Pitch vs. trim in flight phases
Old May 20th 08, 02:12 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Pitch vs. trim in flight phases
gatt writes:
I don't either. That's like saying I don't fly to feel the carb heat or
landing gear switches, or to use checklists.
Some people clearly fly for the physical sensations.
That has nothing to do with it anything, and you're not qualified to
suggest to pilots what's what about flying because you have no
experience in it, anymore than I have combat experience because I played
Battlefield 1942.
I hope that your intense desire to contradict me doesn't turn you into an NTSB
statistic one day.
  #142
Old May 20th 08, 02:31 AM posted to rec.aviation.piloting,rec.aviation.student
Bertie the Bunyip[_25_]
Mxsmanic wrote in
gatt writes:
We're telling you, as the FAA and other sources tell you, that
they're important.
Not under IFR.
We're also telling you that they're reliable.
Not under IFR.
Pilots don't enjoy severe turbulence or wing icing, but these too are
realities of aviation.
VFR pilots are often very much into the sensations of flying. If they
cannot tear themselves away from that, they should stay VFR and never
attempt IFR in IMC.
I'm an airline pilot and I stil use them. We all do, fjukktard.
Bertie
  #143
Mxsmanic wrote in
gatt writes:
or landing gear switches, or to use checklists.
You don;t fly at all, moron.
Bertie
  #144
Old May 20th 08, 05:20 PM posted to rec.aviation.piloting,rec.aviation.student
gatt[_3_]
Mxsmanic wrote:
gatt writes:
We're telling you, as the FAA and other sources tell you, that they're
important.
Not under IFR.
Sorry. You're not authoritative, you cite no sources, and you have no
experience or demonstrated proficiency. Your opinion on the matter is
empty.
Next...
-c
  #145
Old May 20th 08, 05:22 PM posted to rec.aviation.piloting,rec.aviation.student
gatt[_3_]
Mxsmanic wrote:
gatt writes:
statistic one day.
LOL! What kind of ego must you have that you'd think somebody
contradicting you would cause them to be an NTSB statistic?
I'm not interested in what you "hope." You still haven't cited any
authoritative sources for any of your opinions and, as a system
administrator I can tell you, only a fool would believe something just
because Microsoft says it's so.
-c
  #146
Old May 20th 08, 08:36 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
gatt writes:
empty.
Next...
Next, ask Dudley.
  #147
Old May 20th 08, 08:37 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
gatt writes:
It doesn't require any ego. I've read the literature and I know what it says.
I don't make this up.
You wouldn't be, if you fit the profile I have in mind.
It reminds me of some CRM studies I've read, in which it has been shown that
some people would rather die than give up an opinion or risk rejection from a
group.
  #148
Old May 20th 08, 11:55 PM posted to rec.aviation.piloting,rec.aviation.student
some people would rather die than give up an opinion or...
Hmmm.
Jim Pennino
Remove .spam.sux to reply.
  #150
Old May 27th 08, 03:42 PM posted to rec.aviation.piloting,rec.aviation.student
On May 16, 1:49 pm, "Ken S. Tucker" wrote:
I was ok with the location of the trim wheel, but the adjustment
was too coarse for me, but I could be a bitchy sissy.
My wheel was graduated, with a zero mark and did not quite
give the fine adjustment I wanted. That could be cables out
to the tail, I should have learned the mechanism!
Nothing to do with the cables. Cessna's trim is anything but
sensitive, having four or five full turns of the wheel for the trim
range. Try a Citabria sometime, where the trim is a lever that moves
about eight or ten inches for the full range. Much more twitchy.
As far as others have asked about sim trim, the good,
commercial training sims (Level II) have a pitch control mechanism
centered by some strong springs that supposedly simulate elevator
pressures. The anchor points for those springs are movable, and those
are what the trim mechanism moves. So in slow flight the yoke is well
back, against the springs, so that the trim moves the spring anchors
back until the pressure disappears. The yoke does not move and the
pilot, if he's "flying" right, doesn't let it move. He just trims off
the pressure. Mx's stick, on the other hand, trims electronically so
that he has to gradually center the stick to keep the nose where it's
supposed to be. Not realistic at all. And the springs in those cheap
things are so feeble as to be a joke. Flying the real airplane is much
more work. If you had realistic spring forces you'd have to bolt the
stick to the desk and anchor the chair to the floor.
I built our own procedures sim here. Proper frame welded up,
proper adjustable seat, huge monitor, real rudder pedals with
realistic spring feel, real stick with a heavy non-discrete center
spring and an adjustable anchor to simulate a reaslistic trim. Real
steel throttle/prop/mixture quadrant. Robbed the electronics out of
the CH stick and pedals to drive it.
But still, it's used only as a procedures trainer, not for teaching
how to fly. The students use it for free to practice what they learned
on our certified Elite sim or in the air under the hood. It's much
more work to fly it, thanks to the big springs I put in it. I need to
redesign the mechanical trim to get more travel, though.
Underestimated the degree of elevator movement between high cruise and
slow flight.
And it has a collective for helicopter flight.
Dan
Typical power settings during cruise and other phases of flight Mxsmanic Piloting 99 October 2nd 06 10:12 AM
Making a pitch trim indicator for a Glasair [email protected] Home Built 5 September 13th 06 02:30 AM
$30,000 pitch links Stuart Fields Home Built 3 January 16th 06 02:13 AM
Cherokee Electric Pitch Trim Jonathan Goodish Owning 4 November 18th 04 02:43 AM
ALTRAK pitch system flight report optics student Home Built 2 September 21st 03 11:49 PM
