I've just discovered the Morningstar Sunsaver 6 charge controller I've
been using with my 20 watt panel is a two stage controller, and does not have a "float" stage. This appears to have damaged my batteries more in one year than several batteries I've used for 3 years or more, but were charged with a good 3 stage AC charger. Are there recommendations for a more suitable charge controller? When charging, the controller is placed in the trailer, or in the gear well if the glider is tied out, so the battery and controller temperatures are the same. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Are there recommendations for a more suitable charge controller? When charging, the controller is placed in the trailer, or in the gear well if the glider is tied out, so the battery and controller temperatures are the same. Aren't the Morningstar Sunkeeper series 3-stage? |
On Mar 25, 1:57 pm, Eric Greenwell wrote:
I've just discovered the Morningstar Sunsaver 6 charge controller I've been using with my 20 watt panel is a two stage controller, and does not have a "float" stage. This appears to have damaged my batteries more in one year than several batteries I've used for 3 years or more, but were charged with a good 3 stage AC charger. Are there recommendations for a more suitable charge controller? When charging, the controller is placed in the trailer, or in the gear well if the glider is tied out, so the battery and controller temperatures are the same. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes"http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org Eric, I just bought this item on ebay for a 6 W solar panel that I will use to tie together a trailer fan and a 5AH NiMH battery. It seems to work great, keeping the battery charged but allowing the fan to run day and night. I tried to copy you the link from ebay but it wouldn't work. Here is the search term: Solar Panel Charge Regulator Controller 12V 5A 60W NEW Herb, J7 |
Are there recommendations for a more suitable charge controller? When charging, the controller is placed in the trailer, or in the gear well if the glider is tied out, so the battery and controller temperatures are the same. Aren't the Morningstar Sunkeeper series 3-stage? Yes, they are. I don't like the shape, so I'm leaning towards the Steca-5-c with similar specs and $30 instead of $60. But, I'm still looking for recommendations and warnings. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Oops, misspelled batteries, but I fixed it. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
The Steca looks interesting. It's got float, leds and fuse holder to
boot. As long as its got a blocking diode then that looks a good one to go with. Even if not, you can easily add one. Yes, they are. I don't like the shape, so I'm leaning towards the Steca-5-c with similar specs and $30 instead of $60. But, I'm still looking for recommendations and warnings. |
The Steca looks interesting. It's got float, leds and fuse holder to boot. As long as its got a blocking diode then that looks a good one to go with. Even if not, you can easily add one. It does have a blocking diode. I've ordered the Steca-5-c, and will test it for proper switching to float voltage before using it on the glider batteries. I didn't notice that it had a fuse - nice touch. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
| Jim Weir's solar charger | R. Lee Jarvis | Home Built | 2 | February 17th 07 08:21 PM |
| 12v - 12v charger | 5Z | Soaring | 19 | December 30th 05 10:58 PM |
| Hurricane Wilma Damages | Marty from Florida | Owning | 22 | November 2nd 05 02:24 AM |
| Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 02:11 AM |
| Protestor Damages Enola Gay | B2431 | Military Aviation | 88 | December 24th 03 06:24 AM |
