Emfo vs. Jaxida covers
Old September 5th 08, 05:05 PM posted to rec.aviation.soaring
nimbus
Default Emfo vs. Jaxida covers
"Does anyone have any experience with EMFO covers for sailplanes. I
would be interested in how they compare with the ones made by Jaxida.
This question was already asked in 2005....and no real answer was
given to the initial author (James d'Andrea).
I recently have received from Emfo company a small piece of their
cover they are proposing. The external plastic sheet seems to be far
more robust than the one proposed by Jaxida. I intend to buy a Emfo
covers set when the current Jaxida ones I have will be completely
"eaten" by UV.
Has someone a pragmatic experience with the Emfo covers? What is the
expected life time of the Emfo covers? How robust is the Emfo covers
against UV and humidity (belgian weather)
Cheers,
Bruno
Old September 5th 08, 08:14 PM posted to rec.aviation.soaring
sierra
On Sep 5, 12:05*pm, nimbus wrote:
"Does anyone have any experience with EMFO covers for sailplanes. *I
"eaten" by UV.
Cheers,
Bruno
Bruno
I have use EMFO for 3 summer. They fit very well , very well made.and
do not show any sign of wear.
They must be aired if you have heavy dew in the morning. They tend to
accumulate mildew inside otherwise.
The elastic band to attach them could be better but it is a minor
item. Good buy for the price.
Gilles
Old September 5th 08, 08:35 PM posted to rec.aviation.soaring
JS
The EMFO covers are a little heavier, which means they require more
storage space and are a bit of a handful when you're rolling them up.
But this seems to mean good durability too.
My Nimbus 3/25.5 set was their first for that span of N3. The wing
tip panel covers weren't cut right, but they were replaced as soon as
I provided the dimensions that EMFO needed. Great customer support.
The covers have not seen lots of use, and still look quite new.
Old September 6th 08, 09:38 AM posted to rec.aviation.soaring
Rowan Griffin
I bought a set of Emfo covers for my Std. Cirrus 3 1/2 years ago in
preference to Jaxida following discussions with owners of both.
I left my glider rigged for most of the season the first year with the
covers on and have used them fairly regularily since, with the canopy
cover supplied as part of the set used pretty much all the time- they show
no visible signs of UV aging or other signs of wear. I ordered mine at a
busy time and was quoted 6 weeks lead time to have them made and they were
ready to be shipped in 5.
Definately no regrets...
Rowan
Old September 6th 08, 01:03 PM posted to rec.aviation.soaring
Cats
"eaten" by UV.
I'm not sure if they ship to your country, but Vertigo Covers have
been branching out into glider covers of late, and they seem to be
excellent quality and good for several years - I guess Belgian weather
is pretty similar to UK weather. They are certainly more robust than
Jaxida covers, I haven't handled other makes.
Old September 6th 08, 07:23 PM posted to rec.aviation.soaring
John Galloway[_1_]
Having owned 3 sets of Jaxidas and looked at (and seriously considered)
Emfos over the years I would definitely be getting Vertigo covers next
time. The tailoring is a bit simpler than Jaxidas but the coverage is
good and the new material seems excellent. It is not a coated material
but seems to be extremely water resistant. You can easily blow water
beads off the covers by mouth - they just run away. I have been feeling
inside the wing covers of a couple of gliders parked out all wet summer in
them and the interior is dry - unlike my Jaxidas.
I have no connection to or interest in the company.
http://www.vertigocovers.co.uk/Verti...rs_Covers.html
John Galloway
At 12:03 06 September 2008, Cats wrote:
=A0I
"eaten" by UV.
Old September 6th 08, 08:12 PM posted to rec.aviation.soaring
Cats
On Sep 6, 7:23*pm, John Galloway wrote:
snip
*You can easily blow water
beads off the covers by mouth - they just run away. *I have been feeling
And they are new this season - are your Jaxidas?. The acid test will
be in 2-3 years. One problem with mine that seems to be resolving
itself was leakage through the seam along the top of the canopy
cover. BTW was advised to use baby wipes to clean off bird p**!
Old September 7th 08, 07:23 PM posted to rec.aviation.soaring
John Galloway[_1_]
At 19:12 06 September 2008, Cats wrote:
On Sep 6, 7:23=A0pm, John Galloway wrote:
=A0You can easily blow water
beads off the covers by mouth - they just run away. =A0I have been
feelin=
g
summer
i=
n
My Jaxidas are 2 years old but they are made with their newer outer
material which has not deteriorated and seems to be waterproof. What
seems to happen is that in very wet conditions the separate inner
corrugated material absorbs water. My speculation is that it is the
unintended consequence of having a flapping/flexible structure raised
slightly off the wing that allows (sometimes very humid) air to circulate
over the glider surfaces - especially when there are windy conditions. I
think that it is better to have a waterproof but breathable and fairly
heavy and inflexible material lying directly on the wing to minimize
under-the-cover air movement but allow water vapour to escape when the
rain stops.
