#71
On Feb 16, 2:08*am, Bertie the Bunyip wrote:
WingFlaps wrote : On Feb 15, 9:32*am, Bertie the Bunyip wrote: WingFlaps wrote in news:043b8c97-e1d9-463a-9d5f- : On Feb 15, 12:31*am, "John" wrote: No there are no regulations for climb or descent rates for VFR flight. *Only true as long as you don't bust airspace or aircraft operating limitations... Well, neither one has much to do with a vertical speed limit. A dive which goes over Vne? Well, yes, flight testing for instance. VNE is 10% below a tested dive speed. Alos, as I posted before, some airplanes had an emergency dive speed. Vd. I'd have to look it up to see, though. In any case, it's not a legal limit, it;'s a design limitation. Nope. It's legal from Far 91.7: (a) Except as provided in paragraph (d) of this section, no person may operate a civil aircraft without complying with the operating limitations specified in the approved Airplane or Rotorcraft Flight Manual, markings, and placards, or as otherwise prescribed by the certificating authority of the country of registry. Cheers |
#73
On Feb 16, 4:20 am, "Steven P. McNicoll"
wrote: "WingFlaps" wrote in message ... When NORDO you cannot ascend or descend into controlled space except as part of a flight plan. If the aircraft radio fails in flight under VFR, the pilot in command may operate that aircraft and land if-- (i) Weather conditions are at or above basic VFR weather minimums; (ii) Visual contact with the tower is maintained; and (iii) A clearance to land is received. |
#74
On Feb 16, 4:14Â*am, Mark Hansen wrote:
On 02/15/08 01:53, WingFlaps wrote: On Feb 15, 9:19�am, Gig 601XL Builder wrote: WingFlaps wrote: On Feb 15, 12:31 am, "John" wrote: No there are no regulations for climb or descent rates for VFR flight. |
#75
WingFlaps wrote in
: On Feb 16, 4:14Â*am, Mark Hansen wrote: On 02/15/08 01:53, WingFlaps wrote: On Feb 15, 9:19�am, Gig 601XL Builder wrote: WingFlaps wrote: On Feb 15, 12:31 am, "John" wrote: No there are no regulations for climb or descent rates for VFR fligh t. Err I don't think that's 100% correct but it will do for MX. Cheers Please then for my benefit point me to such a regulation. Certainly. Vne is a limit that must not be exceeded (there are others). This sets a limit on how fast you can legally descend (remember pilots must fly within operating limits). You must also not use ascent or descent rate that put you in conflict with ATC unless you have got clearance. When NORDO you cannot ascend or descend into controlled space except as part of a flight plan. What? You believe that an aircraft with no radio is not allowed to enter controlled airspace without being on a flight plan? Can you please provide a reference to that regulation? Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â*The descent rate at or below 500' must be zero or negative except at an aerodrome or within a LFZ. You can probably now see other examples. Pilots should think outside the box ;-) An towered airport is controlled airspace so: Unless otherwise authorized or required by ATC, no person may operate an aircraft to, from, through, or on an airport having an operational control tower unless two-way radio communications are maintained between that aircraft and the control tower. Communications must be established prior to 4 nautical miles from the airport, up to and including 2,500 feet AGL. However, if the aircraft radio fails in flight, the pilot in command may operate that aircraft and land if weather conditions are at or above basic VFR weather minimums, visual contact with the tower is maintained, and a clearance to land is received. If the aircraft radio fails while in flight under IFR, the pilot must comply with §91.185. Flown nordo into controlled fields loads of times.. Not usually a prob. No flight plan either. Just called the tower by phone before i departed or flew as a flight of two. Bertie |
#76
"WingFlaps" wrote in message ... On Feb 16, 4:20 am, "Steven P. McNicoll" wrote: "WingFlaps" wrote in message ... When NORDO you cannot ascend or descend into controlled space except as part of a flight plan. If the aircraft radio fails in flight under VFR, the pilot in command may operate that aircraft and land if-- (i) Weather conditions are at or above basic VFR weather minimums; (ii) Visual contact with the tower is maintained; and (iii) A clearance to land is received. ? |
#77
"WingFlaps" wrote in message ... On Feb 16, 4:14 am, Mark Hansen wrote: On 02/15/08 01:53, WingFlaps wrote: On Feb 15, 9:19?am, Gig 601XL Builder wrote: WingFlaps wrote: On Feb 15, 12:31 am, "John" wrote: No there are no regulations for climb or descent rates for VFR flight. Err I don't think that's 100% correct but it will do for MX. Cheers Please then for my benefit point me to such a regulation. Certainly. Vne is a limit that must not be exceeded (there are others). This sets a limit on how fast you can legally descend (remember pilots must fly within operating limits). You must also not use ascent or descent rate that put you in conflict with ATC unless you have got clearance. When NORDO you cannot ascend or descend into controlled space except as part of a flight plan. What? You believe that an aircraft with no radio is not allowed to enter controlled airspace without being on a flight