#11
On Thu, 3 Jan 2008 21:28:16 -0800, "BT" wrote:
mmm.. I'd be interested to know the reference for "that reg"... cause they don't pay attention to it around here. You ask, you get: FAA Order 7110.65R (the ATC 'bible') Section 9 "Class B Service Area, Terminal", para 7-9-3b. Currently they have to vector aircraft outside the Class B and back in; with the extension they won't have to. Please read the NOTE under b...this means they should be keeping the aircraft at or above 5000'MSL/4200' AGL in our area....actually a BENEFIT to us. FYI, a "large turbine aircraft" is over 12,500 lbs...even a Beech 1900 is well over that... ------------------------------------------------------------------------------------------------ 7-9-3. METHODS a. To the extent practical, clear large turbine engine-powered airplanes to/from the primary airport using altitudes and routes that avoid VFR corridors and airspace below the Class B airspace floor where VFR aircraft are operating. NOTE- Pilots operating in accordance with VFR are expected to advise ATC if compliance with assigned altitudes, headings, or routes will cause violation of any part of the CFR. b. Vector aircraft to remain in Class B airspace after entry. Inform the aircraft when leaving and reentering Class B airspace if it becomes necessary to extend the flight path outside Class B airspace for spacing. NOTE- 14 CFR Section 91.131 states that “Unless otherwise authorized by ATC, each person operating a large turbine engine-powered airplane to or from a primary airport for which a Class B airspace area is designated must operate at or above the designated floors of the Class B airspace area while within the lateral limits of that area.” Such authorization should be the exception rather than the rule. REFERENCE FAAO 7110.65, Deviation Advisories, Para 5-1-10. c. Aircraft departing controlled airports within Class B airspace will be provided the same services as those aircraft departing the primary airport. I brought it up at a safety meeting with ATC Radar supervisor in attendance.. and was told point blank.. we put them where we need to. That's what what they do NOW, but once they have the extension, apparently they will be keeping the RJs at 5K MSL overhead vs 3K MSL (right in with the gliders) now. I "was around" when the first "Terminal Control Areas", (TCA) now Class B were designed.. the idea was that airliners and "jets" would enter in the top and funnel down to the primary airport.. they would also exit out the top. Does not happen.. Sounds like they are going back to that idea The fuel conservation descents start the glide farther out.. instead of "keep'em high and drop'em in".. When landing Rwy 1 at LAS, the min Radar Vector Altitude is about 8300 right over our airport and that's where they want to be. Class B there is 80B90 but they continue the descent down out of the bottom of Class B. Or they have been vectored from the northeast and exit the Class B only to reenter at the 20nm fix on final right over the glider airport. Another stated reason for the change...they want 'em to enter the Bravo ONCE and never leave til they take off again. ALPA is pushing this...they want that extra "protected airspace" The Glide Slope into LAS Rwy 1 is 3.4 degree, at 361ft per nm, 20 nm = 7220 AGL, LAS elevation is 2181, so that equates to about 9400MSL at the Class B entry.. but ATC always has them 1000ft lower. And if ATC lets them fly a "Visual Approach, they get down to 7K MSL. The CLE Rwy6 ILS is a 3 degree glide slope or 318ft / nm, or at 20nm, 6360 AGL, CLE airport elev is 791MSL or at 20nm on a 3 degree glide path the airliner would like to be at about 7100ft MSL and at 30nm at 10300MSL... so why do they need a 50B80 all the way out to 30nm? Considering they are dropping the RJ's down to 3K MSL at 20+ miles out now, I figure it's for a little extra elbow room during VFR ops, + room needed to 'set up' for PRM approach or staggered simultaneous ILS to our close-spaced runways.. --Don Don Byrer KJ5KB Radar Tech & Smilin' Commercial Pilot Guy Glider & CFI wannabe kj5kb-at-hotmail.com "I have slipped the surly bonds of earth; now if I can just land without bending the gear..." "Watch out for those doves...smack-smack-smack-smack..." |
Thanx for digging that out.
