"Where do you find the time?"
That's one of the more common questions I'm asked. Probably the best answer is that I don't watch TV. Oh, we've got one -- great big thing the kids bought for us, mostly so they could watch the Bowl games when they come over to visit during the holidays. We watch it too; usually a rented movie or something like that. Americans watch a lot of television. Turn the thing off and you will have 'found' about a thousand hours a year to spend on something useful. "What are some of these projects you're always talking about?" Well... howzabout a landing gear that uses eight wheels instead of two? Or an ultra-light wing panel that uses banister-rail for spars instead of aluminum tubing? Or a geodesic fuselage made by winding 1/16" x 3/4" strips of pine in a spiral? Or making 'emergency turn- buckles' from aluminum extrusion and an AN4 bolt. Or a tail-wheel 'spring' made from the fiberglas handle of a Harbor Freight ax? Or making pulleys from scraps of 3/8" thick aluminum plate. (Select the proper diameter and your control-system pulleys only rotate about 90 degrees.) .....plus a few hundred other things :-) Right now the hottest thing on the burner is my trying to fabricate a mock-up of the forward section of the Chugger's fuselage This is needed so I can make up the engine mount & landing gear legs. But in the mean time I've had to do some electrical repairs to the house and replace a broken water pipe. Looming over all is the need to repair the starter on my 1965 Volkswagen bus. All of this whilst feeding myself sixty-odd pills a day, a weekly visit to the Vampire Corps and pretending to enjoy a diet that would make a maggot gag. Actually, the projects have a lot to do with keeping my spirits up. They start with an idea then progress to a drawing. Most of them die right there. But if the drawing sez the idea is possibly it triggers a search for components: Is it something I can buy? Something I can make? How much does it weigh? How strong is it? (Determining the strength of something is always a lot of fun :-) If the idea survives the initial stages the next step is usually a model although often times it's more practical to go straight to the real thing and bolt it to my drop-tester. If it survives that -- and if it's light enough -- I'll probably write an illustrated article about it, although most ideas lead you right up to the edge of success... then let you down for one reason or another. (Some of you may remember the knee-action landing gear I built. By the time I found a rubber snubber sufficiently stout to withstand the drop-test the thing was about ten pounds over weight.) I don't consider engines to be 'projects' but they do take up a lot of time. Right now I lack the strength to move them about so my progress is very limited. But my strength is coming back. "Man, I don't know where you find the TIME," a visitor said. He needed a couple of M6 bolts, which I happened to have. "Turn off your TV," I told him. He gave me a quizzical look then frowned, as if I'd just told him to murder his wife. Seriously; give it a try. Virtually all of the stuff on TV is utterly worthless; someone else's version of reality. (Do you really think it matters WHO gets elected?) I prefer my own version of reality :-) -R.S.Hoover |
On Sat, 27 Sep 2008 22:03:58 -0700 (PDT), "
wrote: "Turn off your TV," I told him. He gave me a quizzical look then frowned, as if I'd just told him to murder his wife. Seriously; give it a try. Virtually all of the stuff on TV is utterly worthless; someone else's version of reality. (Do you really think it matters WHO gets elected?) I prefer my own version of reality :-) -R.S.Hoover Bob, I'm sorry, but the reality of the world would be much better if Al Gore had been elected, as he should have been in 2000. There would be many Americans alive today who have died in a needless war. Steve in Michigan |
Bob,
I'm sorry, but the reality of the world would be much better if Al Gore had been elected, as he should have been in 2000. There would be many Americans alive today who have died in a needless war. Steve in Michigan Sorry Bob that someone wants to turn your post into a political discussion, however I'll agree with you. I don't even know most of whats on tv but if there is something I want to watch I have a vcr (yes I still use VHS) so I tape it and watch when it's too late in the evening to create noise. I've also found if I just do a little something, no matter what, on the plane every day, gets much accomplished. luckily with a wooden plane it works out great with the gluing. Lou |
On Sep 28, 9:04*am, Lou wrote:
* I've also found if I just do a little something, no matter what, *on the plane every day, gets much accomplished. luckily with a wooden plane it works out great with the gluing. -------------------------------------------------------------------- Dear Lou, Roger that. Indeed, doing SOMETHING EVERY DAY is the 'secret' that no one believes... until they try it. No matter how finely you slice it, there is a finite number of steps between starting and finishing. Do even ONE THING every day and the number of steps is reduced by one. Make it a habit -- even to carrying some parts with you if you have to travel, and working on them during your lay-over -- and your project will progress at a remarkable rate. (I knew an ATR who did this. It REALLY impressed his crews. Not only was he older than god, with a career that stretched from Stinsons to 747's, he was capable of BUILDING HIS OWN AIRPLANE, should the need arise.) For those familiar with the procedure One-a-Day isn't a vitamin, it's a method of construction that GUARANTEES completion in a timely manner. -Bob |
wrote: "Where do you find the time?" I have taken the liberty of joining these messages together in a text document and will be assigning it as required reading tomorrow. I have given my 11th grade students the assignment of building a working steam, I.C., air or sterling model engine as a graduation requirement. I can already see the ones who are "doing something EVERY day" and the slackers who will be in a frantic scurry next year as graduation aproaches. Maybe this will give some of them a jolt of get up and go. Thanks Bob! Errol Groff Instructor, Machine Tool Department H.H. Ellis Technical High School Danielson, CT |
"Ernest Christley" wrote in message ... wrote: and nine months later there is another interruption in the airplane building. Don't worry, after about 30 years of marriage that stops happening... Vaughn |
On Sun, 28 Sep 2008 22:08:59 GMT, "Vaughn Simon"
wrote: "Ernest Christley" wrote in message ... wrote: and nine months later there is another interruption in the airplane building. Don't worry, after about 30 years of marriage that stops happening... Vaughn ************************************************** ************ Vaughn 30 years? I filled the bean jar in 20 and it's still full )If you don't understand this let me know and I'll explain what my granddad told me. Big John |
| Thread Tools | |
| Display Modes | |
| Finding Rentals | Greg Copeland | Piloting | 21 | July 31st 06 04:18 PM |
| First Time Buyer - High Time Turbo Arrow | [email protected] | Owning | 21 | July 6th 04 08:30 PM |
| Finding old buddies | patrick savoie | Military Aviation | 2 | August 29th 03 07:44 PM |
| they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap | tim liverance | Military Aviation | 0 | August 18th 03 01:18 AM |
| Help finding photo | Chris W | Piloting | 11 | July 29th 03 05:07 PM |
