#21
On Jun 4, 8:48*am, Bob Kuykendall wrote:
On Jun 3, 7:43*pm, wrote: Please name one accident of a glider with auto hookups that could have been prevented by a positive control check. Russia elevator. Air Sailing contest. Pilot Chad Moore. Broken elevator pintle discovered. Accident averted. Thanks, Bob K. Russia pilot, at North Plains Oregon discovered broken rudder connection (I can't remember if it was a control horn problem or cables) while doing a PCC. He was glad he did! |
On Jun 3, 7:18*pm, wrote:
For ships with *auto hookups* positive control checks are a waste of time, and in fact do more harm then good. To expand a bit on my earlier response: Having designed and flight tested sailplane control systems, I feel compelled to take strong issue with that statement. I won't say it's wrong, but I will say that I strongly disagree. You state that it is a "fact" that PCCs do more harm than good. Please educate us with cites to evidence that proves or demonstrates or at least supports this fact. To my way of thinking, sailplanes are designed, engineered, built, and maintained by fallible beings. They are fallible machines. Their mechanisms get mis-assembled. They break and they get broken. Lives depend on their correct operation. Their operation can be easily checked for serious faults. Admitted, these checks can be done wrong and they can done ineffectively so as to consume time better spent elsehow. However, the applicable solution set also includes many ways of doing them quicky and safely. In my history as a glider bum, I have seen: * HP ruddervator, supposedly auto-connecting, failure to engage its driver on assembly, allowing only up/left input. Condition discovered in pre-flight. Dick Schreder not so lucky (but still pretty lucky!) with the RS-15 prototype. * Standard Cirrus tailplane, again supposedly auto-connecting, possible to mis-engage at the drive pushrod, allowing down elevator but not up. See the assembly-check drawing I did at the Standard Cirrus Web site for details. * Factory-new 304, trailing edge airbrake drive pushrod locking nut not tightened, pushrod free to rotate and eventually disengage from rod end. Condition discovered while wiggling random bits prior to first flight. * (Previously reported) Russa AC4, elevator center pintle broken loose from stabilizer. Up stick moves the elevator root aft without pivoting elevator up. Condition discovered in mandatory pre-launch PCC. Thanks, Bob K. http://www.hpaircraft.com/hp-24 |
As mentioned in another thread. I too had a disconnected HP ruddervator and
wrote an article about it for Soaring. http://www.soaridaho.com/Schreder/St...mbly_Check.pdf This article contains a link to Dick Schreder's RS-14 adventure. Back when I was in the Navy I served with Steward Tittle. We have kept in touch through out the years. As many of you will remember he had an accident in an LS-6 caused by a disconnected flaperon. Stew reviewed my article prior to it being published and identified two things in common with his accident. In both cases we assembled with the control surfaces locked. (LS-6 wing cuffs in place and my ruddervator gustlocks in place.) We were both in a hurry to launch and didn't do a PCC. This sequence is becoming all too familiar. Wayne HP-14 "Six Foxtrot" http://www.soaridaho.com/Schreder "Bob Kuykendall" wrote in message ... On Jun 3, 7:18 pm, wrote: For ships with *auto hookups* positive control checks are a waste of time, and in fact do more harm then good. .... Snip.. In my history as a glider bum, I have seen: * HP ruddervator, supposedly auto-connecting, failure to engage its driver on assembly, allowing only up/left input. Condition discovered in pre-flight. Dick Schreder not so lucky (but still pretty lucky!) with the RS-15 prototype. ....Snip.... Thanks, Bob K. http://www.hpaircraft.com/hp-24 |
I towed out and gridded. On the grid I still felt there was something
wrong, but couldn't put my finger on what was wrong. I asked another experienced pilot to do a control check before I launched. We found nothing wrong. In between this last paragraph and the text below, did you go through a pre-flight checklist, that had a C for "CONTROLS, CLEAR AND FREE- FULL MOVEMENT? Or did the problem not manifest itself until full flight? As soon as the tow commenced I could see what the problem was. I only had approx half stick movement. Umm, pop the cord? Did you not also have an E somewhere on your preflight checklist, for EMERGENCY, which in theory should have left you with clear options for aborting a takeoff at different phases? I realize that the layout of the airport this happened at may not have good emergency options and also that it may not have occurred until already past the "point of no return" so these points may be moot and your actions taken executed flawlessly (after all, you are here to tell about it...), so I don't mean to harp. I'm just curious if this particular frightening occurrence could have been avoided altogether or at least handled at MUCH lower energies if a thorough preflight checklist was actually performed. Thanks for sharing. Paul Hanson |
On Jun 4, 12:54*pm, "Wayne Paul" wrote:
