If anyone knows an FAA designee in Arizona who can do an experimental
C of A on a new glider, please let me know ASAP. (Not Mike Moyer at the Scottsdale FSDO -- he's busy until mid April.) Advance thanks -- ~ted/2NO 480-296-9022 ps Also -- I have conflicting advice about whether a FSDO in one area (say, Houston) can issue an Experimental C of A (racing/exhibition) for another area (say, Phoenix). Does anyone have any solid information on this? |
On Mar 21, 1:20 pm, Tuno wrote:
If anyone knows an FAA designee in Arizona who can do an experimental C of A on a new glider, please let me know ASAP. (Not Mike Moyer at the Scottsdale FSDO -- he's busy until mid April.) Advance thanks -- ~ted/2NO 480-296-9022 ps Also -- I have conflicting advice about whether a FSDO in one area (say, Houston) can issue an Experimental C of A (racing/exhibition) for another area (say, Phoenix). Does anyone have any solid information on this? Don't know the answer to the PS. Here's the list. http://www.faa.gov/other_visit/aviat...RDirectory.pdf Presuming you have your N-number, look for AZ _Maintenance_ DAR's that are authorized Function code 26. I count 9 total maintenance DARs in AZ with function 26. Whether they all will do gliders, I don't know. Codes are defined in FAA Order 8100.8C (4) Code 26 -- Issue recurrent/original special airworthiness certificates, in the experimental category, for the purposes of operating exhibition or air racing on U.S.-registered aircraft located in the United States. Good luck, Frank Whiteley ps: maybe someone will have a name and number handy |
Its' a long way to go, but I know a DAR in El Monte CA, and
gliders/motorgliders a specialty. And yes, he can cross FSDO boundaries. BT "Tuno" wrote in message ... If anyone knows an FAA designee in Arizona who can do an experimental C of A on a new glider, please let me know ASAP. (Not Mike Moyer at the Scottsdale FSDO -- he's busy until mid April.) Advance thanks -- ~ted/2NO 480-296-9022 ps Also -- I have conflicting advice about whether a FSDO in one area (say, Houston) can issue an Experimental C of A (racing/exhibition) for another area (say, Phoenix). Does anyone have any solid information on this? |
On Mar 21, 7:37 pm, "BT" wrote:
Its' a long way to go, but I know a DAR in El Monte CA, and gliders/motorgliders a specialty. And yes, he can cross FSDO boundaries. BT "Tuno" wrote in message They may be authorized to do so IAW para 904 of FAA Order 8100.8C. If you're in a hurry, suggest checking with the local guys first. Frank Whiteley |
BT,
Can you send me his contact info please? -ted/2NO |
| Thread Tools | |
| Display Modes | |
| D-M AFB, Tucson, AZ | Lonnie[_2_] | Aviation Photos | 12 | September 9th 07 05:55 AM |
| Southern Arizona Storm | Ken Reed | Piloting | 14 | June 10th 06 05:01 AM |
| Southern Arizona Storm | Ken Reed | Owning | 12 | June 10th 06 05:01 AM |
| FS: Russia AC-4c (Tucson, AZ, USA) | LOV2AV8 | Soaring | 0 | May 16th 06 09:51 PM |
| Phoenix Arizona airspace | Andy | Soaring | 0 | August 3rd 05 01:24 AM |
