Ramp jack for Komet Trailer
Old March 23rd 08, 05:31 PM posted to rec.aviation.soaring
Default Ramp jack for Komet Trailer
I am looking at a worn out mechanical jack for the ramp on a Komet
trailer. The best repair I have come up with is to buy a set of
scissor jacks and have them welded into the existing frame. Has
anyone else tackled this job and had better luck with another type of
repair?
Thanks in advance,
Roger
Old March 23rd 08, 07:12 PM posted to rec.aviation.soaring
Mike the Strike
Some years ago, I had exactly the same problem on a 1978 Komet. I
bought two extra strong jacks and had a local welding shop mount them
for me. Worked great!
Mike
repair?
Thanks in advance,
Roger
Old March 23rd 08, 09:30 PM posted to rec.aviation.soaring
On Mar 23, 1:10*pm, Sarah Anderson wrote:
I have an older Komet with the same problem.
I'd be interested in pix as well as info on where exactly to buy a "lovejoy bearing".
Boy, sometimes the advertising writes itself, doesn't it?
Sarah
Bullwinkle wrote:
On 3/23/08 12:12 PM, in article
, "Mike the
Strike" wrote:
Some years ago, I had exactly the same problem on a 1978 Komet. *I
for me. *Worked great!
Mike
trailer. *The best repair I have come up with is to buy a set of
scissor jacks and have them welded into the existing frame. *Has
repair?
Thanks in advance,
Roger
I recently had trouble with mine. I got two auto scissor jacks from AutoMax
and a friend connected them with a Lovejoy bearing. Huge range of motion and
great stability compared with the previous ramp jack. I've got photos, if
you need them.
Bullwinkle- Hide quoted text -
- Show quoted text -
I'm pretty sure Williams Soaring has the double jack setups for your
ramp. Reasonably priced too, as I recall.
I have the same problem, but hate scissor jacks. I'm hoping to knock
out a simple lever type setup in the next couple weeks. I'll post
something if it works out.
Old March 23rd 08, 09:36 PM posted to rec.aviation.soaring
repair?
Thanks in advance,
Roger
One of the scissor jacks for my trailer eventually stripped its
threads. I repaired it with a Heli-Coil and a new all-thread. The
jacks work ok but the force required to elevate the glider is higher
than I would like. Unfortunately, the alternative is more money than I
want to invest.
Steve
Old March 23rd 08, 09:49 PM posted to rec.aviation.soaring
Bill Daniels
repair?
Thanks in advance,
Roger
want to invest.
Steve
Bob Carl got tired of cranking his ramp jack so he bought a big, low-RPM
cordless drill and fitted it with a large socket then replaced the scissor
jack crank handle with a matching nut. Now he can zip his ramp jack up and
down effortlessly even with the glider on it.
Bill D
Old March 24th 08, 02:03 AM posted to rec.aviation.soaring
Bob Kuykendall
want to invest.
Jacks and other machines cycled under load usually use Acme thread,
which is very different from the profile used on allthread and bolts
and similar. Acme threads generally have lower maximum force limits,
but their even pressure distribution across the thread profile gives
them relatively low friction - lower than the triangular profile used
on nuts and bolts at least.
Just replacing the scissors jack can be pretty cost-effective. You can
probably get a matched set at a scrapyard for like five bucks each.
Thanks, Bob K.
Old April 2nd 08, 06:37 PM posted to rec.aviation.soaring
want to invest.
Just replacing the scissorsjackcan be pretty cost-effective. You can
Thanks, Bob K.
http://store.williamssoaring.com/Mer...ory_C ode=TPA
The only problem with the junkyard jacks is finding a PAIR that will
fit between your wings when stowed in the trailer. I couldn't. I
ended up buying a pair of Toyota jacks, then shortening all the parts
to make a pair that would fit. They worked fine, but it took me a
large part of a day to do it, and I won't do it again. Williams
Soaring sells the units for $192.00 (or so) and IF I were going to use
scissor jacks, that's what I'd do. However, I tested my NASCAR
inspired lever jack (crude prototype) and it works nicely. Instead of
getting on my knees and cranking it up, I stand up and pull on a 48
lever and raise the glider. With the fuselage empty it's quite easy.
With a 240 pound pilot in the cockpit, it takes considerable (but
doable by Joe Average) effort. (We didn't have adequate space to put
wings on, so the pilot was substituted to simulate the weight of the
wings). When in the 'down' position, the distance between the bottom
of the ramp channels and the ground is slightly less than 2". When
raised, it is right around 9 1/2", which should allow for removing the
wheel on most gliders.
Komet Trailer Gas Springs P. Corbett Soaring 4 March 12th 07 12:30 AM
Komet Trailer Rims Tim Hanke Soaring 6 February 28th 06 05:56 PM
Double scissor jack for trailer ramp? Bullwinkle Soaring 15 January 18th 06 06:18 PM
KOMET Trailer Cradle [email protected] Soaring 3 September 27th 04 05:33 AM
Komet trailer strut John Shelton Soaring 5 November 15th 03 06:04 PM
