I notice that there are Ivoprop makes an in flight adjustable
	propeller suitable for a an o-200 engine. I understand that putting this prop on my C-150 is illegal. But suppose ... Suppose I put this prop on my Cessna 150. It only weighs 9.5 pounds, as compared to the Sensenich weight of 24 pounds. So I save 14.5 pounds. Can anyone guess how this would effect my performance? How much better climb and how much better cruise? -Just curious See http://www.ivoprop.com/inflightultralightmodel.htm And http://www2.sensenich.com/misc/c150.htm  |
			 "Charles Talleyrand" wrote in message ... Suppose I put this prop on my Cessna 150. It only weighs 9.5 pounds, as compared to the Sensenich weight of 24 pounds. So I save 14.5 #. But it will make a largish change in your CG. The fuel and passenger load for a 150 are both near the CG, so you might end up putting a few pounds of ballast in the tail to stay within the CG envelope. That would cost you some of the initial weight advantage. Can anyone guess how this would effect my performance? How much better climb and how much better cruise? Nobody can answer that question until you specify a pitch. Any given fixed pitch prop will be optimized for climb (at the expense of cruise speed) or cruise (at the expense of takeoff and climb performance) or somewhere in between. -- Vaughn Nothing personal, but if you are posting through Google Groups I may not receive your message. Google refuses to control the flood of spam messages originating in their system, so on any given day I may or may not have Google blocked. Try a real NNTP server & news reader program and you will never go back. All you need is access to an NNTP server (AKA "news server") and a news reader program. You probably already have a news reader program in your computer (Hint: Outlook Express). Assuming that your Usenet needs are modest, use http://news.aioe.org/ for free and/or http://www.teranews.com/ for a one-time $3.95 setup fee. Will poofread for food.  |
On 08/15/08 12:10, Vaughn Simon wrote:
	"Charles Talleyrand" wrote in message ... Suppose I put this prop on my Cessna 150. It only weighs 9.5 pounds, as compared to the Sensenich weight of 24 pounds. So I save 14.5 #. But it will make a largish change in your CG. The fuel and passenger load for a 150 are both near the CG, so you might end up putting a few pounds of ballast in the tail to stay within the CG envelope. That would cost you some of the initial weight advantage. If you reduce the weight of the prop, won't that move your CG aft? Requiring less weight in the tail (actually, anywhere behind the CG) to support the same flight envelope? Can anyone guess how this would effect my performance? How much better climb and how much better cruise? Nobody can answer that question until you specify a pitch. Any given fixed pitch prop will be optimized for climb (at the expense of cruise speed) or cruise (at the expense of takeoff and climb performance) or somewhere in between. -- Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot Cal Aggie Flying Farmers Sacramento, CA  |
On Aug 15, 3:10 pm, "Vaughn Simon"
	wrote: "Charles Talleyrand" wrote in message ... Suppose I put this prop on my Cessna 150. It only weighs 9.5 pounds, as compared to the Sensenich weight of 24 pounds. So I save 14.5 #. But it will make a largish change in your CG. The fuel and passenger load for a 150 are both near the CG, so you might end up putting a few pounds of ballast in the tail to stay within the CG envelope. That would cost you some of the initial weight advantage. Can anyone guess how this would effect my performance? How much better climb and how much better cruise? Nobody can answer that question until you specify a pitch. Any given fixed pitch prop will be optimized for climb (at the expense of cruise speed) or cruise (at the expense of takeoff and climb performance) or somewhere in between. Actually, one can assume that it will climb at least as well as the standard climb prop, and cruise at least as well as the standard cruise prop. The difference between the cruise (normal) prop climb performance, and the climb prop climb performance, will be available to cruise prop users. The difference between the climb prop cruise performance, and the cruise prop cruise performance, will be available to climb prop users. Anyone know these numbers? Alternatively, there must be planes that have used both fixed and constant-speed props. Anyone know the difference?  |
Charles Talleyrand  wrote:
	Alternatively, there must be planes that have used both fixed and constant-speed props. Anyone know the difference? Don't know about the Cessna 150, but I'm pretty sure some owners of experimentals (such as the RV series) have tried both fixed and later constant speed props on the same engine and airframe. If interested, I suspect one could find numbers mentioned on the forums on this web site: http://www.vansairforce.net/  |
On Aug 15, 1:27*pm, Mark Hansen  wrote:
	On 08/15/08 12:10, Vaughn Simon wrote: "Charles Talleyrand" wrote in message .... Suppose I put this prop on my Cessna 150. *It only weighs 9.5 pounds, as compared to the Sensenich weight of 24 pounds. *So I save 14.5 #. * * But it will make a largish change in your CG. *The fuel and passenger load for a 150 are both near the CG, so you might end up putting a few pounds of ballast in the tail to stay within the CG envelope. *That would cost you some of the initial weight advantage. If you reduce the weight of the prop, won't that move your CG aft? Requiring less weight in the tail (actually, anywhere behind the CG) to support the same flight envelope? Can anyone guess how this would effect my performance? *How much better climb and how much better cruise? * *Nobody can answer that question until you specify a pitch. *Any given fixed pitch prop will be optimized for climb (at the expense of cruise speed) or cruise (at the expense of takeoff and climb performance) or somewhere in between. -- Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot Cal Aggie Flying Farmers Sacramento, CA Mark is dead right on this one,,, And you might end up with an ill handling plane with an aft CG that will happen..... be safe out there.  |
			 "Mark Hansen" wrote in message ... If you reduce the weight of the prop, won't that move your CG aft? Requiring less weight in the tail (actually, anywhere behind the CG) to support the same flight envelope? (Let's see, how can I gracefully get out of this one...OK, I know...) Brain fart! Yes, you are 100% correct. We would need to saw off tail structure to fix the CG. (just kidding) Worst case, you would need to add weight as far forward as possible, and that added weight would have to be MORE than the weight that you saved by swapping the prop because it would necessarily need to be mounted closer to the CG than where the weight came off (the prop). Just to add a bit of noise to the discussion, an airplane operating at maximum allowed aft CG is actually more aerodynamically efficient. Sailplane pilots often add tail ballast for just this reason. -- Vaughn Nothing personal, but if you are posting through Google Groups I may not receive your message. Google refuses to control the flood of spam messages originating in their system, so on any given day I may or may not have Google blocked. Try a real NNTP server & news reader program and you will never go back. All you need is access to an NNTP server (AKA "news server") and a news reader program. You probably already have a news reader program in your computer (Hint: Outlook Express). Assuming that your Usenet needs are modest, use http://news.aioe.org/ for free and/or http://www.teranews.com/ for a one-time $3.95 setup fee. Will poofread for food.  |
I would think he would need extra weight in the nose.. not in the tail.
