We need to get a weight and balance done for our Blanik L-13. The
	manuals are not really helpful referring to percentage of MAC (mean aerodynamic chord) for the CG range without saying how much MAC is nor where the reference plane/datum is (probably the wing root rib). I dug up the FAA type certificate that actually uses the "most forward point on fuselage nose" as the datum and specifies the arm for front and back pilot plus the C/G range relative to that datum which should give me all the info needed to do the calculations for minimum single pilot weight etc. Only problem is that the FAA type certificate states that the leveling means for weighing the glider are "between points marked on side of fuselage". Now that is not very helpful either since ours has been painted several times and the manual doesn't make you any wiser either as to where those points are. Does anyone out there know how to establish the proper leveling of the Blanik L-13 when weighing it or has a better method for doing the weight and balance for that glider? Thanks in advance for any help you can provide, Markus Graeber Aeroclub de Colombia  |
I do not have our old copy of the L-13 Manuals handy.. they are out at the
	club. I only have my L-23 manuals here. If I remember correctly there should be two "set screws" or larger than standard rivets along the horizontal rivet line of the fuselage aft of the wing. These reference points should be easily noticed and not trusting to staying with paint. The maintenance manual should have explicit instructions for weighing the L-13. BT "Markus Graeber" wrote in message ... We need to get a weight and balance done for our Blanik L-13. The manuals are not really helpful referring to percentage of MAC (mean aerodynamic chord) for the CG range without saying how much MAC is nor where the reference plane/datum is (probably the wing root rib). I dug up the FAA type certificate that actually uses the "most forward point on fuselage nose" as the datum and specifies the arm for front and back pilot plus the C/G range relative to that datum which should give me all the info needed to do the calculations for minimum single pilot weight etc. Only problem is that the FAA type certificate states that the leveling means for weighing the glider are "between points marked on side of fuselage". Now that is not very helpful either since ours has been painted several times and the manual doesn't make you any wiser either as to where those points are. Does anyone out there know how to establish the proper leveling of the Blanik L-13 when weighing it or has a better method for doing the weight and balance for that glider? Thanks in advance for any help you can provide, Markus Graeber Aeroclub de Colombia  |
At 03:36 22 January 2008, Bt wrote:
	I do not have our old copy of the L-13 Manuals handy.. they are out at the club. I only have my L-23 manuals here. If I remember correctly there should be two 'set screws' or larger than standard rivets along the horizontal rivet line of the fuselage aft of the wing. These reference points should be easily noticed and not trusting to staying with paint. The maintenance manual should have explicit instructions for weighing the L-13. BT 'Markus Graeber' wrote in message . com... We need to get a weight and balance done for our Blanik L-13. The manuals are not really helpful referring to percentage of MAC (mean aerodynamic chord) for the CG range without saying how much MAC is nor where the reference plane/datum is (probably the wing root rib). I dug up the FAA type certificate that actually uses the 'most forward point on fuselage nose' as the datum and specifies the arm for front and back pilot plus the C/G range relative to that datum which should give me all the info needed to do the calculations for minimum single pilot weight etc. Only problem is that the FAA type certificate states that the leveling means for weighing the glider are 'between points marked on side of fuselage'. Now that is not very helpful either since ours has been painted several times and the manual doesn't make you any wiser either as to where those points are. Does anyone out there know how to establish the proper leveling of the Blanik L-13 when weighing it or has a better method for doing the weight and balance for that glider? Thanks in advance for any help you can provide, Markus Graeber Aeroclub de Colombia These set screws must be the datum points. See the BGA datasheet for the Blanik L-13 http://www.gliding.co.uk/bgainfo/tec...ets/blanik.pdf Gavin Std Cirrus, CNN now G-SCNN, #173  |
Use the "Top of rear fuselage tail down 1000:51". It is a good idea to
	cut this angle out of cardboard or plywood and keep it for future W&B purposes. The Standard Jantar manual tells us to "level the cord line". OK, fine, now how do we do that? The only way I could figure was to make a full template from a large piece of cardboard, made to fit the root rib with wing removed, then scribe the cord line (exact leading edge to trailing edge).Then raise this cord line 8" and mark a "raised" cord on top of the template. Then cut along the raised cord line, so's I had a place to put my bubble level. Assemble the bird, slip on the template, raise the tail to achieve bubble level on the "raised" cord line. Wow, thanks for making it sooooo easy PZL. After going through all this........................make a simple triangle to go on the top aft boom, that shows bubble level when the ship is in the proper position. JJ  |
On Jan 22, 1:05*am, Gavin Short
