Tom Knauff's newsletter
Old July 4th 08, 04:27 AM posted to rec.aviation.soaring
Nyal Williams[_2_]
Default Tom Knauff's newsletter
OK, I don't do trig. How much difference would it make if the speed were
45kts at a 45 deg bank?
At 23:41 03 July 2008, Tony Verhulst wrote:
Nyal Williams wrote:
I notice from the back seat in a left turn that the yaw string for the
front cockpit is slightly more to the right than the one in the back;
I
believe this to be because the front one is farther from the center of
lift -- or the tangent of the turning radius.
I suspect not. Assuming the following: 1. on a 2 seater, the front yaw
string is about 6 ft (2m) ahead of the center of lift. 2. According to
the American Soaring handbook, a 45 degree banked turn at 60 mph (52
kts) has a radius of 240 feet (73m).
High school level geometry and trigonometry (I've been out of high
school for a looong time :-) ) shows that this results in an error of
only 1.4 degrees - small enough to be ignored for all practical
purposes.
I suspect that a yaw string, typically taped to the canopy, may have
errors because the string is in the boundary layer.
Tony V.
  #42
Nyal Williams[_2_]
I
purposes.
Tony V.
  #43
Old July 4th 08, 06:02 AM posted to rec.aviation.soaring
sisu1a
But the 2 instruments measure different things. The yawstring (in
theory) measures airflow angle at the fuselage. The inclinometer
measures the difference between gravity and the opposite centripetal
force - when in balance, the ball is centered.
True they measure different forces, but they derive appx the same info
for the pilot- status of turn coordination.
The question is, which is a better measure of coordination?
BOTH! A good ball is more accurate, but it's responses are more
damped. The string gives you a good enough approximation for gaggling
and such, but no reason not to have a ball as well (works better in
icing too...) since they are available as 'space miser' instruments as
well (screwed in under an existing instrument by sharing two bottom
holes) and don't hog panel.
Because of the difference in drag at the
wingtips during the turn, the nose may yaw away from the center of the
turn. The yaw string would show that, while at the same time, the
inclinometer would be centered.
Again, the damped response of the ball vs the string. This effect is
amplified by using a low quality ball and a high quality string ;-)
It is recommended by some (Helmut Reichman was amongst this crowd)
that believe that a normal ball in fluid is too slow for soaring, and
instead used an inverted curved glass tube with a bubble of air. He
also used a string of course...
I should experiment in my LS6. Lord knows that I'm tired of looking
up
at the gaggle :-).
We really do appreciate the warning though ;-)
-Paul
  #44
Old July 4th 08, 02:00 PM posted to rec.aviation.soaring
kirk.stant
I should experiment in my LS6. Lord knows that I'm tired of looking up
at the gaggle :-).
Tony V.
Tony, I've found that my LS6 prefers to thermal with several degrees
of apparent slip as indicated by the yaw string - if I try to center
the yaw string with the rudder, I have to use much more aileron to
control the bankangle and prevent overbanking.
Once established and trimmed, hands off, she will thermal on her own
just fine, maintaining that slight slip.
Pretty much agrees with what Dick Johnson wrote.
Kirk
66
  #45
Old July 4th 08, 11:10 PM posted to rec.aviation.soaring
By now, most people are bored with this thread, so I expect few will
get to this post. I generally avoid posting to RAS because of the
hostile responses / postings.
In this case, the demonstrable thesis that most glider pilots do not
have the knowledge to fly safely is generally supported by the
postings to date.
There is only one bottom line to aviation knowledge, and that is the
demonstrated safety record. In our case, there are no reliable
statistics save one: the fatality rate. Glider fatalities are reported
most of the time (not all.) Simply dividing the number of fatalities
into the membership gives a fatality rate that can be compared with
other activities. The NTSB has web sites listing comparisons of
fatality rates for many activities. Gliding is the worst of all. There
will be several postings to quibble with this last statement, but it
is true if you care to look it up.
It is also true that we have been teaching people to fly for 44 years,
and no one we taught as died. Last year we had an experienced power
pilot who we transitioned to gliders who had a seizure and we did do
his transition training.
So we are doing something right. That something, is to teach
everything stated in the FARs, to the standard implied by the PTS.
Nothing more, nothing less.
When it comes to specifics, the legal system punishes those who do not
comply with the standard, so we ensure everything we teach is correct.
We have been successful and we have a lot to lose if we do it wrong.
In the early days, we enlisted famous people like Wolfgang
Langeweische and Derek Piggott to help us. Both came to our gliderport
several times. We will long remember the discussions. Many other very
experienced instructors also helped, and of course we used every
reference to establish standards still used today.
You can see the differences of opinions in the details of this thread.
If you ask specific questions on even the simplest subjects, you will
get many firmly held opinions.