Ahh... read the fine print in 7-9-3b... "if it becomes necessary" they can vector the aircraft out of the ClassB, they just have to tell the pilot being vectored that they will be exiting the "Class B protection zone", and of course they don't have to tell the pilot not talking to them that is already outside of and avoiding the "Class B exclusion zone". FWIW.. I used to live and die by 7110.65.. but it was a much earlier alpha suffix.. like "C".. and it has been over 25 years.. We negotiated a waiver to 91.215 for glider operations (climb windows) within the 30nm ModeC Veil, outside Class B, but above the ceiling of ClassB, to get above 10,000 MSL BT USAF RET Comm, ASEL, AMEL, Instrument CFIG "Don Byrer" wrote in message ... On Thu, 3 Jan 2008 21:28:16 -0800, "BT" wrote: mmm.. I'd be interested to know the reference for "that reg"... cause they don't pay attention to it around here. You ask, you get: FAA Order 7110.65R (the ATC 'bible') Section 9 "Class B Service Area, Terminal", para 7-9-3b. Currently they have to vector aircraft outside the Class B and back in; with the extension they won't have to. Please read the NOTE under b...this means they should be keeping the aircraft at or above 5000'MSL/4200' AGL in our area....actually a BENEFIT to us. FYI, a "large turbine aircraft" is over 12,500 lbs...even a Beech 1900 is well over that... ------------------------------------------------------------------------------------------------ 7-9-3. METHODS a. To the extent practical, clear large turbine engine-powered airplanes to/from the primary airport using altitudes and routes that avoid VFR corridors and airspace below the Class B airspace floor where VFR aircraft are operating. NOTE- Pilots operating in accordance with VFR are expected to advise ATC if compliance with assigned altitudes, headings, or routes will cause violation of any part of the CFR. b. Vector aircraft to remain in Class B airspace after entry. Inform the aircraft when leaving and reentering Class B airspace if it becomes necessary to extend the flight path outside Class B airspace for spacing. NOTE- 14 CFR Section 91.131 states that "Unless otherwise authorized by ATC, each person operating a large turbine engine-powered airplane to or from a primary airport for which a Class B airspace area is designated must operate at or above the designated floors of the Class B airspace area while within the lateral limits of that area." Such authorization should be the exception rather than the rule. REFERENCE FAAO 7110.65, Deviation Advisories, Para 5-1-10. c. Aircraft departing controlled airports within Class B airspace will be provided the same services as those aircraft departing the primary airport. I brought it up at a safety meeting with ATC Radar supervisor in attendance.. and was told point blank.. we put them where we need to. That's what what they do NOW, but once they have the extension, apparently they will be keeping the RJs at 5K MSL overhead vs 3K MSL (right in with the gliders) now. I "was around" when the first "Terminal Control Areas", (TCA) now Class B were designed.. the idea was that airliners and "jets" would enter in the top and funnel down to the primary airport.. they would also exit out the top. Does not happen.. Sounds like they are going back to that idea The fuel conservation descents start the glide farther out.. instead of "keep'em high and drop'em in".. When landing Rwy 1 at LAS, the min Radar Vector Altitude is about 8300 right over our airport and that's where they want to be. Class B there is 80B90 but they continue the descent down out of the bottom of Class B. Or they have been vectored from the northeast and exit the Class B only to reenter at the 20nm fix on final right over the glider airport. Another stated reason for the change...they want 'em to enter the Bravo ONCE and never leave til they take off again. ALPA is pushing this...they want that extra "protected airspace" The Glide Slope into LAS Rwy 1 is 3.4 degree, at 361ft per nm, 20 nm = 7220 AGL, LAS elevation is 2181, so that equates to about 9400MSL at the Class B entry.. but ATC always has them 1000ft lower. And if ATC lets them fly a "Visual Approach, they get down to 7K MSL. The CLE Rwy6 ILS is a 3 degree glide slope or 318ft / nm, or at 20nm, 6360 AGL, CLE airport elev is 791MSL or at 20nm on a 3 degree glide path the airliner would like to be at about 7100ft MSL and at 30nm at 10300MSL... so why do they need a 50B80 all the way out to 30nm? Considering they are dropping the RJ's down to 3K MSL at 20+ miles out now, I figure it's for a little extra elbow room during VFR ops, + room needed to 'set up' for PRM approach or staggered simultaneous ILS to our close-spaced runways.. --Don Don Byrer KJ5KB Radar Tech & Smilin' Commercial Pilot Guy Glider & CFI wannabe kj5kb-at-hotmail.com "I have slipped the surly bonds of earth; now if I can just land without bending the gear..." "Watch out for those doves...smack-smack-smack-smack..." |
