Airworthiness Certificate Replacement?
Old June 26th 08, 03:15 PM posted to rec.aviation.soaring
Default Airworthiness Certificate Replacement?
Has anyone ever gotten a replacement airworthiness certificate
document after losing the original? If it's possible, what is the
process?
Old June 26th 08, 03:31 PM posted to rec.aviation.soaring
JJ Sinclair
process?
Send a letter to the Federallies at Oak City, they have a folder on
all aircraft registered in the US. Give then your N number and request
replacement of whatever you lost.
JJ
Adam
process?
Go to this site:
http://162.58.35.241/e.gov/ND/airrecordsND.asp
Enter you N-number and serial number. For $10 the FAA will send you a
CD (or paper) of every registration and airworthiness record they have
on the plane.
/Adam
Old June 26th 08, 03:47 PM posted to rec.aviation.soaring
process?
Go to this site:http://162.58.35.241/e.gov/ND/airrecordsND.asp
on the plane.
/Adam
Does the "paper" version of that include the appropriate printed
document to go in the aircraft?
Old June 26th 08, 04:26 PM posted to rec.aviation.soaring
process?
Go to your local FSDO/MIDO with copy of registration and your other
stuff like log book
and they can issue you one on the spot.
Easily done- I did it 2 wk ago.
They may ask you to get the file, but usually not. They can confirm
certificate type from their
database.
Give 'em a call, I've had excellent service from our local guys.
UH
Old June 26th 08, 04:36 PM posted to rec.aviation.soaring
process?
stuff like log book
database.
UH
Thanks. I'm asking for a friend. She tried that at her local FSDO.
They don't know squat. They're making her start completely from
scratch, including going all the way back to the manufacturer
(Germany) for documentation. I thought I'd ask here because I just
could not believe that the FAA couldn't look it up and print off
another certificate to place in the aircraft. The registration and
airworthiness are on file and active/valid.
Old June 26th 08, 08:11 PM posted to rec.aviation.soaring
process?
stuff like log book
database.
UH
Well, it turns out she went into the office and got some immediate
help from a different person. They gave her what she needed right
away.
Thanks,
Dave
TBO and airworthiness Jim Stewart Owning 26 April 17th 07 06:05 PM
USA Glider Experimental Airworthiness Certificate charlie foxtrot Soaring 4 April 15th 06 06:04 AM
Need replacement medical certificate Ben Smith Piloting 3 January 31st 05 11:13 PM
Exhibition/Racing Airworthiness Certificate Question bsquared Soaring 5 June 22nd 04 07:24 PM
Replacement AW certificate PaulH Owning 6 June 15th 04 02:41 PM