So, anyway, I don’t have the time to get involved with the discussions
in this newsgroup. Most everything I know, I have written in books and
articles, and made presentations at SSA conventions, seminars and FAA
Glider CFI Revalidation Clinics, which I started many years ago.
For those of you who made it this far, I figure you deserve answers to
the three questions.
During a steep left turn, how are the controls held?
Right aileron to counteract the overbanking tendency.
Left Rudder in the direction of the turn. (A paragraph or two is
required to explain this, but the right wing in this case is creating
more drag and the tail needs to be slightly outside the arc of the
turn as the CG is exactly on the arc.)
Back stick pressure. The glider weighs more in a turn, and the center
of mass is ahead of the center of lift.
During a left turn on aerotow, the glider pilot should see the left
side of the towplane’s fuselage. The suggested analogy of sitting in
an aft car of a railroad train during a turn is a good mental image.
Finally, what color field is most desirable on an off field landing?
The answer as so often happens is – “It depends.”
But, if you had to pick one answer, it would be the color of the
earth. There is an adage stated as, “You won’t get hurt if you land it
dirt.”
However, this does not mean a freshly plowed field, which has deep
furrows, rocks and giant clods of hard earth.
You want a freshly cultivated field that has been plowed, harrowed and
the rocks have been removed for generations.
In some parts of the planet, this is not possible. It never happens,
so you must go to plan B.
Freshly harvested fields usually have one major problem. Time has gone
by and animals have dug landing gear burrows in the ground just
waiting for the next glider landing gear. Erosion can also be a
problem.
Some crops are planted in nice earth color, but on top of prepared
mounds. You must be familiar with the farming practices of your local
area to choose wisely.
In the NE USA, farmers have an adage, “Knee high by the 4th of July.”
This means corn should be this high by the 4th if the crop is to be a
good one. For glider pilots, it means you generally can no longer land
in a fresh corn field. The good news, is the alfalfa crop is being
harvested about this same time, by then animal holes are a high risk.
Well, there is a lot more to this subject and Doris is taking me to
see fireworks. I suppose I omitted something important in the above,
and I am equally sure there will be some who will blast away as that
seems to be the tenure of the medium. I probably won’t respond.
Frankly, everything you need to know to fly safely has been written. A
small library would include excellent books by Derek Piggott, Wolfgang
Langeweische, Anne & Lorne Welch and others. For those of you who
abhor self-promotion in this forum, I’ll avoid telling you my books
have everything required by the FAA flight training requirements, have
been described as “the best training manuals of any kind,” and are
easy to read and understand. I also won’t mention you can find them on
our web site: www.eglider.org
At the bottom of our web site you will find links to several flight
safety newsletters I have written over recent years. They are free!
Happy fourth of July!!!
Tom Knauff
http://www.eglider.org
  #46
Old July 5th 08, 12:56 AM posted to rec.aviation.soaring
Jim Logajan
[posted and mailed]
I've done an analogous computation and your assertion above appears to
be surprisingly incorrect (or the source of my data or methodology is
highly corrupted - you decide.) By my calculations the metric you
mention actually shows aviation accidents of all types to be
approximately _over three times greater then gliding_. The single worst
accident rate in aviation appears to be helicopters, which is seven
times worse than gliding!
My own conclusion is that gliding, by your suggested metric, is actually
safer than aviation in general!
I'm afraid I can't reconcile my results with your assertion, since you
haven't provided specifics on your methodology or data. But for the
record (and critique) here's the methodology I used (numeric results are
at bullet point (7) for the impatient):
(1) I used the NTSB accident query database as my data source for
accident counts:
http://www.ntsb.gov/ntsb/query.asp
(2) I used the FAA Civil Airman Statistics web page to get an estimate
of the number of all active airmen certificates, those holding rotocraft
class, and those holding glider class (Tables 1, 7, and 8 at this site):
http://www.faa.gov/data_statistics/a...atistics/2007/
(3) In the NTSB web site I selected a large enough range that a single
bad or good year wouldn't cause unexpected outliers to dominate, but not
so large as to encompass long term trends. So I selected the 8 year
range of 2000-1-1 to 2007-12-31.
(4) I elected to count only the number of fatal accident records, rather
than attempt to add up the fatalities in all the matching records. There
were simply too many accidents in the entire period to manually do the
arithmetic for this exercise (maybe some other time.) In any case, since
glider accidents rarely involve more than 1 fatality per accident, this
method actually should work against the gliders since other aviation
accidents, on average, involve more fatalities per accident.
(5) As of 2007, the FAA estimates 590,349 active airmen certificates of
all classes. It estimates 30,853 pilots with rotocraft and 29,513 with
glider. Of those 29,513 with glider, 14,955 hold nothing but glider.
(6) In the 8 year range, selecting only for "Fatal" accident severity,
then subselecting for "Category: All" I get 3407 accident records. For
"Category: Helicopter" I get 356 accident records. For "Category:
Glider" I get 46 accident records.