Recreational and business pilots in the Chicago area were recently
informed that the current 20-25 NM radius B-airspace is proposed to be increased all the way to the 30NM transponder veil. Comments can be filed until January 12. The 3 area glider clubs will be impacted with one club being located 28 NM from O'Hare. The floor of the B-airspace will be at 4,000 MSL if this proposal should pass. Interestingly, the justifications heard for this change match exactly the points stated here already. Pilot members of our clubs that are flying into Chicago City airports regularly report that ATC is specifically advising them when exiting and re-entering B airspace - obviously establishing records for having to do so. Our course of action will most likely be a petition to carve out a sector over the affected glider port or/and to request for the floor of the outside ring to be raised to 5,000'. In any case, we will loose quite a few of the current Northern Illinois turnpoints. Question: Anyone knows how ATC reacts to requests to briefly transition B-airspace on the outside border (transponder equipped glider)? Many of our local gliders fly with transponders. Herb Kilian, J7 |
On Fri, 4 Jan 2008 09:20:15 -0800, "BT" wrote:
Thanx for digging that out. Quite welcome...I'm sure others would like to see it anyway. Ahh... read the fine print in 7-9-3b... "if it becomes necessary" they can vector the aircraft out of the ClassB, they just have to tell the pilot being vectored that they will be exiting the "Class B protection zone", and of course they don't have to tell the pilot not talking to them that is already outside of and avoiding the "Class B exclusion zone". Yes....and that's what I'm told they are trying to avoid. That's two extra exchanges btwn pilot and controller they'd like to eliminate. We negotiated a waiver to 91.215 for glider operations (climb windows) within the 30nm ModeC Veil, outside Class B, but above the ceiling of ClassB, to get above 10,000 MSL This isnt a big 'climb' area ![]() Also, many of the guys around here that are serious soarers have their own glider with synthesized radio, and a few have xponders. For now, I'm a 'fun flyer' til I get my ticket...and even then I suspect I will be happy with 1 hour flights in the club gliders; at least in this area...my butt is only rated for 60 minutes in a blanik L13. --Don Don Byrer KJ5KB Radar Tech & Smilin' Commercial Pilot Guy Glider & CFI wannabe kj5kb-at-hotmail.com "I have slipped the surly bonds of earth; now if I can just land without bending the gear..." "Watch out for those doves...smack-smack-smack-smack..." |
On Fri, 4 Jan 2008 10:06:21 -0800 (PST), Herb
wrote: Recreational and business pilots in the Chicago area were recently informed that the current 20-25 NM radius B-airspace is proposed to be increased all the way to the 30NM transponder veil. Comments can be filed until January 12. The 3 area glider clubs will be impacted with one club being located 28 NM from O'Hare. The floor of the B-airspace will be at 4,000 MSL if this proposal should pass. ouch... Interestingly, the justifications heard for this change match exactly the points stated here already. Pilot members of our clubs that are flying into Chicago City airports regularly report that ATC is specifically advising them when exiting and re-entering B airspace - obviously establishing records for having to do so. They REALLY want to decrease workload and frequency congestion...I do understand and agree with that. Question: Anyone knows how ATC reacts to requests to briefly transition B-airspace on the outside border (transponder equipped glider)? Many of our local gliders fly with transponders. I would think it to be the