			#21
			 Robert M. Gary wrote: I've heard of this fuel. I believe its called Ferry Dust. That.s spelled "Fairy Dust"! Ang.  |
d$g$s-one-thee-zer0-zer0 wrote:
	Eeyore wrote: Do you have a link to this article ? It's on www.avweb.com. And there's also this: http://www.swiftenterprises.com/Swif...0benefits.html Make of it what you will. Swift gives no hint whatsoever as to the consitutents of his fuel. Many hydrocarbons*, really most hydrocarbon liquids, will burn and can provide an eplosive mixture with air. It's just a matter of using the "Edison" method of locating a good replacement for 100 octane no-lead. This fellow has apparently foung a cost-effective substitute, and he's keeping the mixture identity under his hat. *Ages ago (maybe not so long ago), benzine was a useful constutent for auto fuel. In Europe, for some years, auto fuel was called "Benzin". So Mr. Swift has found another cost-effective (at today's prices) substirute for AvGas. We wonder what the stuff is made of... Angelo Campanellsa  |
terry wrote:
	for those interested , here is a link to the Swift patent. It sounds pretty complicated with 5 different components. One of the components used to lower the vapour pressure is ethyl acetate, a solvent used in nail polish , varnish etc. This fuel is going to have quite an interesting odour. The percentage of the various components can apparently be varied to adjust octane rating for both aviation and auto use. http://www.wipo.int/pctdb/en/wo.jsp?...2&DISPLAY=DESC For you cehm wonks, here's the nugget: "... the present inventors provide a renewable fuel comprised of: (a) one or more low carbon esters derivable from ethanol; (b) one or more pentosan derivable furans; (c) one or more aromatic hydrocarbons derived from acetone or propyne; (d) one or more C4-C io straight chain alkanes derivable from polysaccharides; and (e) one or more bio-oils derived from plant germ." Soup for the needy AvPlane, I say. Ang.  |
Angelo Campanella  wrote in
	: terry wrote: for those interested , here is a link to the Swift patent. It sounds pretty complicated with 5 different components. One of the components used to lower the vapour pressure is ethyl acetate, a solvent used in nail polish , varnish etc. This fuel is going to have quite an interesting odour. The percentage of the various components can apparently be varied to adjust octane rating for both aviation and auto use. http://www.wipo.int/pctdb/en/wo.jsp?...A=WO2008013922 &DI SPLAY=DESC For you cehm wonks, here's the nugget: "... the present inventors provide a renewable fuel comprised of: (a) one or more low carbon esters derivable from ethanol; (b) one or more pentosan derivable furans; (c) one or more aromatic hydrocarbons derived from acetone or propyne; (d) one or more C4-C io straight chain alkanes derivable from polysaccharides; and (e) one or more bio-oils derived from plant germ." Soup for the needy AvPlane, I say. Ang. Tell me this, what do you make of his claim that you can pour this stuff straight into an airplane set up for Avgas? No timing or mixture changes, no hardware changes? Bertie  |
In article  Bertie the Bunyip  writes:
	Tell me this, what do you make of his claim that you can pour this stuff straight into an airplane set up for Avgas? No timing or mixture changes, no hardware changes? If it really is a substitute for 100LL, then that would be exactly what one would do. A pretty big 'if', though. If he can really make the stuff, why is he talking instead of mixing? If you can put avgas out at 1/2 the price as he seemed to be claiming, he could get a lot of attention with a pump pumping for $2.499 / gallon. Of course, if he makes the stuff without lead, then I don't see why it wouldn't work in most cars as well. At $2.499 / gallon, he could sell all he could make. *IF* he can do it. Alan  |
			 Exactly. Even if were the same price and did what he claims ( greater range for volume) he could still outsell Avgas. Bertie But, who's going to be the first to put it in their own plane? And how long do you think it would take the FAA to approve it? Lou  |
			#28
			#29
	Bertie the Bunyip wrote: Tell me this, what do you make of his claim that you can pour this stuff straight into an airplane set up for Avgas? No timing or mixture changes, no hardware changes? Timing? probably, if the octane rating is there. Mixture? You would probably have to adjust mixture accordingly. The different fuel density would probably require adjustments to float levels. Other hardware changes? I would have to see the materials compatibility tests before I started using it. It has been known since the 1950s that the synthetic rubber used in hoses, etc. can tolerate either petroleum-based or parrafin-based fuels. The problems arise when switching (either way) between the two, since each type fuel has its own effect on the polymers. -- Remove _'s from email address to talk to me.  |
			#30
Orval Fairbairn  wrote in
	news
In article , Bertie the Bunyip wrote: Tell me this, what do you make of his claim that you can pour this stuff straight into an airplane set up for Avgas? No timing or mixture changes, no hardware changes? Timing? probably, if the octane rating is there. Mixture? You would probably have to adjust mixture accordingly. The different fuel density would probably require adjustments to float levels. Other hardware changes? I would have to see the materials compatibility tests before I started using it. It has been known since the 1950s that the synthetic rubber used in hoses, etc. can tolerate either petroleum-based or parrafin-based fuels. The problems arise when switching (either way) between the two, since each type fuel has its own effect on the polymers. Well, my luscombe had virtually nothing in the fuel system vunerable to anything this side of Skydrol, but only because I installed a metal float and an automotive fuel line. The float seat is metal of course and there's nothing else in the system that anythign can melt. My KCAB is anouther thing altogether. The LeBlond I'm going to have to check, but I think it has a standard MS carb form the thirties anyway, so it should be fine. Bertie  |
| Thread Tools | |
| Display Modes | |
| Fuel quality control standards for aircraft rental/fuel sales... | [email protected] | Owning | 19 | January 19th 05 05:12 AM |
| Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Home Built | 0 | January 26th 04 08:48 AM |
| Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Aviation Marketplace | 0 | January 26th 04 08:48 AM |
| Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Owning | 0 | January 26th 04 08:48 AM |
| Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 08:09 PM |
