Part 103 Ultralight Electric Aircraft Corporation Randall Fishman, President phone: 561-351-1190 website: www.ElectraFlyer.com email: http://www.electraflyer.com/52_53_womf.pdf An EAA MEMbEr First... The ElectraFlyer, an Electric-Powered Trike! http://www.electraflyer.com/lightsport.pdf Light Sport and Ultralight Flying July 2007 ================================================= == Sonex web site: http://www.sonexaircraft.com/ Photo of Sonex e-flight electric aircraft: http://www.sonexaircraft.com/news/im...flight_058.jpg Photo of electric powerplant: http://www.sonexaircraft.com/news/im...light_5947.jpg Diagram of e-Flight powerplant: http://bioage.typepad.com/.shared/im.../25/sonex1.png Pricing: http://www.sonexaircraft.com/kits/pricing.html Article: http://www.greencarcongress.com/2007...aft-.html#more http://www.sonexaircraft.com/press/r...pr_072407.html Sonex Aircraft, LLC and AeroConversions Unveil E-Flight Initiative for Sport Aircraft Alternative Energy Research & Development Electric Power; a new mission: The contemporary E-Flight electric project will benefit greatly by the maturation of technology since our initial studies. Using a purpose-built AeroConversions brushless DC cobalt motor, controller, and highly efficient battery and charging system, the E-Flight electric systems will be able to power a larger aircraft to higher top speeds with greatly increased endurance. E-Flight’s proof-of-concept prototype will use the flight proven Waiex airframe, flown single pilot only, so that the emphasis can be placed solely on powerplant research and development. Initial top speeds will reach approximately 130 mph, and endurance is expected to range between 25-45 minutes or longer, depending upon power usage on each individual flight. The initial emphasis for the E-Flight proof-of concept aircraft has been shifted away from immediate pursuit of FAI speed records, although the possibility remains that those records could be obtained in short-order after successful first flight. With the advanced state of the technologies concerned, the goal of the project is to develop and prove the application of the technology and pave the way for near-term electric powerplant Sonex and AeroConversions products for sale to the sport aviation marketplace and beyond. The current state and growing popularity of electric powered model RC aircraft leads the layman to assume that an electric powered aircraft of this type is simply a matter of hooking a bigger battery to a bigger motor, charging it up in an hour or two and taking-off. While that is essentially true in raw principle, the reality of this project is that scaling-up these technologies in a viable manner presents significant challenges. • Electric Power; AeroConversions Electric Motor: Brushless DC cobalt motor technology has advanced significantly since 1994’s Flash Flight study, allowing the design team to now consider their use, however, just like before, a suitable brushless DC cobalt motor of this level of power output with an acceptable size and weight does not exist and can not be built and provided by a third party vendor without incurring unacceptable costs. As a result, the design team, in collaboration with Bob Boucher of Astro Flight, Inc., has designed and built a completely new AeroConversions motor. This motor is the most powerful, lightest-weight, and efficient unit of this type ever produced. It is a 3 phase, 270 volt, 200 amp motor that will be over 90 percent efficient. It uses elegantly designed CNC machined anodized aluminum and nickel-plated steel parts in combination with “off the shelf” bearings, races, snap rings, magnets, etc. The prototype AeroConversions motor is slightly larger than a 35 ounce coffee can and weighs approximately 50 pounds. The motor is a modular, scalable unit. The motor core’s design has modular sections that can be reduced to a lower-output, smaller motor (shortened in length), or added upon to make a larger motor with a higher power output. • Electric Power; AeroConversions Electronic Motor Controller: Electronic motor controllers for brushless electric motors are quite commonplace today, mostly used in the electric RC market. A suitable controller for a 270 volt, 200 amp motor does not exist. Running such high current requires much larger components. Although there are a handful of third party vendors who could design and build the appropriate controller for this project, it would take 6-7 months lead time and cost 20-50 Thousand Dollars. The time and cost associated with acquiring such a controller was deemed unacceptable and the research and development team, in cooperation with a key electronics expert, began designing a proprietary AeroConversions electronic motor controller. The controller can commutate the motor in two different ways: using Hall effect sensors to determine the magnet core’s position in relation to the coils, or using the motor’s back-EMF to sense rotor position, eliminating the need for Hall sensors. The AeroConversions controller will initially employ a Hall effect sensor-equipped motor, but back-EMF controlling will also be explored to potentially further simplify the AeroConversions motor design. The AeroConversions controller will also provide in-cockpit monitoring of battery power levels to the pilot. • Electric Power; AeroConversions Battery System: Most contemporary