same as transitioning it in any slow small power plane. You have a radio and a transponder...if "UNABLE " they will tell ya. Will also depend on where you are in relation to traffic flow too. I can probably get cleared to buzz around all day at 3K MSL NW of CLE, as the primary traffic flow is NE/SW... Around here (CLE), in a C172, if you call up for flight following they'll usually clear you into the Bravo, and vector you clear of traffic. --Don Don Byrer KJ5KB Radar Tech & Smilin' Commercial Pilot Guy Glider & CFI wannabe kj5kb-at-hotmail.com "I have slipped the surly bonds of earth; now if I can just land without bending the gear..." "Watch out for those doves...smack-smack-smack-smack..." |
On Jan 4, 4:27*pm, Don Byrer wrote:
On Fri, 4 Jan 2008 10:06:21 -0800 (PST), Herb wrote: Recreational and business pilots in the Chicago area were recently informed that the current 20-25 NM radius B-airspace is proposed to be increased all the way to the 30NM transponder veil. * Don - SSA got the notice on December 31, to invite glider folks to the meetings. It was passed to local folks in a matter of hours. The Botsford club Pres. has had a conversation with me on Friday, and he has a pile of information to share at the Saturday club meeting on various items to do and how to collect data to help thwart the shelf. You will be quite a resource to Bruce, there. The best way to get the outcome you want is to bash them with their own protocols. Cleveland may be a pile of work,and it may not get a perfect outcome, but it seems I am having to type a lot on Airspace issues for SSA members this month. Cleveland and Chicago have a Class B change,, and a MOA in Nevada, and the ADS-B NPRM. I will post more on RAS later to get the keyboardists in line to file comments as needed. Thanks, Cindy B |
Who is Cindy B???
Mike Schumann "CindyB" wrote in message ... On Jan 4, 4:27 pm, Don Byrer wrote: On Fri, 4 Jan 2008 10:06:21 -0800 (PST), Herb wrote: Recreational and business pilots in the Chicago area were recently informed that the current 20-25 NM radius B-airspace is proposed to be increased all the way to the 30NM transponder veil. Don - SSA got the notice on December 31, to invite glider folks to the meetings. It was passed to local folks in a matter of hours. The Botsford club Pres. has had a conversation with me on Friday, and he has a pile of information to share at the Saturday club meeting on various items to do and how to collect data to help thwart the shelf. You will be quite a resource to Bruce, there. The best way to get the outcome you want is to bash them with their own protocols. Cleveland may be a pile of work,and it may not get a perfect outcome, but it seems I am having to type a lot on Airspace issues for SSA members this month. Cleveland and Chicago have a Class B change,, and a MOA in Nevada, and the ADS-B NPRM. I will post more on RAS later to get the keyboardists in line to file comments as needed. Thanks, Cindy B -- Posted via a free Usenet account from http://www.teranews.com |
Cindy Brickner from Cal City.
On Jan 5, 3:04*pm, "Mike Schumann" wrote: Who is Cindy B??? |
aviationnut wrote:
Cindy Brickner from Cal City. On Jan 5, 3:04 pm, "Mike Schumann" wrote: Who is Cindy B??? Cindy Brickner is also the member of the SSA Government Liaison Committee responsible for airspace matters... Marc |
![]() On Jan 5, 3:04 pm, "Mike Schumann" wrote: Who is Cindy B??? Cindy Brickner is also the member of the SSA Government Liaison Committee responsible for airspace matters... Marc Hey, don't forget that Cindy is also a regional director on the board of the SSA and has been for a long time, she also was a speaker at many conventions, and at least year's convention, to celebrate the 75th anniversary of the SSA, she hosted a very well attended session on "generations" in soaring. She's the Bomb in Soaring! (isn't that what the kids say, when someone or something is really really cool?) |
Bravo | Mal[_3_] | Aviation Photos | 0 | March 15th 07 02:47 AM |
Orlando Class Bravo | Ehvee8or | Piloting | 5 | April 12th 05 11:41 PM |
Lost comm while VFR in Class Bravo | Roy Smith | General Aviation | 10 | April 23rd 04 11:12 PM |
Is type BE35 or Bravo Echo 35? | Peter R. | Piloting | 3 | March 4th 04 05:37 AM |
Aw Shits and Bravo Zulus | Gordon | Naval Aviation | 31 | December 9th 03 10:42 PM |
