#71
"Gig 601XL Builder" wrote in message ... WingFlaps wrote: I see your point and I think it's a good one. As I said before, I smell the rat of marketing... Cheers You keep want to blame Marketing. Sure they may have said we need to have an easy to use FADEC system but it was the engineers that decided not to have the limp home mode. So, how would you arrange a "limp home" mode that avoided a low volts problem, with electronic fuel injectors? If you go to mechanical injectors, you lose the advantages inherent in the electronic ones. The only way, I can think of, is to add sources of power. Al G |
#72
Thomas Borchert wrote in
: Gig, Sure they may have said we need to have an easy to use FADEC system but it was the engineers that decided not to have the limp home mode. In a way, they do (if not in the way it used to be installed in the DA42): the emergency battery. I guess what I'm trying to say is: This engine is different than the old Lycs and TCMs. Doesn't mean it's worse. Just different. Nope It's worse. Bertie |
#73
Al,
So, how would you arrange a "limp home" mode that avoided a low volts problem, with electronic fuel injectors? If you go to mechanical injectors, you lose the advantages inherent in the electronic ones. Ah, thank you! Of course, as Bertie puts it, one could theoretically build alternative injectors in, I guess. One could also plate the engine with gold. But, as you say, an engine with electronic fuel injectors is an engine with ELECTRONIC fuel injectors. The basis for the engine is a mass-production car engine. That's what makes (may make) the engine viable in the market. And I still fail to see how "mechanical" would somehow inherently be better or more relaible than "electric". In fact, a common rail diesel has a much simpler mechanical design than one with mechanical injectors - it is much less prone to failure in that respect. Interestingly, the SMA diesel is of the old style, with mechanical injectors. It also has a mechanical emergency throttle. It also has gained zero traction in the market, in large part due to its high price. -- Thomas Borchert (EDDH) |
#74
: Al, So, how would you arrange a "limp home" mode that avoided a low volts problem, with electronic fuel injectors? If you go to mechanical injectors, you lose the advantages inherent in the electronic ones. Ah, thank you! Of course, as Bertie puts it, one could theoretically build alternative injectors in, Where did I say that you uberfjukktard? Bertie |
#75
I'm never going to agree to a Diesel in an airplane unless they fix this nonsense about it stopping when the tanks are empty. Do you want to bet on such a flawed concept? -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
#76
David Lesher wrote in news:fp4ipr$q92$2
@reader2.panix.com: I'm never going to agree to a Diesel in an airplane unless they fix this nonsense about it stopping when the tanks are empty. Which tank? the liquid or the electron one? bertie |
#77
On Feb 16, 4:53*am, Gig 601XL Builder
wrote: WingFlaps wrote: I see your point and I think it's a good one. As I said before, I smell the rat of marketing... Cheers You keep want to blame Marketing. Sure they may have said we need to have an easy to use FADEC system but it was the engineers that decided not to have the limp home mode. Interesting. Why would engineers decide that? Cheers |
#78
Peter wrote in
: Thomas Borchert wrote Why is it that each and every innovation in GA is met by people spouting OWTs and made-up speculation, when a minute or two of simple research would provide the facts? What picture does that paint of the pilot population and their "hangar talk"? How about a simple "I don't know and that's why I keep quiet on this" instead of spouting made-up negatives? Sorry, but this is really annoying. You need to calm down Thomas before jumping on people like this. Dunno, I kinda like him this way. Pounding on his keyboard, teeth gritted, veins standing out on his neck. Standing on tiptoe, even though seated, his leg muscles trembling. It's a good look for him. Bertie |
#79
On Feb 16, 6:28*am, Thomas Borchert
wrote: . And I still fail to see how "mechanical" would somehow inherently be better or more relaible than "electric". In fact, a common rail diesel has a much simpler mechanical design than one with mechanical injectors - it is much less prone to failure in that respect. I don't think that's true. Look at the reliability of non-common rail (old) diesels. Very high injection pressures give better atomization but the piezos and nozzles take a hammering and ceramics do break. Cheers |
#80
WingFlaps wrote:
On Feb 16, 4:53 am, Gig 601XL Builder wrote: WingFlaps wrote: I see your point and I think it's a good one. As I said before, I smell the rat of marketing... Cheers You keep want to blame Marketing. Sure they may have said we need to have an easy to use FADEC system but it was the engineers that decided not to have the limp home mode. Interesting. Why would engineers decide that? Cheers Why would marketing? |
| Thread Tools | |
| Display Modes | |
| Thielert (Diesel Engines) | Charles Talleyrand | Piloting | 108 | February 19th 08 05:59 PM |
| diesel 160-200HP engines | geo | Home Built | 27 | April 2nd 04 05:27 PM |
| Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Home Built | 3 | September 13th 03 01:44 AM |
| Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | General Aviation | 2 | September 13th 03 01:44 AM |
| Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Rotorcraft | 2 | September 13th 03 01:44 AM |