(7) Using the above sources and method, my results a
(A) For all aviation accidents:
(3407 fatal accidents/8 years)/590,349 pilots =
0.00072 fatal accidents/(pilot-year)
(R) For rotorcraft accidents:
(356 fatal accidents/8 years)/30,853 =
0.00144 fatal accidents/(pilot-year)
(G) For glider accidents:
(46 fatal accidents/8 years)/29,513 =
0.00020 fatal accidents/(pilot-year)
(G.1) If all the glider accidents were due only to those who could only
fly gliders:
(46 fatal accidents/8 years)/14,955 =
0.00038 fatal accidents/(pilot-year)
While my computations seem to imply gliders are actually safer than
other methods of flying, the metric is of course highly suspect.
Lastly, for the record, an Australian cross modal safety comparison
found that motorcycling was probably the least safe mode of transport:
http://www.atsb.gov.au/publications/...omparisons.pdf
(Unfortunately gliders weren't broken out into their own category.)
  #47
Old July 5th 08, 02:33 PM posted to rec.aviation.soaring
Andy[_1_]
On Jul 4, 4:56*pm, Jim Logajan wrote:
I think that for a meaningful risk analysis the number of fatalities
should be compared to either the hours of risk exposure, or the number
of risk exposure events. This means either the number of flights, or
the number of flight hours, should be used rather than the number of
people qualified to participate.
FAA atempts to gather data on power pilots flight hours at every
medical exam. That data is not collected for pilots with only a
glider rating.
Andy
  #48
Old July 5th 08, 03:20 PM posted to rec.aviation.soaring
As Andy noted, the FAA does not systematically collect glider pilot related
flight data. This is also true for Ultra-light, balloon, and the rapidly
growing Sport Pilot communities.
Without knowing the number of flights and flight hours, it is very difficult
to develop meaningful statistical based risk analysis.
There is even a problem using the FAA database to identify the number of
pilots with a specific rating. It appears from doing a couple "spot check"
that pilots who have died are not being removed. So, currently the only way
to identify active pilots is to identify those with active medicals. The
only solution that I can think of is for the FAA to start recording biannual
flight review dates. A pilot's flight history could be part of the biannual
report.
HP-14 "Six Foxtrot"
http://www.soaridaho.com/
"Andy" wrote in message
glider rating.
Andy
  #49
Old July 5th 08, 03:30 PM posted to rec.aviation.soaring
Bill Daniels
glider rating.
Andy
Actually, I don't think there is any possibility of a meaningful risk
analysis since the overwhelming determinant is pilot skill. You can't
simply lump all pilots in the same statistical pool and try to extract a
"risk analysis" of soaring while ignoring the "800 pound gorilla in the
room" which is pilot knowledge and skill.
The only meaningful analysis is the one an individual pilot makes when
asking if todays flight consitiutes an acceptable risk.
Bill Daniels
"Soaring is very safe if you don't crash."
  #50
Old July 5th 08, 03:54 PM posted to rec.aviation.soaring
Frank Whiteley
I did the annual report on glider pilot trends for the SSA world
report for 2007. The FAA stats on US glider pilot ratings are just
estimates, which aren't adjusted until about April of the following
year. At that point there was about decline of about 2,000 from the
one January number, and about 400 lower than my guessimate. We are
losing many senior glider rated, and mostly inactive, pilots each
year. The more appalling statistic was the lowish number of new
glider only ratings and the very low number of add-on ratings.
That said, requiring CFI's to input flight review dates would help us
really understand our activity and only add one or two fields to the
database. Since many take their FR's in other aircraft types, it
would mean capturing those dates for all pilots. It might meet with
some resistance and only slightly clarify our perspective, since many
may not exercise their glider rating.
As we no longer require the use of the SSN with the pilot's license, I
don't see any simple method for the FAA to cull their records by using
the other SSA's death records.
You can find all sorts of statistics to justify about any perspective.
Frank Whiteley
flight data. *This is also true for Ultra-light, balloon, and the rapidly
pilots with a specific rating. *It appears from doing a couple "spot check"
that pilots who have died are not being removed. *So, currently the only way
report.
HP-14 "Six Foxtrot"http://www.soaridaho.com/
of risk exposure events. *This means either the number of flights, or
medical exam. *That data is not collected for pilots with only a
glider rating.
Andy
Tom Knauff's Newsletter [email protected] Soaring 0 January 7th 08 08:42 PM
Tom Knauff Newsletter Thomas Knauff Soaring 0 September 19th 05 04:02 PM
Nov 15 SSA E-Newsletter Online Jim Skydell Soaring 2 November 18th 04 03:20 AM
Name that newsletter JohnT. Home Built 4 July 8th 04 08:23 PM
Latest Newsletter Michael Coates Home Built 3 July 15th 03 10:04 PM