electric powerplants for gas-electric and pure electric cars and previous generations of RC electric vehicles utilize Lithium Ion battery technology. While much improved in power density and discharge rate over lead-acid and NiCad batteries, Li-Ion batteries still do not offer enough power discharge-to-weight ratio to support an electric powerplant for an aircraft that is based on battery power alone and has a market-viable endurance. Newer RC electric vehicles, cell phone, laptop computers and other mobile devices have been moving toward Lithium Polymer cells. Li-Poly battery cells can safely discharge at a rate of 25 times their capacity, or “25c.” With all the extra energy of a Li-Poly cell, however, comes extra volatility. The E-Flight design team has engineered and constructed 10 battery “safe boxes” intended to contain 8 Li-Poly battery packs per box and consolidate their charge/discharge and balancing wiring into two sets of multi-pin connectors. The Boxes will accommodate natural cell expansion and contraction while safely securing each cell pack and facilitating cell cooling with “cooling foam” padding. Cooling will further be aided by heat sink surfaces on each box that will have cooling inlet air directed over them. Additionally, the boxes are designed to contain and safely direct fire or explosion within the box through a “blow hole” in the box that will be connected to a small exhaust manifold. For the proof-of-concept aircraft, the battery boxes will be removed from the aircraft and charged individually. The charging units need to be configured to safely keep all cells balanced during charging. Lessons learned from the proof-of-concept systems will lead to the design of more advanced charging and balancing systems allowing safer battery handling by consumers, including a single-plug charging system that may remain in the aircraft at all times, featuring easy exchange of battery boxes to enable consecutive back-to-back flights in a short period of time by pilots who wish to invest in spare batteries. Future generations of safer, more powerful Li-Poly batteries show the near-term possibility of further extended flight duration while personal electronics and transportation will undoubtedly continue to push improvement of the technology in years to come. “By developing a viable electric motor and controller system for this proof-of-concept aircraft, we will open a door to future flight that we have only been able to dream of,” comments Monnett. “Self-launching electric powered gliders already exist. The potential of electric power goes beyond that single use and relates directly to sport flying, aerobatics and high altitude flight in purpose-built airframes. It is essential that our proof-of-concept vehicle is a conventional aircraft that the majority of aviation enthusiasts can relate to.” One remarkable reality about the E-Flight electric aircraft project is that, by necessity, the entire R&D project for the proof-of-concept stage of the project will cost less than the price of the average ready-to-fly LSA aircraft available today. This project undeniably highlights the spirit of EAA in that it is truly a grass-roots effort to push technology for advancement of our sport and improvement of our planet’s ecosystem and it has been accomplished, not by a large aerospace firm or government agency, but by EAA members on an extraordinarily cost-effective budget. http://www.aeroconversions.com/ -------------------------------------------------------------------------------- The official daily newspaper of EAA AirVenture Oshkosh Volume 8, Number 4 July 25, 2007 -------------------------------------------------------------------------------- Sonex rolls out electric plane By Randy Dufault Jeremy Monnett shows off the electric motor and mount employed in a proof-of-concept Waiex airframe to demonstrate the potential of compact electric power and advanced-technology batteries. Photo by Dave Higdon With the price of oil rising faster than an F-15 in an unrestricted climb and the potential for $6 per gallon self-serve avgas a real possibility, alternate ways of powering aircraft, ways that require much less fossil fuel, are going to be important to the future of sport aviation. On Tuesday, Sonex Aircraft LLC took the wraps off its previously secret e-Flight initiative. "This is an exciting announcement and one that you are really going to appreciate," EAA President Tom Poberezny said at the beginning of the press conference. He added, "It addresses the grass-roots research that is important to the integrity of EAA and the homebuilt movement. More importantly, it is growing aviation by making it more economical." The most visible aspect of e-Flight right now is a Sonex Waiex airframe equipped with a proof-of-concept prototype electric powerplant. The aircraft, which is expected to fly later this year, will be used to further develop the motor, along with the requisite control systems, charging systems, and of course, battery systems. "It was [apparent] that once we started down this path to developing an alternative power source for the airplane, that we had to do it in very specific steps," John Monnett, Sonex founder and president, said when he introduced the electric plane. "The whole object of [the proof-of-concept] is to come up with a powerplant that is equivalent in weight