	BT "Vaughn Simon" wrote in message ... "Charles Talleyrand" wrote in message ... Suppose I put this prop on my Cessna 150. It only weighs 9.5 pounds, as compared to the Sensenich weight of 24 pounds. So I save 14.5 #. But it will make a largish change in your CG. The fuel and passenger load for a 150 are both near the CG, so you might end up putting a few pounds of ballast in the tail to stay within the CG envelope. That would cost you some of the initial weight advantage. Can anyone guess how this would effect my performance? How much better climb and how much better cruise? Nobody can answer that question until you specify a pitch. Any given fixed pitch prop will be optimized for climb (at the expense of cruise speed) or cruise (at the expense of takeoff and climb performance) or somewhere in between. -- Vaughn Nothing personal, but if you are posting through Google Groups I may not receive your message. Google refuses to control the flood of spam messages originating in their system, so on any given day I may or may not have Google blocked. Try a real NNTP server & news reader program and you will never go back. All you need is access to an NNTP server (AKA "news server") and a news reader program. You probably already have a news reader program in your computer (Hint: Outlook Express). Assuming that your Usenet needs are modest, use http://news.aioe.org/ for free and/or http://www.teranews.com/ for a one-time $3.95 setup fee. Will poofread for food.  |
Don't forget the CG change.. losing 14# on the nose is a lot.. you are going
	to be tail heavy BT "Charles Talleyrand" wrote in message ... On Aug 15, 3:10 pm, "Vaughn Simon" wrote: "Charles Talleyrand" wrote in message ... Suppose I put this prop on my Cessna 150. It only weighs 9.5 pounds, as compared to the Sensenich weight of 24 pounds. So I save 14.5 #. But it will make a largish change in your CG. The fuel and passenger load for a 150 are both near the CG, so you might end up putting a few pounds of ballast in the tail to stay within the CG envelope. That would cost you some of the initial weight advantage. Can anyone guess how this would effect my performance? How much better climb and how much better cruise? Nobody can answer that question until you specify a pitch. Any given fixed pitch prop will be optimized for climb (at the expense of cruise speed) or cruise (at the expense of takeoff and climb performance) or somewhere in between. Actually, one can assume that it will climb at least as well as the standard climb prop, and cruise at least as well as the standard cruise prop. The difference between the cruise (normal) prop climb performance, and the climb prop climb performance, will be available to cruise prop users. The difference between the climb prop cruise performance, and the cruise prop cruise performance, will be available to climb prop users. Anyone know these numbers? Alternatively, there must be planes that have used both fixed and constant-speed props. Anyone know the difference?  |
Actually I think it was determined in the sailplane circles.. that having
	the CG at the 85% point was the most efficient.. too far aft was too much and caused nose down stick putting the elevator down into the slip stream, and not far enough aft caused back stick or up elevator into the slip stream. Heavier pilots do add tail ballast which increases the minimum pilot weight for club gliders. BT Just to add a bit of noise to the discussion, an airplane operating at maximum allowed aft CG is actually more aerodynamically efficient. Sailplane pilots often add tail ballast for just this reason. -- Vaughn  |
| Thread Tools | |
| Display Modes | |
| Ground adjustable prop | [email protected] | Home Built | 1 | January 30th 05 07:15 AM |
| adjustable prop bearing | Joe | Home Built | 5 | October 23rd 04 01:00 PM |
| Cessna Prop Needed | Cy Galley | Aviation Marketplace | 0 | January 23rd 04 02:23 AM |
| Hydraulic CS prop converting to Adjustable prop? | Scott VanderVeen | Home Built | 0 | December 5th 03 06:54 PM |
| Adjustable prop experience? | Richard Lamb | Home Built | 0 | July 1st 03 05:07 AM |
