sport pilot airplane from pvt glider
Old May 15th 08, 03:18 AM posted to rec.aviation.soaring
Andy[_1_]
Default sport pilot airplane from pvt glider
For some reason I can't reply to the old thread that discussed adding
new ratings to sport pilot without a flight test. The reply option is
not available. Anyway...
It seems FAA has had second thought on this and has issued an NPRM.
Some of it reads as follows:
"Currently, to obtain additional aircraft
category and class privileges at the sport
pilot level, the holder of a pilot
certificate must complete a proficiency
check administered by an authorized
instructor. Upon successful completion
of that proficiency check, that person
receives a logbook endorsement from
the instructor who administered the
proficiency check. That endorsement
permits the person completing the
proficiency check to exercise sport pilot
privileges in the category and class of
aircraft in which the proficiency check
was administered.
Consistent with the FAA’s system for
issuing all other pilot certificates and
ratings, the FAA is proposing to require
a person seeking privileges to operate an
additional category and class of lightsport
aircraft as a sport pilot to obtain
the appropriate category and class
rating. These ratings would be issued
after the completion of a practical test
typically administered by an FAAdesignated
pilot examiner (DPE). The
practice of obtaining privileges to
operate a light-sport aircraft after
completion of a proficiency check by an
authorized instructor would be
discontinued. Privileges to operate lightsport
aircraft would be indicated as
ratings on a person’s pilot certificate
rather than by an endorsement in a
person’s logbook."
Note the requirement for a flight test with an FAA designated
examiner. (DPE)
The full NPRM can be seen at
http://edocket.access.gpo.gov/2008/pdf/08-1127.pdf
Andy
Old May 15th 08, 04:14 AM posted to rec.aviation.soaring
BT
Andy.. that is standard for anyone moving from a glider rating to an
airplane rating.
They are finally covering their tracks for the Sport Pilot level.
BT
"Andy" wrote in message
was administered.
person’s logbook."
examiner. (DPE)
Andy
Old May 15th 08, 03:39 PM posted to rec.aviation.soaring
Andy[_1_]
airplane rating.
BT
The context of my post was perhaps not clear since I was unable to
continue the original thread. I should have prefaced it by quoting my
comment from the old thread:
"I am certainly confused and surprised that an SP gliderpilot can get
SP airplane without a knowledge or flight test since, as a pvt
gliderpilot, I had to take both the knowledge and flight test to get
private
ASEL on my certificate."
A search of this group for "sport airplane" will find the thread.
Andy
Old May 18th 08, 03:25 AM posted to rec.aviation.soaring
Nyal Williams[_2_]
Andy, the "Reply" button is now at the bottom of the page
instead of the top. It appears this might be a gentle nudge to post
replys below the message instead of at the top, as has been our standard
practice.
adding
>was administered.
>Consistent with the FAA=92s system for
>ratings on a person=92s pilot certificate
>person=92s logbook."
>examiner. (DPE)
>Andy
Old May 18th 08, 01:01 PM posted to rec.aviation.soaring
Russ[_2_]
Nyal-
Interesting that you should try to dictate convention when your posts
are coming through with quotes so butchered that they are illegible.
This is "Usenet", you are posting to, and has no reply buttons.
Any buttons you see come from the software which you personally are
using for posting and there are no rules as to where a person may put
their reply. Only, "your" personal taste as to where you would like to
see the reply.
Clean up your own act before dictating to others how they should post.
I am posting to the top in this instance, not to spite you, but so that
you may see an example, below, as to how your posts are coming through a
"normal" newsreader program for Usenet.
practice.
adding
>was administered.
>examiner. (DPE)
>Andy
Old May 18th 08, 06:09 PM posted to rec.aviation.soaring
Marc Ramsey[_2_]
Nyal's Usenet reader is reading/posting in HTML format, he likely
doesn't see anything wrong, as the '>' sequences translate to '' and
the '"' sequences translate to '"'. Nyal, check your settings and
change the posting format to text, which is the Usenet standard...
