One of my friends is bothered by his Becker radio, emitting terrible
noises through the speaker, whose origin seems to be the flight computer (LX7000). The power supply to both devices is fitted with ferrites. I tried a few tricks, like wiring the metal case of one or both devices directly to the negative or to other metal parts of the cockpit. No effect. One thing is a bit disconcerting for me: as I removed the antenna cable from the radio, the noise stopped immediately. The antenna is integrated in the fin, pretty far away from the panel. The antenna cable looks like new, it is not bundled together with other wires and isn't too long. Anybody have any suggestion? thank you very much! Aldo Cernezzi |
On Jul 30, 5:22*pm, cernauta wrote:
One of my friends is bothered by his Becker radio, emitting terrible noises through the speaker, whose origin seems to be the flight computer (LX7000). The power supply to both devices is fitted with ferrites. I tried a few tricks, like wiring the metal case of one or both devices directly to the negative or to other metal parts of the cockpit. No effect. One thing is a bit disconcerting for me: as I removed the antenna cable from the radio, the noise stopped immediately. The antenna is integrated in the fin, pretty far away from the panel. The antenna cable looks like new, it is not bundled together with other wires and isn't too long. Anybody have any suggestion? thank you very much! Aldo Cernezzi A penny's worth... It sounds like this is happening when not transmitting (But if only when transmitting it is likely the microphone wiring). How does the RF connector look at the antenna cable, especially the shield connection. If you give it a good wiggle when connected does it change what you hear? Does it use a screw nut to hold the braided shield? if so test by wiggling the nut, but I would replace it with a crimp on connector as a matter of principle. BTW many people seem to assume Becker wiring harnesses are somehow shielded - as you've no doubt noticed the shroud on the harness is just plastic netting. Are the ferrite isolators as close as possible to the power supply cable entry on the Radio and LX7000? The isolators should roughly be as big as the first part of your thumb or forefinger and the wire should loop through several times. Large size split style/snap together isolators are handy to use to test on cables even if too large to leave in the glider. The earth wires should be as short as possible and bond to a common tie point (probably better in the confined space of a glider panel) or thick bus bar/cable. Run both the earth and positive side of the power through the ferrite cores, at least to start with. Check the tie point/ connections for even the slightest amount of corrosion. Anything not pretty and shiny should be replaced. Try disconnecting each data and other non-power cabling from the LX7000 and see if that makes things better or worse. If so look at those cables carefully for problems, or try putting ferrite cores on them. Inspect all the wiring, remove and replace any PVC insulated wire with Tefzel insulated MIL spec wiring :-) (my real reason for posting was I just wanted to say that). Darryl |
On Wed, 30 Jul 2008 18:28:52 -0700 (PDT), Darryl Ramm
wrote: It sounds like this is happening when not transmitting Correct . How does the RF connector look at the antenna cable, especially the shield connection. If you give it a good wiggle when connected does it change what you hear? No, it doesn't. Are the ferrite isolators as close as possible to the power supply cable entry on the Radio and LX7000? Yes. Inspect all the wiring, remove and replace any PVC insulated wire with Tefzel insulated MIL spec wiring :-) (my real reason for posting was I just wanted to say that). :-)) I'll check everything you kindly suggested thanks! Aldo |
Sounds like the problems I fought for years with the B-100, ie your
computer and or GPS is pumping out RF on or near 123.3/5. Try disconnecting the GPS and see if your radio stops breaking squelch. If so, try moving the GPS away from the computer and or radio. If your running a model-20, Cambridge can fix the RF emissons. Try moving the GPS display away from the computer/radio. I never did get it completely fixed and finally gave up and bought an SN-10. JJ On Jul 30, 5:22*pm, cernauta wrote: One of my friends is bothered by his Becker radio, emitting terrible noises through the speaker, whose origin seems to be the flight computer (LX7000). The power supply to both devices is fitted with ferrites. I tried a few tricks, like wiring the metal case of one or both devices directly to the negative or to other metal parts of the cockpit. No effect. One thing is a bit disconcerting for me: as I removed the antenna cable from the radio, the noise stopped immediately. The antenna is integrated in the fin, pretty far away from the panel. The antenna cable looks like new, it is not bundled together with other wires and isn't too long. Anybody have any suggestion? thank you very much! Aldo Cernezzi |
New technologies flight computer | Ed Gaddy[_2_] | Soaring | 1 | July 14th 08 07:43 PM |
FM radio interference from planes | rb | Piloting | 34 | July 19th 06 05:53 PM |
GPS / radio interference | Cub Driver | Piloting | 2 | October 31st 04 10:57 PM |
radio / vario interference - HELP! | Chris Davison | Soaring | 13 | November 3rd 03 06:09 AM |
Radio Interference Information | Ross Richardson | Piloting | 0 | October 17th 03 02:06 PM |