and in power to our AeroVee-powered Sonex and Waiex [models]." Monnett went on to add the sole mission of the airplane displayed here is to develop the technologies that will ultimately result in production systems. The test-bed airplane is also expected to test other, as yet unspecified, electric power sources. The prototype powerplant uses brushless, cobalt motor technology and, according to AeroConversions, is the most powerful, lightest weight, and efficient motor of the type ever produced. It was developed with the help of Bob Boucher of Astro Flight Inc. Astro Flight is a major producer of electric radio-controlled model motors. The 200-amp motor is 90 percent efficient and operates on 270 volts of direct current electricity, as advertised by the Waiex’s tail number, N270DC. According to Pete Buck, Sonex’s chief engineer, the motor was manufactured in-house. He added that Sonex expects to construct virtually all of the components of the future production systems themselves. Production systems, unlike the current AeroVee engine, likely will not be offered as kits, due to the critical tolerances and potential dangers with some of the electrical components. Monnett pointed out that a couple of technologies are key to making electric flight a reality. Of course, powerful and light batteries are a must, but a motor controller capable of managing the high power involved also is required. A charging system, capable of replenishing the batteries in a reasonable amount of time, is another must. Sonex is developing both technologies. Target flight duration for the proof-of-concept airplane is 25 minutes to 45 minutes. Production systems are expected to allow for one-hour flights. Buck says an hour’s endurance is difficult right now but ultimately is very possible as both the system and the available technologies are further developed. In addition to the electric Waiex, Sonex’s e-Flight initiative also involves two other aspects: the practical use of ethanol fuels in the AeroConversions AeroVee 2.0 engine and developing other enhancements to the AeroVee, improving its already-impressive efficiency. Sonex partnered with Wisconsin-based Renew Fuel Stations, a distributor of E85, a blend of up to 85 percent ethanol and 15 percent gasoline, to develop an AeroVee engine configuration that can use the fuel. Renew’s interest in the project is expansion of the market for ethanol fuels. Testing is under way right now. The idea of electric flight is not new to Sonex. It dates back to 1994 when Monnett and Buck looked into the possibility of building an electric plane specifically for the purpose of establishing speed records for a new class of aircraft. Although the project was deemed to be practical, Sonex put the project aside to further develop its current set of kit airplanes and to support their customers. The company is committed to completing the effort this time, though Monnett stated firmly that the e-Flight program will never detract from Sonex’s commitment to its customers. Sonex is financing the entire effort itself. Once production systems are available, Sonex plans to make them available to the experimental market for installation on other airframes. Sonex will present a forum on the e-Flight project Wednesday at 11:00 a.m. in Forum Building 11. More information about the project is available on the web at www.AeroConversions.com/E-Flight. ================================================= ========= The RAeS General Aviation Group aims to encourage the development of light aviation through the promotion of technologies, in particular those that minimise its impact upon the environment. The 2007-8 design competition therefore offers awards for technical developments that can include: • whole aircraft design • propulsion • operational methods • specific technologies within the aircraft. The competition is open to any individual or group; entries are particularly encouraged from teams from educational institutions or RAeS corporate members. Entries should be received by Friday 2 May 2008 and consist firstly of a 10 page report , showing how it works, its benefits both to light aviation and to the environment, and who is responsible for the entry. A shortlist of entrants will then be selected, who will be invited to give a 20 minute presentation at a special event at RAeS Headquarters in London during mid June 2008. At that event, a judging panel will select the final winning entries; prizes and final award categories will be announced nearer to the entry deadline. Judging criteria will be based upon feasibility, originality, reduction of impact upon the environment and the potential benefits to light aviation overall. Final presentations will also be judged on presentation quality and response to questioning. The judging panel will consist of highly qualified light aviation professionals – including representatives from industry, regulatory authorities and academia. Further Details: General Aviation Group Royal Aeronautical Society No.4 Hamilton Place London, W1J 7BQ, UK |
#183
Here is news of a 48 minute flight in the Alps by what appears to be a