As mentioned in another thread. I too had a disconnected HP ruddervator and wrote an article about it for Soaring.http://www.soaridaho.com/Schreder/St...mbly_Check.pdf This article contains a link to Dick Schreder's RS-14 adventure. Back when I was in the Navy I served with Steward Tittle. *We have kept in touch through out the years. *As many of you will remember he had an accident in an LS-6 caused by a disconnected flaperon. *Stew reviewed my article prior to it being published and identified two things in common with his accident. *In both cases we assembled with the control surfaces locked. (LS-6 wing cuffs in place and my ruddervator gustlocks in place.) *We were both in a hurry to launch and didn't do a PCC. This sequence is becoming all too familiar. Wayne The LS6 configuration makes the critical PCC extremely easy to accomplish solo. Just stand behind the wing at the fuselage, and grasp both flaperons at the same time. They can then be checked for symmetrical and assymetrical motion and resistance. For those not familiar with them, the LS6 elevator is auto and can be checked visually for engagement. I assemble with the control surface lock in place as the flaperons can foul the drive fairings if left to drop all the way. Since the only real emergency in the LS6 flight manual is takeoff with a disconnected flaperon, I am extremely conscious of the need to get it right - by feel when hooking up the hotelliers and safeties, by sight using the mirrors provided, and by PCC. I have rigged an LS4 and misconnected a spoiler, so I know it can be done. (Caught during a PCC on the grid at Parowan, thanks PT!). Now if it would just stop raining, maybe we could get some gliding in! Kirk Soggy in St Louis (30+ inches of DiHydrogenMonoxide and counting...) |
time, and in fact do more harm then good. I have never heard of a PCC should also cover whether the stabilizer is actually bolted on and bolted all the way. Good luck flying a glider with stabilizer flapping up and down, regardless of whether it has auto hookup or manual. Reminds me of the discussion about the wing pins being in all the way. |
#28
After all, he's going to be the one in trouble if he's wrong. But it Let's tackle that statement once and for all, shall we? Yes, there's usually only 1 guy in the cockpit of a sailplane; and if he doesn't do a CAC and a PCC then his ass is the one most at risk. BUT, let us not forget that there is a tow-plane on the other end of the rope! And what about the other pilots and aircraft at the airport? What about possible bystanders (demo ride people and their families, for example)? An out-of-control glider can be just as deadly to those people as it can be to the person inside it. And I think the lawyers would have a FIELD DAY with the issue of responsibility, if someone on the ground got hurt as a result of an improperly assembled glider. I know this wasn't Ian's main point in his post - but its important to mull this over before you think that "its OK becuase I'm the one who will pay if I screw up". You can't be that certain. --Noel P.S. Contrary to popular belief, its possible to be safe AND still have a ton of fun. Being safe doesn't mean being nasty or boring - it just means taking 5 minutes to be responsible! |
#29
sisu1a wrote:
In between this last paragraph and the text below, did you go through a pre-flight checklist, that had a C for "CONTROLS, CLEAR AND FREE- FULL MOVEMENT? Or did the problem not manifest itself until full flight? Normal control checks were done. Restricted range of movement should have been noticed, but as I said, the glider was relatively new, and it was the first flight of the season after maybe three months in the trailer. You might notice a trend in start of season incidents. Currency and familiarity with the equipment you're flying and the environment you're flying in are important factors. Umm, pop the cord? Did you not also have an E somewhere on your preflight checklist, for EMERGENCY, which in theory should have left you with clear options for aborting a takeoff at different phases? I realize that the layout of the airport this happened at may not have good emergency options and also that it may not have occurred until already past the "point of no return" so these points may be moot and your actions taken executed flawlessly (after all, you are here to tell about it...), so I don't mean to harp. I'm just curious if this particular frightening occurrence could have been avoided altogether or at least handled at MUCH lower energies if a thorough preflight checklist was actually performed. Thanks for sharing. As the glider was stable and there was nowhere good to go ahead I elected to continue with the tow and try to sort it out with a little altitude. I used the time on tow to think about what I was going to do. -- Philip Plane _____ | ---------------( )--------------- Glider pilots have no visible means of support |
#30
One of my friends from RAS told me about this thread and asked that I put
the link in for my presentation on PCC. http://www.mymedtrans.com/personal/ |
| Thread Tools | |
| Display Modes | |
| Some more positive GA News | Jay Honeck[_2_] | Piloting | 22 | February 4th 08 02:46 AM |
| USA Today .. Positive GA Pub | Jay Beckman | Piloting | 65 | February 14th 07 11:36 PM |
| Positive, All-Comers Welcome. | Jim Culp | Soaring | 4 | January 2nd 05 07:18 AM |
| some positive press for GA | Dave Butler | Piloting | 1 | January 28th 04 04:07 PM |
