Side-mounted canopy -- Prevent blowing shut?
Old September 10th 08, 04:10 PM posted to rec.aviation.soaring
John Galloway[_1_]
Default Side-mounted canopy -- Prevent blowing shut?
At 01:07 10 September 2008, V1 wrote:
Thanks to everyone who provided suggestions. I'm seeing that it's
even more critical to close AND lock than I had considered - a great
tip from Richard (the voice of expensive experience).
- Frank
If your Ventus has a lifting panel then raise the panel every time you
open the canopy. You might get some minor damage to your instrument
cowling (or, in my case, lose the PDA) but it should save the canopy.
John Galloway
Old September 10th 08, 10:52 PM posted to rec.aviation.soaring
Ian[_2_]
On Fri, 05 Sep 2008 12:37:40 -0700, V1 wrote:
I have a side-mounted canopy (Ventus 2). I'm concerned that a gust of
wind could blow it shut when it's in the open position, breaking or
damaging the canopy.
Our club operates from an airfield that regularly experiences fresh to
strong winds.
Club policy is to stage gliders with side hinged canopies at the flight
line such that the prevailing wind will blow the canopy open. Ie these
gliders are staged on the side of the runway either nose facing the
runway, or tail facing the runway, depending on the direction of the
prevailing wind (which goes with the end we are launching from). This is
so that they don't slam shut, damaging equipment and people, when the
pilots are climbing in or out.
The rest of the time canopies must be closed and locked. Even when the
wind is not blowing.
Ian
Old September 10th 08, 11:23 PM posted to rec.aviation.soaring
Big Wings
I bought a canopy cover from
http://www.wingsandwheels.com/page38.htm
The Platinum cover has a version for side lifting canopies. It fits my
Discus2c.
- Frank
John Galloway
Upper Surface Blowing (USB) Charles Gray Military Aviation 1 August 17th 08 10:21 PM
Saturn V S-IC (first) stage are placed side by side prior to commencement of the mating of the two stages 6416485.jpg [email protected] Aviation Photos 0 April 12th 07 01:28 AM
For Mitchell Holman, if you want them... - F-15 & F-16 on pedestals WPAFB side by side.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 4 January 19th 07 01:19 AM
Fueling from Plastic Containers and Blowing yourself up? Juaquin Murrieta Home Built 23 April 11th 05 04:27 PM
Is That a Resistor Wired Between the Hot Side and the Switch Side of the Solenoid? jls Owning 3 April 11th 04 04:55 PM