	wrote: At 03:36 22 January 2008, Bt wrote: I do not have our old copy of the L-13 Manuals handy.. they are out at the club. I only have my L-23 manuals here. If I remember correctly there should be two 'set screws' or larger than standard rivets along the horizontal rivet line of the fuselage aft of the wing. These reference points should be easily noticed and not trusting to staying with paint. The maintenance manual should have explicit instructions for weighing the L-13. BT 'Markus Graeber' *wrote in message . com... We need to get a weight and balance done for our Blanik L-13. The manuals are not really helpful referring to percentage of MAC (mean aerodynamic chord) *for the CG range without saying how much MAC is nor where the reference plane/datum is (probably the wing root rib). I dug up the FAA type certificate that actually uses the 'most forward point on fuselage nose' as the datum and specifies the arm for front and back pilot plus the C/G range relative to that datum which should give me all the info needed to do the calculations for minimum single pilot weight etc. Only problem is that the FAA type certificate states that the leveling means for weighing the glider are 'between points marked on side of fuselage'. Now that is not very helpful either since ours has been painted several times and the manual doesn't make you any wiser either as to where those points are. Does anyone out there know how to establish the proper leveling of the Blanik L-13 when weighing it or has a better method for doing the weight and balance for that glider? Thanks in advance for any help you can provide, Markus Graeber Aeroclub de Colombia These set screws must be the datum points. *See the BGA datasheet for the Blanik L-13 *http://www.gliding.co.uk/bgainfo/tec...ets/blanik.pdf Gavin Std Cirrus, CNN now G-SCNN, #173- Hide quoted text - - Show quoted text - I love it... "1000:51 at top of aft fuselage". Not 20:1 or anything simple like that. "Okay George, up on the tail about 2MM. Wait... no, down a 1MM. Nope, nope back up 1MM... "  |
Actually, it doesn't make any difference. Just put a mark on the fufelage,
	and put a 5.1mm drill 100mm aft the mark. Place bubble level on the drill, with one edge resting on the mark. Oh, only got drills sized in inches in your workshop ?... Bert "Papa3" wrote in message ... - Show quoted text - I love it... "1000:51 at top of aft fuselage". Not 20:1 or anything simple like that. "Okay George, up on the tail about 2MM. Wait... no, down a 1MM. Nope, nope back up 1MM... "  |
On Jan 22, 7:24 am, Papa3  wrote:
	I love it... "1000:51 at top of aft fuselage". Not 20:1 or anything simple like that. "Okay George, up on the tail about 2MM. Wait... no, down a 1MM. Nope, nope back up 1MM... " Um... Get a 1 meter long stick (metric yardstick?), set it on top if the fuselage, raise rear end 51mm and viola! -Tom  |
On Jan 22, 9:42*am, "Bert Willing" bw_no_spam_ple...@tango-
	whisky.com wrote: Actually, it doesn't make any difference. Just put a mark on the fufelage, and put a 5.1mm drill 100mm aft the mark. Place bubble level on the drill, with one edge resting on the mark. Oh, only got drills sized in inches in your workshop ?... Bert "Papa3" wrote in message ... - Show quoted text - I love it... "1000:51 at top of aft fuselage". * *Not 20:1 or anything simple like that. * *"Okay George, up on the tail about 2MM. *Wait.... no, down a 1MM. * Nope, nope back up 1MM... " Okay, maybe should have included the :-) But, since we're all so serious, someone with a Blanik go calculate the difference that .1MM makes given the mass of the beast. Then, eliminate the calibaration errors in scales, location of the seat belt buckles, inflation of the oleo (which will change the angle with the tail wheel) yadda yadda yadda. I think the point was the level of precision implied by 1000:51 is laughable given the realities of conducting a W&B Cheers, Erik  |
Thanks for everybody who has responded, especially Dick and Tim who
	sent me photos and a W&B sheet. I wasn't able to actually find the dimples that mark the level plane on either side of the fuselage so I ended up using the info in the BGA data sheet and leveled the aft fuselage to 1000:51 downwards (1000mm:51mm level - and yeah, it was exactly 5.1 mm down as in the diameter of a twig ;-) using the tip of the nose cone as the reference datum (to hell with the MAC, wherever it is supposed to be...) and the data for the arms contained in the US Type Certificate (which specifies the arm for front & back pilot as well as for the baggage compartment). Turns out that our min single pilot weight went up from the original 68 kg to now 72 kg to stay within the CG range, probably largely to the sturdy tail wheel with aluminum fairing the club had mounted on the tail a long time ago in lieu of the joke that came from the factory. Thanks again everybody for helping to get this sorted out quickly. Markus  |
El lunes, 21 de enero de 2008, 20:26:45 (UTC-3), Markus Graeber  escribió:
	We need to get a weight and balance done for our Blanik L-13. The manuals are not really helpful referring to percentage of MAC (mean aerodynamic chord) for the CG range without saying how much MAC is nor where the reference plane/datum is (probably the wing root rib). I dug up the FAA type certificate that actually uses the "most forward point on fuselage nose" as the datum and specifies the arm for front and back pilot plus the C/G range relative to that datum which should give me all the info needed to do the calculations for minimum single pilot weight etc. Only problem is that the FAA type certificate states that the leveling means for weighing the glider are "between points marked on side of fuselage". Now that is not very helpful either since ours has been painted several times and the manual doesn't make you any wiser either as to where those points are. Does anyone out there know how to establish the proper leveling of the Blanik L-13 when weighing it or has a better method for doing the weight and balance for that glider? Thanks in advance for any help you can provide, Markus Graeber Aeroclub de Colombia Do you have a data for L23 weight and balance? thanks!!  |
| Thread Tools | |
| Display Modes | |
| PA-32 Weight and Balance | John Doe | Owning | 14 | May 23rd 06 02:03 AM |
| L23 weight and balance | Tony Verhulst | Soaring | 5 | December 31st 05 02:54 AM |
| Weight & Balance DVD | jon | Home Built | 0 | October 8th 05 06:39 PM |
| Weight and Balance | Dale Larsen | Home Built | 2 | June 23rd 04 06:11 PM |
| Weight and balance.. | Bart | Rotorcraft | 9 | August 19th 03 03:57 AM |