conventional single-place aircraft: http://www.apame.eu/AA%20Projects.html ASSOCIATION POUR LA PROMOTION DES AERONEFS A MOTORISATION ELECTRIQUE WORLDWIDE PREMIE FIRST AIRCRAFT FLIGHT WITH ELECTRICAL ENGINE On Sunday December 23rd [2007] at 11:50 am took place the first flight of the Electra F-WMDJ, equipped with electrical engine of 25cv and Lithium polymer batteries. ... his 48 minutes flight over more than 50 kilometers realized in closed circuit is the world premiere flight of this type. Photos... This new silicon nanowire technology claims to produce ten times the amount of electricity of existing lithium-ion cells. It could be the enabling technology for electric aircraft, not to mention what it might do for automobiles: http://news-service.stanford.edu/new...re-010908.html Stanford Report, December 18, 2007 Stanford's nanowire battery holds 10 times the charge of existing ones BY DAN STOBER Stanford researchers have found a way to use silicon nanowires to reinvent the rechargeable lithium-ion batteries that power laptops, iPods, video cameras, cell phones, and countless other devices. The new version, developed through research led by Yi Cui, assistant professor of materials science and engineering, produces 10 times the amount of electricity of existing lithium-ion, known as Li-ion, batteries. A laptop that now runs on battery for two hours could operate for 20 hours, a boon to ocean-hopping business travelers. "It's not a small improvement," Cui said. "It's a revolutionary development." The breakthrough is described in a paper, "High-performance lithium battery anodes using silicon nanowires," published online Dec. 16 in Nature Nanotechnology, written by Cui, his graduate chemistry student Candace Chan and five others. The greatly expanded storage capacity could make Li-ion batteries attractive to electric car manufacturers. Cui suggested that they could also be used in homes or offices to store electricity generated by rooftop solar panels. "Given the mature infrastructure behind silicon, this new technology can be pushed to real life quickly," Cui said. ... |
#184
![]() Additional information: Characteristics of the apparatus: Single-seater Scale: 9 m Length: 7 m Empty weight without motorization: 115 kg Maximum permissible weight on takeoff: 265 kg Cruising speed: 90 km/h Smoothness: 13 Standard construction drink & fabric Electric power unit: Engine with standard D.C. current "brush" industrial of 18 kw (25 HP) Electronics of power developed specifically for this use Batteries Polymeric – Lithium (total mass: 47 kg) Propeller with adjustable step on ground ARPLAST adapted to this motorization Dashboard, power control, engine mount, driving flask, etc… developed and realized specifically for this apparatus Aircraft specs and information: http://air.souris.set.free.fr/engl/Index_eng.htm On Mon, 31 Dec 2007 20:19:55 GMT, Larry Dighera wrote in : Here is news of a 48 minute flight in the Alps by what appears to be a conventional single-place aircraft: http://www.apame.eu/AA%20Projects.html ASSOCIATION POUR LA PROMOTION DES AERONEFS A MOTORISATION ELECTRIQUE WORLDWIDE PREMIE FIRST AIRCRAFT FLIGHT WITH ELECTRICAL ENGINE On Sunday December 23rd [2007] at 11:50 am took place the first flight of the Electra F-WMDJ, equipped with electrical engine of 25cv and Lithium polymer batteries. ... his 48 minutes flight over more than 50 kilometers realized in closed circuit is the world premiere flight of this type. Photos... This new silicon nanowire technology claims to produce ten times the amount of electricity of existing lithium-ion cells. It could be the enabling technology for electric aircraft, not to mention what it might do for automobiles: http://news-service.stanford.edu/new...re-010908.html Stanford Report, December 18, 2007 Stanford's nanowire battery holds 10 times the charge of existing ones BY DAN STOBER Stanford researchers have found a way to use silicon nanowires to reinvent the rechargeable lithium-ion batteries that power laptops, iPods, video cameras, cell phones, and countless other devices. The new version, developed through research led by Yi Cui, assistant professor of materials science and engineering, produces 10 times the amount of electricity of existing lithium-ion, known as Li-ion, batteries. A laptop that now runs on battery for two hours could operate for 20 hours, a boon to ocean-hopping business travelers. "It's not a small improvement," Cui said. "It's a revolutionary development." The breakthrough is described in a paper, "High-performance lithium battery anodes using silicon nanowires," published online Dec. 16 in Nature Nanotechnology, written by Cui, his graduate chemistry student Candace Chan and five others. The greatly expanded storage capacity could make Li-ion batteries attractive to electric car manufacturers. Cui suggested that they could also be used in homes or offices to store electricity generated by rooftop solar panels. "Given the mature infrastructure behind silicon, this new technology can be pushed to real life quickly," Cui said. ... |
Electrically Powered Ultralight Aircraft | Larry Dighera | Piloting | 178 | December 31st 07 08:53 PM |
Electrically Powered Ultralight Aircraft | Larry Dighera | Home Built | 191 | August 21st 07 12:29 AM |
World's First Certified Electrically Propelled Aircraft? | Larry Dighera | Piloting | 2 | September 22nd 06 01:50 AM |
Powered gliders = powered aircraft for 91.205 | Mark James Boyd | Soaring | 2 | December 12th 04 03:28 AM |
Help! 2motors propelled ultralight aircraft | [email protected] | Home Built | 3 | July 9th 03 01:02 AM |
