Skidding turns
Old February 20th 08, 11:35 PM posted to rec.aviation.piloting
Default Skidding turns
No. He preflighted it and decided these were non-issues -right? (Now
I've not seen the cracks but I'd guess that a stop drilled a rivet
crack at the bottom of the tail is not likely to be an issue as not
near a hinge. the paint shows it's an old repair and the crack has
been stopped correctly).
Cheers- Hide quoted text -
- Show quoted text -
Well. Can't say anything was apparent about this on the ground during
the pre-flight. And nothing detectable through pressing on the rudder
pedals. I'll try the test recommended next time I'm out at the field.
In the meantime I'm about to bring this to the chief pilot's
attention.
Old February 21st 08, 03:21 PM posted to rec.aviation.piloting
On Feb 21, 4:38 am, WJRFlyBoy wrote:
"The right elevator tip trailing edge had been broken and *repaired with
aluminum foil tape* was what I thought was grossly negligent.
Right. That is extreme.
Dan
Old February 21st 08, 06:04 PM posted to rec.aviation.piloting
attention.
Remove numbers for gmail and for God's sake it ain't "gee" either!- Hide quoted text -
I now realize you guys are talking about a different plane, the Cessna
with the jammed rudder.
My confusion, sorry.
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
A Q on horizontal turns Ramapriya Piloting 2 January 8th 05 05:57 PM
A Q on horizontal turns Ramapriya Piloting 14 January 7th 05 11:46 PM
A320 doing S-turns at LAS Gerald Sylvester Piloting 7 May 7th 04 02:59 PM
Slipping in Turns Jim Hendrix Soaring 16 November 30th 03 04:39 PM
