#21
No. He preflighted it and decided these were non-issues -right? (Now
I've not seen the cracks but I'd guess that a stop drilled a rivet crack at the bottom of the tail is not likely to be an issue as not near a hinge. the paint shows it's an old repair and the crack has been stopped correctly). Cheers- Hide quoted text - - Show quoted text - Well. Can't say anything was apparent about this on the ground during the pre-flight. And nothing detectable through pressing on the rudder pedals. I'll try the test recommended next time I'm out at the field. In the meantime I'm about to bring this to the chief pilot's attention. |
On Feb 21, 4:38 am, WJRFlyBoy wrote:
"The right elevator tip trailing edge had been broken and *repaired with aluminum foil tape* was what I thought was grossly negligent. Right. That is extreme. Dan |
#24
the pre-flight. And nothing detectable through pressing on the rudder pedals. I'll try the test recommended next time I'm out at the field. In the meantime I'm about to bring this to the chief pilot's attention. "The right elevator tip trailing edge had been broken and *repaired with aluminum foil tape* was what I thought was grossly negligent. -- Remove numbers for gmail and for God's sake it ain't "gee" either!- Hide quoted text - - Show quoted text - I now realize you guys are talking about a different plane, the Cessna with the jammed rudder. My confusion, sorry. |
Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 04:47 PM |
A Q on horizontal turns | Ramapriya | Piloting | 2 | January 8th 05 05:57 PM |
A Q on horizontal turns | Ramapriya | Piloting | 14 | January 7th 05 11:46 PM |
A320 doing S-turns at LAS | Gerald Sylvester | Piloting | 7 | May 7th 04 02:59 PM |
Slipping in Turns | Jim Hendrix | Soaring | 16 | November 30th 03 04:39 PM |