plan? Can you please provide a reference to that regulation? The descent rate at or below 500' must be zero or negative except at an aerodrome or within a LFZ. You can probably now see other examples. Pilots should think outside the box ;-) An towered airport is controlled airspace so: Unless otherwise authorized or required by ATC, no person may operate an aircraft to, from, through, or on an airport having an operational control tower unless two-way radio communications are maintained between that aircraft and the control tower. Communications must be established prior to 4 nautical miles from the airport, up to and including 2,500 feet AGL. However, if the aircraft radio fails in flight, the pilot in command may operate that aircraft and land if weather conditions are at or above basic VFR weather minimums, visual contact with the tower is maintained, and a clearance to land is received. If the aircraft radio fails while in flight under IFR, the pilot must comply with §91.185. You shouldn't be playing with your daddy's computer. |
#78
"Steven P. McNicoll" wrote in
: You shouldn't be playing with your daddy's computer. Sorry, but this lame is so past it's sell by date I just couldn't let it go by without comment. Since there has been so much interest in trolling and what it is and ins't these days here's a bit of a primer for those interested in the subject. Any post slyly left to bait an unwitting fjukkwit is technically a troll. So, just about everybody who has ever posted on usenet has trolled at one time or another in whatever modest way. This is a good thing sometimes. Nothing like geting sucked into a trap to wake you up. However a schoolyard taunt is just lame and hardly worthy of the title "troll" and so tarnishes the noble tradition. having said that, lames are OK if they're multi-leveled and/or serve to illuminate another aspect of the discussion. Or if they're funny, of course. Bertie |
#79
On Feb 16, 9:52Â*am, Bertie the Bunyip wrote:
WingFlaps wrote : On Feb 16, 4:14Â*am, Mark Hansen wrote: On 02/15/08 01:53, WingFlaps wrote: On Feb 15, 9:19�am, Gig 601XL Builder wrote: WingFlaps wrote: On Feb 15, 12:31 am, "John" wrote: No there are no regulations for climb or descent rates for VFR fligh t. Err I don't think that's 100% correct but it will do for MX. Cheers Please then for my benefit point me to such a regulation. Certainly. Vne is a limit that must not be exceeded (there are others). This sets a limit on how fast you can legally descend (remember pilots must fly within operating limits). You must also not use ascent or descent rate that put you in conflict with ATC unless you have got clearance. When NORDO you cannot ascend or descend into controlled space except as part of a flight plan. What? You believe that an aircraft with no radio is not allowed to enter controlled airspace without being on a flight plan? Can you please provide a reference to that regulation? Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â*The descent rate at or below 500' must be zero or negative except at an aerodrome or within a LFZ. You can probably now see other examples. Pilots should think outside the box ;-) An towered airport is controlled airspace so: Unless otherwise authorized or required by ATC, no person may operate an aircraft to, from, through, or on an airport having an operational control tower unless two-way radio communications are maintained between that aircraft and the control tower. Communications must be established prior to 4 nautical miles from the airport, up to and including 2,500 feet AGL. However, if the aircraft radio fails in flight, the pilot in command may operate that aircraft and land if weather conditions are at or above basic VFR weather minimums, visual contact with the tower is maintained, and a clearance to land is received. If the aircraft radio fails while in flight under IFR, the pilot must comply with §91.185. Flown nordo into controlled fields loads of times.. Not usually a prob. No flight plan either. Just called the tower by phone before i departed or flew as a flight of two. Yes, in my thinking that call to the tower established a plan. Cheers |
#80
On Feb 16, 10:11*am, Bertie the Bunyip wrote:
"Steven P. McNicoll" wrote : You shouldn't be playing with your daddy's computer. Sorry, but this lame is so past it's sell by date I just couldn't let it go by without comment. Since there has been so much interest in trolling and what it is and ins't these days here's a bit of a primer for those interested in the subject. Any post slyly left to bait an unwitting fjukkwit is technically a troll. So, just about everybody who has ever posted on usenet has trolled at one time or another in whatever modest way. This is a good thing sometimes. Keep up the good work, rattle their cages free from the prattle of mediocrity! Cheers |
| Descent below MDA -- what would you do? | Roy Smith | Instrument Flight Rules | 50 | August 29th 05 01:39 AM |
| ANR squeal on descent | Juan Jimenez | General Aviation | 13 | August 19th 05 11:39 PM |
| descent below minimums | hsm | Instrument Flight Rules | 82 | January 11th 05 07:33 PM |
| BRS and descent rate | Roger Long | Piloting | 21 | May 7th 04 06:34 PM |
| Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 04:22 PM |