John Galloway
Old September 7th 08, 08:19 PM posted to rec.aviation.soaring
James D'Andrea
feelin=
g
summer
i=
n
And they are new this season - are your Jaxidas?. *The acid test will
be in 2-3 years. *One problem with mine that seems to be resolving
cover. *BTW was advised to use baby wipes to clean off bird p**!
material which has not deteriorated and seems to be waterproof. *What
corrugated material absorbs water. *My speculation is that it is the
over the glider surfaces - especially when there are windy conditions. *I
rain stops.
John Galloway- Hide quoted text -
- Show quoted text -
I bought a set of EMFO covers for my LS-3-17 and would never consider
buying them again in the future. The cover for the tailplane did not
fit and was obviously made for another glider, and the fuselage cover
fit too snugly to hold the velco attachments on the wing covers. I
notified EMFO of the problems, and they requested that I send them
photos before they would replace them. I sent the photos to both EMFO
and Tom Knauff, the US distributor of EMFO at the time. Despite
multiple emails sent by both me and Tom Knauff, we never received a
reply from EMFO during the next 2 years. During that time, I
continued to use the cover pieces that did fit to partially protect my
glider from the elements. My experience was that EMFOs did not stand
up to the extreme UV conditions and heat of Truckee, CA where my
glider was based (5,900 ft and 90+ deg F). The covers turned brown in
color, shrank, and deteriorated in the sunlight. I sent the covers
back to Knauff who sent them to EMFO as the covers are advertised to
come with a 3 year warranty. When EMFO received the covers, they
quickly responded this time, and accused me of violating the warranty
by washing the covers with a chemical or detergent when in fact I did
not. Evidently, EMFO thought the smell of the detiorated fabric was a
chemical, or was from chemical exposure. In the end and after several
more emails to EMFO, I never got a set of replacements that ever fit
my glider. in my case, EMFO ignored my product complaints about
poorly fitting covers, and blamed me for their covers not standing up
to their durability claims to avoid honoring their warranty. Although
I never got a satisfactory resolution to the problem, Tom Knauff
provided me with excellent customer service in trying to get EMFO to
get me a set of covers that fit during that two year period. My
understanding is that he no longer distributes EMFO nor Jaxida covers,
in part, due to the problems he has had with these companies
supporting their products.
Old September 7th 08, 10:41 PM posted to rec.aviation.soaring
Darryl Ramm
feelin=
g
summer
i=
n
rain stops.
buying them again in the future. *The cover for the tailplane did not
fit too snugly to hold the velco attachments on the wing covers. *I
photos before they would replace them. *I sent the photos to both EMFO
and Tom Knauff, the US distributor of EMFO at the time. *Despite
reply from EMFO during the next 2 years. *During that time, I
glider from the elements. *My experience was that EMFOs did not stand
glider was based (5,900 ft and 90+ deg F). *The covers turned brown in
color, shrank, and deteriorated in the sunlight. *I sent the covers
come with a 3 year warranty. *When EMFO received the covers, they
not. *Evidently, EMFO thought the smell of the detiorated fabric was a
chemical, or was from chemical exposure. *In the end and after several
my glider. *in my case, EMFO ignored my product complaints about
to their durability claims to avoid honoring their warranty. *Although
get me a set of covers that fit during that two year period. *My
A club I used to belong to had some wing covers replaced by Jaxida
under warranty that has deteriorated in the Sun (western USA again).
These were before the new "waxy exterior layer" style fabric that
Jaxida is now using - and might have been a bad batch of previous
style fabric. I've also dealt with Jaxida on getting a kit/
instructions to modify covers existing covers for transparent solar
panel covers, and dealt with Jaxida when there had been a mistake
delivering cover part with a new sailplane I purchased. All in all,
considering language and location issues I've found Jaxida OK to do
business with. For some things I've worked through Williams Soaring to
get info/help from Jaxida (esp. anything requiring payment etc. since
Jaxida like many small European businesses won't accept credit cards).
YMMV. And Bruno is in Europe so dealing with Jaxida should be easier.
Bruno - if this is for your ASH-26E, the long style Jaxida Fueslage
covers (with or without clear solar panel covers) will help keep rain
out of the engine bay opening. Possible humidity build up in the
engine bay if stored for long term under covers is one reasons I would
prefer to keep the 26E in a proper ventilated trailer.
Darryl
FS: PZL Compass, Jaxida covers Ramy Soaring 0 November 1st 07 05:43 AM
Jaxida (or other brand) covers syoun10 Soaring 6 June 7th 06 07:51 PM
Emfo vs. Jaxida covers faadpe Soaring 2 November 15th 05 01:11 AM
Emfo vs. Jaxida covers James D'Andrea Soaring 5 September 28th 05 10:05 PM
Jaxida covers Miguel Lavalle Soaring 1 March 1st 04 02:45 PM
