Bertie the Bunyip wrote:
WingFlaps wrote in : On Feb 26, 8:07 am, Larry Dighera wrote: On Mon, 25 Feb 2008 18:04:57 +0000 (UTC), Bertie the Bunyip wrote in : Wel, it's a rose by any other name sort of thing.. Basicaly what's happening is the air around the wing's pressure is influenced by the ground. You have a high below the wing in flight and it gets higher and influences the way the air flows around the wing keeping it laminar longe r. ( slower) I find it curious that an alleged airline captain has failed to mention the reduction in induced drag that results due to the interference with the wingtip vortices when operating in ground effect. Perhaps it did note poke the induced drag memory cells? Maybe our Bertie actively suppresses his drag memories? Groan! Bertie Perhaps if you came out in drag, Ken might like that better :-)) -- Dudley Henriques |
On Feb 25, 11:04*am, Bertie the Bunyip wrote:
"gatt" wrote : In the book "Takeoffs and Landings" by Leighton Collins--who is referenced in "Stick and Rudder"--there is no mention of the term "ground effect." Rather, Collins talks briefly about "ground cushion" and how air "piles up" beneath the wings. Do people still teach this? Wel, it's a rose by any other name sort of thing.. Basicaly what's happening is the air around the wing's pressure is influenced by the ground. You have a high below the wing in flight and it gets higher and influences the way the air flows around the wing keeping it laminar longer.. ( slower) Bertie No, its not. |
On Mon, 25 Feb 2008 09:46:30 -0800, "gatt"
wrote: Rather, Collins talks briefly about "ground cushion" and how air "piles up" beneath the wings. Do people still teach this? All I can say is, if you rely on that ground cushion to soften the impact, you will be sorely disappointed. Blue skies! -- Dan Ford Claire Chennault and His American Volunteers, 1941-1942 new from HarperCollins www.FlyingTigersBook.com |
buttman wrote in
: On Feb 25, 11:04*am, Bertie the Bunyip wrote: "gatt" wrote ews.com: In the book "Takeoffs and Landings" by Leighton Collins--who is referenced in "Stick and Rudder"--there is no mention of the term "ground effect." Rather, Collins talks briefly about "ground cushion" and how air "piles up" beneath the wings. Do people still teach this? Wel, it's a rose by any other name sort of thing.. Basicaly what's happening is the air around the wing's pressure is influenced by the ground. You have a high below the wing in flight and it gets higher and influences the way the air flows around the wing keeping it laminar longer . ( slower) Bertie No, its not. Yes, it is. Bertie |
I have found that in the early stages of discussion, ground cushion puts a
useful picture into the student's mind...we can get into downwash later. Bob Gardner "gatt" wrote in message ... In the book "Takeoffs and Landings" by Leighton Collins--who is referenced in "Stick and Rudder"--there is no mention of the term "ground effect." Rather, Collins talks briefly about "ground cushion" and how air "piles up" beneath the wings. Do people still teach this? -c |
If the goal is to give the student an easy-to-grasp concept, ground cushion
is just fine *as an introduction to the discussion.* If the goal is to use technically correct phraseology at all times whether it penetrates the student's skull or not, then reduction in induced drag and downwash angle do the trick. Bob Gardner "Cubdriver" usenet AT danford DOT net wrote in message ... On Mon, 25 Feb 2008 09:46:30 -0800, "gatt" wrote: Rather, Collins talks briefly about "ground cushion" and how air "piles up" beneath the wings. Do people still teach this? All I can say is, if you rely on that ground cushion to soften the impact, you will be sorely disappointed. Blue skies! -- Dan Ford Claire Chennault and His American Volunteers, 1941-1942 new from HarperCollins www.FlyingTigersBook.com |
Bob Gardner wrote:
If the goal is to give the student an easy-to-grasp concept, ground cushion is just fine *as an introduction to the discussion.* If the goal is to use technically correct phraseology at all times whether it penetrates the student's skull or not, then reduction in induced drag and downwash angle do the trick. Bob Gardner "Cubdriver" usenet AT danford DOT net wrote in message ... On Mon, 25 Feb 2008 09:46:30 -0800, "gatt" wrote: Rather, Collins talks briefly about "ground cushion" and how air "piles up" beneath the wings. Do people still teach this? All I can say is, if you rely on that ground cushion to soften the impact, you will be sorely disappointed. Blue skies! -- Dan Ford Claire Chennault and His American Volunteers, 1941-1942 new from HarperCollins www.FlyingTigersBook.com I agree. I've used the "ground cushion" analogy many times when opening up the issue of ground effect with primary students. Using chalk and a blackboard to demonstrate how, and where the cushion forms under the airplane is one of the ways to take this first step. Once the student knows ground effect actually exists and what it does, THEN is the time to begin to explain the "devil in the details" :-) -- Dudley Henriques |
![]() "Bob Gardner" wrote in message . .. I have found that in the early stages of discussion, ground cushion puts a useful picture into the student's mind...we can get into downwash later. I like that explanation. He also made a reference to watching a seagull glide over calm water, and flare to land. Granted, I suppose there are readers who might never have seen a seagull over water (?) but physics aside it's a clear, memorable representation of the general idea. ....which reminds me of photo series in the Jepp Instrument/Commercial textbook showing a wayward seagull who forgot to lower his landing gear. The book indicates that even natural born aviators do it on occasion, which is why checklists are important. Won't forget that one either. -c |
Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Piloting | 168 | February 5th 08 05:32 PM |
Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Instrument Flight Rules | 137 | February 5th 08 05:32 PM |
Can I still get "Bad day for JFK ground Controller"? | [email protected] | Piloting | 8 | October 19th 07 04:52 AM |
V-22 Osprey "ground effect" question | Robert | Naval Aviation | 6 | January 2nd 07 03:44 PM |
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale | >pk | Aviation Marketplace | 0 | October 16th 06 07:48 AM |
