			#21
  The MiG-25 was designed specifically to counter the B-70.
	Correct. Wasn't the B-70 killer missile the Mig-25 was designed to carry called the "Anab"? 40 feet long IIRC. Huge mutha. No... the MiG-25 had the R-40 missile (NATO name AA-6 "Acrid"). And it was only about 20 feet long. FAS has a couple pictures... I wouldn't take their range and performance data seriously (on anything), but as far as physical dimensions they seem to be in the ballpark. http://www.fas.org/man/dod-101/sys/missile/row/aa-6.htm  |
"Bob Martin"  wrote in message
	om... The MiG-25 was designed specifically to counter the B-70. Correct. Wasn't the B-70 killer missile the Mig-25 was designed to carry called the "Anab"? 40 feet long IIRC. Huge mutha. No... the MiG-25 had the R-40 missile (NATO name AA-6 "Acrid"). And it was only about 20 feet long. FAS has a couple pictures... I wouldn't take their range and performance data seriously (on anything), but as far as physical dimensions they seem to be in the ballpark. http://www.fas.org/man/dod-101/sys/missile/row/aa-6.htm Thanx for the correction, Bob. It's been too long since this old fart looked up that data. ;-) But since the Mig-25 was designed to attack at high speeds (and at high speeds everything, attacker and attackee, travels in a straight line), the Mig-25 had small tailfeathers and hence low manuevrebility (sp?). So, it's intended target gone, the 25 became a photorecon platform. It and the later Mig-31 Foxhound in effect became the Soviet's SR-71. Was the AA-6 Acrid missile dropped, or was it "retargeted"?  |
			#24
 (Bob Martin) wrote in
	om: The MiG-25 was designed specifically to counter the B-70. Correct. Wasn't the B-70 killer missile the Mig-25 was designed to carry called the "Anab"? 40 feet long IIRC. Huge mutha. No... the MiG-25 had the R-40 missile (NATO name AA-6 "Acrid"). And it was only about 20 feet long. FAS has a couple pictures... I wouldn't take their range and performance data seriously (on anything), but as far as physical dimensions they seem to be in the ballpark. http://www.fas.org/man/dod-101/sys/missile/row/aa-6.htm Interesting to note that the images depict the IR version, except the mid bottom image, which shows the usual mix of IR on the two inner pylons and radar seekers on the two outboard pylons. Regards...  |
			#25
On Sat, 20 Dec 2003 19:17:34 GMT, "Felger Carbon"
	wrote: "Bob Martin" wrote in message . com... The MiG-25 was designed specifically to counter the B-70. Correct. Wasn't the B-70 killer missile the Mig-25 was designed to carry called the "Anab"? 40 feet long IIRC. Huge mutha. No... the MiG-25 had the R-40 missile (NATO name AA-6 "Acrid"). And it was only about 20 feet long. FAS has a couple pictures... I wouldn't take their range and performance data seriously (on anything), but as far as physical dimensions they seem to be in the ballpark. http://www.fas.org/man/dod-101/sys/missile/row/aa-6.htm Thanx for the correction, Bob. It's been too long since this old fart looked up that data. ;-) But since the Mig-25 was designed to attack at high speeds (and at high speeds everything, attacker and attackee, travels in a straight line), the Mig-25 had small tailfeathers and hence low manuevrebility (sp?). So, it's intended target gone, the 25 became a photorecon platform. It and the later Mig-31 Foxhound in effect became the Soviet's SR-71. Was the AA-6 Acrid missile dropped, or was it "retargeted"? They use the AA-9 (Phoenix ripoff) as the main armament on the Mig-31 although the AA-6 is also shown in some pictures.  |
			#26
			 Scott Ferrin wrote: You could make a case for a Sam being able to knock out any airplane. So why build any at all? Assuming B70's were built and upgraded umpteen times by now, what do you think the results would be with a re-engine of the six pack with a modern supercruise engine such as a F119? Bob Actually I'd be surprised if the F119 powered one wasn't *slower*. The J93 was designed for Mach 3 and high altitudes. The F119 is not. I realize that airflow and inlet geometry are critical for a high mach plane, but what would be different in the guts of the engine? Did the XB-70 burn a non standard fuel like the SR71? I suppose my point was expanded range or payload using the F119. Who knows, maybe there is a orphan XB70 made out of spare parts laying around groom lake somewhere. Might be an interesting platform to test some of the new high tech aero spike or pulse engines. Bob -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =-----  |
			#27
	Scott Ferrin wrote: On Fri, 19 Dec 2003 05:07:37 GMT, Chad Irby wrote: In article , (WaltBJ) wrote: The B70 was doomed once its IR signature was analyzed. Even the B58 at M2.0 had an IR signature the 102's poor old LN2 cooled seeker head could detect about 100 miles away. And we found the IR Falcons could track the B58, too. At least the IR WESM (Weapons System Evaluator Missile) brought back tapes showing the missile seeker head was locked on and tracking - during a frontal attack. Now, A B70 at M3.0 and +75000 would be like a giant IR beacon with a radar signature like the Vertical Assembly Building, all screaming 'Shoot Me'. The only problem with high-speed IR missiles over long ranges is that the window in the front of the seeker head gets hot enough to blind the warhead. The AIM-47 Falcon had something like a hundred mile range and flew at Mach 6. It had IR terminal guidance. Today's THAAD uses IR also (several others do but they use kill vehicles that are protected before the leave the atmosphere). HEDI also used an IR terminal guidance. Think of HEDI as a hit-to-kill Sprint missile. I don't know if they ever did get the IR seeker to work though. ISTR it was cooled by nitrogen gas flowing over the outside of the seeker and used a synthetic sapphire window. Yeah, you have to do some serious redesign to make IR a good high-speed targeting method. It's just easier to do it the other way around for the sort of target we're looking at - superfast, very high. The AIM-47 never really worked that well, though they used some of the lessons learned to make the AIM-54 Phoenix... without the IR. -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly.  |