Marc
Russ wrote:
Nyal-
see the reply.
practice.
adding
Old May 19th 08, 12:40 AM posted to rec.aviation.soaring
Nyal Williams[_2_]
Russ, and others,
I have no interest in dictating convention; I merely observed what was the
usual practice, recalled that there had been been some discussion and
criticism of posting at top or bottom (probably two years ago) and
surmised that moving the button to the bottom might have been a nudge.
There are arguments for posting at top and at bottom and I take no
position on this. I only wanted to point out that someone who needed a
button for reply had overlooked it.
Now, turns out that my reader needs adjusting and that not everyone sees
what I see. I'm not all that savvy about internet communications. I'm
using Thunderbird at someone else's suggestion and I'm not sure what to
do to it.
It was not my intent to influence practices or to ruffle feathers.
Thanks, Marc Russ's post did not even show up on my list of downloaded
messages.
'>' and
settings and
>Marc
>Russ wrote:
>> Nyal-
posts
illegible.
reply buttons.
are
put
you would like to
>> see the reply.
post.
so that
through a
the page
to post
our standard
>>> practice.
discussed
>>> adding
reply option is
issued an NPRM.
Old May 19th 08, 12:55 AM posted to rec.aviation.soaring
Nyal Williams[_2_]
Ah, here's your post.
Russ, I tried to answer you privately by email but you have obscured your
address.
This came to me completely clean, unbutchered, uncluttered, and clear as a
bell.
I don't know what the problem is. Sorry!
At 11:01 18 May 2008, Russ wrote:
>Nyal-
buttons.
would like to
>see the reply.
post.
that
a
page
post
standard
>> practice.
discussed
>> adding
option is
NPRM.
>> >was administered.
designated
>> >examiner. (DPE)
>> >Andy
Old May 19th 08, 02:11 AM posted to rec.aviation.soaring
Jim Logajan
sees what I see. I'm not all that savvy about internet
communications. I'm using Thunderbird at someone else's suggestion
and I'm not sure what to do to it.
It looks like you may be posting via this web site:
http://www.gliderpilot.net/
You might try contacting the webmaster for that site via the info in that
site's contact page and point out the problem. Alternatively you could try
posting via Google Groups:
http://groups.google.com/group/rec.a.../topics?lnk=sg
Old May 19th 08, 03:21 AM posted to rec.aviation.soaring
Russ[_2_]
clear as a
bell.
Nyal,
Sorry about that, I realized after I posted the quote that your
newsreader probably would clean the quote up the same as it munged it.
I suspect, now, that it is a combination of html text and
Gilderpilot.net, and Google news that your messages go through. It was
a disastrous combination of the internet providers and some texting
characters that prevent the message from being translated to plain text
for a Usenet newsreader.
http://tinyurl.com/5vlay4
This shortened link should take you to a Google Groups version of your
Spoilers or Airbrakes message, which first set me off. It might give you
a view of the munging of the text that made it unreadable. Your
messages are fine as long as nothing is quoted.
After trying to read the above message I falsely perceived, in your next
message in the "Sport pilot from pvt glider" thread, that you were then
directing Andy to follow a convention that was not followed in the
spoiler/airbrake correction attempt.
I am blaming my short fuse for it all, on the rainy weekend, here.
Russ
Adding an airplane rating to private pilot glider gmcd05 Soaring 35 April 25th 08 02:43 AM
sport airplane from private glider Andy[_1_] Soaring 5 November 28th 07 02:29 AM
Sport Pilot and Glider Questions Ralph Steiner Soaring 17 February 22nd 06 12:34 PM
Light-Sport Aircraft / Sport Pilot group gilan Piloting 0 November 13th 05 05:53 PM
Light-Sport Aircraft / Sport Pilot group gilan Owning 0 November 13th 05 05:53 PM
