On Jan 13, 5:33 pm, wrote:
Mat, training yourself to use an AOA indicator takes about 30 seconds - it's really obvious. Training to use the ASI for pitch attitude without reference to the visible horizon takes many hours of intensive training and even then most pilots don't do it well. AOA indicators are about reducing information overload, not increasing it. An AOA indicator IS a stall warning with far greater resolution. The EASY way to fly is with an AOA. The HARD way is to do without it. . Bill Daniels So, we are talking about pitch attitude control without reference to the visible horizon. In that situation how do we control roll and yaw? The same way as we control roll and yaw in normal flight, since we don't need a horizon to do this. Roll can be detected as long as there is a reference in the distance we can see we are rolling with respect to, and yaw can be detected using a yaw string or slip ball. Balanced bank will always produce a turn, which can of course be seen as the reference surface moving past the nose. |
wrote in message ... Mat, training yourself to use an AOA indicator takes about 30 seconds - it's really obvious. Training to use the ASI for pitch attitude without reference to the visible horizon takes many hours of intensive training and even then most pilots don't do it well. AOA indicators are about reducing information overload, not increasing it. An AOA indicator IS a stall warning with far greater resolution. The EASY way to fly is with an AOA. The HARD way is to do without it. . Bill Daniels So, we are talking about pitch attitude control without reference to the visible horizon. In that situation how do we control roll and yaw? I wrote a confusing line. It should have said "controlling AOA with the ASI and no relaible horizon is difficult." By saying, "Attempting to use aircraft attitude (deck angle) without a reliable horizon will get you killed real fast" do you mean attempting to CONTROL attitude, or attempting to DETERMINE aircraft attitude? Does it matter? If you can't detemine attitude, you can't control it. Bill D Obviously, if you can't DETERMINE attitude, you can't CONTROL it. |
So, we are talking about pitch attitude control without reference to the visible horizon. *In that situation how do we control roll and yaw? The same way as we control roll and yaw in normal flight, since we don't need a horizon to do this. Roll can be detected as long as there is a reference in the distance we can see we are rolling with respect to, and yaw can be detected using a yaw string or slip ball. Balanced bank will always produce a turn, which can of course be seen as the reference surface moving past the nose.- Hide quoted text - A reference in the distance we can see we are rolling with respect to is, in my expeience, a horizon. It may not be THE horizon but is sufficient to control the aircraft both in pitch and roll. I think Bill is trying to make the point that an AOA indicator would be useful when there is NO horizon. |
On Jan 13, 7:19*pm, "Bill Daniels" bildan@comcast-dot-net wrote:
wrote in message ... Mat, training yourself to use an AOA indicator takes about 30 seconds - it's really obvious. Training to use the ASI for pitch attitude without reference to the visible horizon takes many hours of intensive training and even then most pilots don't do it well. AOA indicators are about reducing information overload, not increasing it. |
So, we are talking about pitch attitude control without reference to the visible horizon. In that situation how do we control roll and yaw? The same way as we control roll and yaw in normal flight, since we don't need a horizon to do this. Roll can be detected as long as there is a reference in the distance we can see we are rolling with respect to, and yaw can be detected using a yaw string or slip ball. Balanced bank will always produce a turn, which can of course be seen as the reference surface moving past the nose.- Hide quoted text - A reference in the distance we can see we are rolling with respect to is, in my expeience, a horizon. It may not be THE horizon but is sufficient to control the aircraft both in pitch and roll. I think Bill is trying to make the point that an AOA indicator would be useful when there is NO horizon. We could call it something catchy, like an "artificial horizon"! Well, maybe that's a simple way to get an attitude indicator that's commercially available for a $1000 or so, solid state so power consumption is low, and easily installed. It might indicate the AOA accurately enough in steady flight for performance optimizing. Anyone tried it? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On 13 Jan, 19:52, "Bill Daniels" bildan@comcast-dot-net wrote:
"Ian" wrote in message Surely most pilots - after their first few flights - are capable of hitting and maintaining a desired speed as shown on the ASI? If you think it's easy, borrow an instrument training hood that blocks your view of the horizon and give it a try. Only in a 2-seater with a safety pilot, of course. Flying without any visual attitude indications is not the same as flying without a horizon. If anything is visible over the nose it's possible to use for feedback on changes in nose position, if not absolute values. In fact, I suspect that that is how most of us do it: using attitude /change/ in combination with ASI to hit a target speed. Very few glider pilots fly without any external reference at all. If that's what you were saying, and I've misunderstood, I'm sorry! So why don't we all have them? Damn good question. And ... ? Ian |
On 13 Jan, 22:15, Eric Greenwell wrote:
1. Which of the commercially available AOA indicators is most suited to a glider? 2. Who is planning to put one in their glider? 3. How do they deal with flaps? Ian |
On 14 Jan, 01:19, "Bill Daniels" bildan@comcast-dot-net wrote:
Does it matter? If you can't detemine attitude, you can't control it. Hmm. Philosophical question, maybe, but it's perfectly possible to control attitude while only knowing airspeed, as my friends who fly in cloud using ASI and T&S do ... Ian |
Ian wrote:
Surely most pilots - after their first few flights - are capable of hitting and maintaining a desired speed as shown on the ASI? Yes, when they have nothing more pressing to think about. and as long the ASI tells them what they think it should be telling them. Flying a sailplane is about as easy as flying gets, and yet there are a half-dozen times a year in the US when it is too much, under the circumstances, for the involved pilots and they meet an untimely end. We should all fly more. The accident numbers might go up, but I think the rates would go down. Jack |
| Anyone Here Ever Seen That Crappy Film Deep Impact? | Michael Baldwin, Bruce[_2_] | Products | 6 | August 21st 07 07:03 AM |
| El Nino impact on NZ soaring | Richard Hanschu | Soaring | 0 | September 14th 04 08:22 AM |
| Impact of noise control efforts on landouts? | nafod40 | Soaring | 9 | May 17th 04 05:28 PM |
| Impact of Eurofighters in the Middle East | Quant | Military Aviation | 164 | October 4th 03 05:33 PM |
| Surgical hardware's impact on a USAF recruit? | Raptor | Military Aviation | 13 | September 15th 03 11:58 AM |