			#28
On Sat, 20 Dec 2003 21:23:42 GMT, Chad Irby  wrote:
	In article , Scott Ferrin wrote: On Fri, 19 Dec 2003 05:07:37 GMT, Chad Irby wrote: In article , (WaltBJ) wrote: The B70 was doomed once its IR signature was analyzed. Even the B58 at M2.0 had an IR signature the 102's poor old LN2 cooled seeker head could detect about 100 miles away. And we found the IR Falcons could track the B58, too. At least the IR WESM (Weapons System Evaluator Missile) brought back tapes showing the missile seeker head was locked on and tracking - during a frontal attack. Now, A B70 at M3.0 and +75000 would be like a giant IR beacon with a radar signature like the Vertical Assembly Building, all screaming 'Shoot Me'. The only problem with high-speed IR missiles over long ranges is that the window in the front of the seeker head gets hot enough to blind the warhead. The AIM-47 Falcon had something like a hundred mile range and flew at Mach 6. It had IR terminal guidance. Today's THAAD uses IR also (several others do but they use kill vehicles that are protected before the leave the atmosphere). HEDI also used an IR terminal guidance. Think of HEDI as a hit-to-kill Sprint missile. I don't know if they ever did get the IR seeker to work though. ISTR it was cooled by nitrogen gas flowing over the outside of the seeker and used a synthetic sapphire window. Yeah, you have to do some serious redesign to make IR a good high-speed targeting method. It's just easier to do it the other way around for the sort of target we're looking at - superfast, very high. The AIM-47 never really worked that well, You might want to read up on the test shots. Even today they are some of the most impressive out there and they were like six for seven on hits and some of them were direct hits. Not to mention all of them were shooting down :-) with one of them smacking a target at 1500 feet from something lik 75 to 80,000 ft.  |
			#29
On Sat, 20 Dec 2003 15:19:54 -0600, BOB URZ
	wrote: Scott Ferrin wrote: You could make a case for a Sam being able to knock out any airplane. So why build any at all? Assuming B70's were built and upgraded umpteen times by now, what do you think the results would be with a re-engine of the six pack with a modern supercruise engine such as a F119? Bob Actually I'd be surprised if the F119 powered one wasn't *slower*. The J93 was designed for Mach 3 and high altitudes. The F119 is not. I realize that airflow and inlet geometry are critical for a high mach plane, but what would be different in the guts of the engine? Did the XB-70 burn a non standard fuel like the SR71? It didn't use special fuel (although they wanted to use a fuel with boron added at one point). I *think* part of the reason for the differences would be related to the compression ratio of the engines and that they were straight turbojets rather than turbofans. The XB-70, Blackbirds, and Mig-25 all used low pressure engines I *think* because at high speed they compressed the air so much to get something to work with that by the time it got to the engines they couldn't take the temperature of compressing a ton more. ISTR the J93's compression ratio being around 9 to 1 whereas something like the F100-129 is up around 32-1 or 36-1. Then again they though the could get the Crusader III up to 2.9 with a J75 so who knows. All of this is just my opinion from what I've read over the years so hopefully someone will weigh in who knows a lot about it.  |
			#30
"BOB URZ"  wrote in message
	... Scott Ferrin wrote: Assuming B70's were built and upgraded umpteen times by now, what do you think the results would be with a re-engine of the six pack with a modern supercruise engine such as a F119? Bob Actually I'd be surprised if the F119 powered one wasn't *slower*. The J93 was designed for Mach 3 and high altitudes. The F119 is not. I realize that airflow and inlet geometry are critical for a high mach plane, but what would be different in the guts of the engine? Did the XB-70 burn a non standard fuel like the SR71? Hey, it's Xmas. Mebbe I can make another mistake. For a supersonic aircraft, the purpose of the inlet geometry is to reduce the supersonic airflow at atmospheric pressure to subsonic airflow at super-atmospheric pressure. ;-) This means there's more oxygen to burn more fuel, thus getting more power. It also runs the engine hotter. The faster the supersonic aircraft goes, the hotter the engine can run. This raises the following critical question: how long an engine life do you want? I understand the Mig-31 Foxhound is _capable_ of astonishingly high speeds, as it has demonstrated on at least one occasion in the mideast. It generally doesn't, because an immediate engine overhaul/replacement is then needed. The F-119 engined F-22 has fixed inlets and is not especially fast. The engine, therefore, does _not_ have to be made of the *very* expensive highest-temperature alloys. My question is, how long would the F-119 last in a mach3 aircraft like the B-70?  |
