#31
![]() I can think of a simple test. Tie the aircraft down, stick the tanks, confirm the asymmetric state. Now, remove both caps. Wait a while, maybe a few hours. Stick tanks. Any change? If yes, it's vent related, if not, the [bottom] fuel lines/manifold. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
#32
![]() "Bertie the Bunyip" wrote in message Me da,,,,Me da Are you Bertie's sister MeDa Buttlip Squirt, squirt. |
#33
"Maxwell" luv2^fly99@cox.^net wrote in news:NcqVj.2735$hJ1.725
@newsfe17.lga: "Bertie the Bunyip" wrote in message Me da,,,,Me da Are you Bertie's sister MeDa Buttlip Why, you want me to fix you up? Bertie |
#34
The Citabria's fuel system is okay now; those who guessed "filler
caps" have the satisfaction of being right. The A&P had time to give the system a good look late last week and we tested the fix with some local and cross-country flying over the weekend. The left tank still tends to contribute a bit more than the right in flight, but "it's always done that." And the system now crossflows on the ground when the wings are not level, which it had stopped doing. The A&P didn't find any soft or swollen hoses so he took a close look at the cap gaskets and found that looking like new and performing like new aren't the same thing. There were no cracks or other obvious flaws but both gaskets were equally bad at sealing; that's why a simple cap-swap didn't change anything. It seems that the left tank just isn't as sensitive to venting/sealing problems as the right. To seal well, even with good gaskets, the caps have to be difficult to screw down tight. Thanks to all who contributed ideas. |
#35
On May 19, 5:27 pm, quietguy wrote:
There were no cracks or other obvious flaws but both gaskets were equally bad at sealing; that's why a simple cap-swap didn't change anything. It seems that the left tank just isn't as sensitive to venting/sealing problems as the right. To seal well, even with good gaskets, the caps have to be difficult to screw down tight. The LH tank vents directly outside, while the RH tank vent into the left, so a leaking RH cap would hold back the flow in flight somewhat due to the small resistance of airflow through the vent crossover. But leaking caps still don't explain the lack of crossflow overnight; only a totally plugged vent system or plugged fuel lines would do that. Those cap gaskets compress with age and get hard, and won't seal unless they're really clamped down tight. New gaskets fix that, but they can be so tight that the cap doesn't get screwed on all the way and can come off in flight. I painted red stripes on our caps so that the stripes are lined up fore-and-aft when the caps are all the way on. And I use a little tiny bit of Dow DC-4 silicone grease between the cap and gasket so the cap doesn't have to grind the gasket against the filler neck; the cap goes on really nice after that. Dan |
#37
![]() "Bertie the Bunyip" wrote in message ... Not according to my manual, which has a T fitting feeding air to both tanks from the one vent on all models. It wouldn't be the first time the reality differed from the manuals, of course. Bertie Or the first time reality differed from your recollection. |
#38
"Maxwell" luv2^fly99@cox.^net wrote in news:FIqYj.87799$y05.56401
@newsfe22.lga: "Bertie the Bunyip" wrote in message ... Not according to my manual, which has a T fitting feeding air to both tanks from the one vent on all models. It wouldn't be the first time the reality differed from the manuals, of course. Bertie Or the first time reality differed from your recollection. True enouogh, but then I do still remember where I left the manuals, so it doen't matter. Bertie |
#39
On May 19, 7:00 pm, Bertie the Bunyip wrote:
wrote in news:6cbe76a7-0b6a-4d7c-a352- : On May 19, 5:27 pm, quietguy wrote: There were no cracks or other obvious flaws but both gaskets were equally bad at sealing; that's why a simple cap-swap didn't change anything. It seems that the left tank just isn't as sensitive to venting/sealing problems as the right. To seal well, even with good gaskets, the caps have to be difficult to screw down tight. The LH tank vents directly outside, while the RH tank vent into the left, Not according to my manual, which has a T fitting feeding air to both tanks from the one vent on all models. It wouldn't be the first time the reality differed from the manuals, of course. Bertie Must have changed at some point. Both of ours have the vent feeding through a check valve into the LH tank, and a crossover vent connection between the inboard walls of both tanks. Dan |
#40
![]() wrote in message ... On May 19, 7:00 pm, Bertie the Bunyip wrote: wrote in news:6cbe76a7-0b6a-4d7c-a352- : On May 19, 5:27 pm, quietguy wrote: There were no cracks or other obvious flaws but both gaskets were equally bad at sealing; that's why a simple cap-swap didn't change anything. It seems that the left tank just isn't as sensitive to venting/sealing problems as the right. To seal well, even with good gaskets, the caps have to be difficult to screw down tight. The LH tank vents directly outside, while the RH tank vent into the left, Not according to my manual, which has a T fitting feeding air to both tanks from the one vent on all models. It wouldn't be the first time the reality differed from the manuals, of course. Bertie Must have changed at some point. Both of ours have the vent feeding through a check valve into the LH tank, and a crossover vent connection between the inboard walls of both tanks. Dan You're just feeding a troll. All he does is repeat what he is told. Very much like MX. |
fuel flow on the cheap | pittss1c | Home Built | 3 | May 7th 06 10:12 PM |
Fuel Flow instrument | Billc851 | Home Built | 18 | March 19th 05 12:49 PM |
V8 fuel flow | Robert Bates | Home Built | 34 | January 24th 05 03:41 AM |
fuel flow measurement | khanindra jyoti deka | Home Built | 0 | January 5th 05 04:34 AM |
Fuel Flow Monitoring | EDR | Owning | 4 | October 18th 03 03:10 AM |
