New Iraqi Airborne Strike Capability Spotted
Old October 21st 08, 03:00 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Mark Borgerson[_2_]
Default New Iraqi Airborne Strike Capability Spotted
In article 9870b6e3-029a-4701-9405-6919ed5d2cd0
@s1g2000prg.googlegroups.com, says...
On Oct 20, 9:59*pm, Mark Borgerson wrote:
says...
On Mon, 20 Oct 2008 13:59:09 -0700 (PDT), Jack Linthicum
On Oct 20, 4:50*pm, Peter Skelton wrote:
On Mon, 20 Oct 2008 13:42:34 -0700 (PDT), BlackBeard
Thanks Jack and Dumpst. *That link worked. *I don't believe it can
carry 12 passengers with all that equipment onboard. *I worked on
several projects where we loaded EO/IR sensors, trackers, and
targeting equipment onboard similar platforms we were using as test
beds. *Not much room left after all that gets shoehorned in.
re. OV-10. *I have a friend that was a USN test jumper who jumped
several times from the Bronco. *He claims they'd sit on the deck, nuts-
to-butts facing aft. *The Bronco would go into a steep climb and
they'd all slide out the back. *Crazy...
If the maximum payload load is 3500 lb as Cessna says, 12 kitted
soldiers are not going to fit.
Peter Skelton
specs for the Grand Caravan Super Cargomaster, listed at 14 passengers
plus two crew. Something like 3700-3800 pounds of cargo/people
Weights:
Empty Weight
1,746kg
Maximum Take-Off Weight
3,629kg
Maximum Load
1,900kg
Fuel Capacity
1,267l
Ramp Weight (Grand Caravan, Super Cargomaster)
3,985kg
http://www.aerospace-technology.com/...van/specs.html
Interesting. The Cessna website gives the maximum useful load
number I gave above. The Brochure downloadable from the site
gives 1862 kg. It also shows that, for a range of 100 nm, the
maximum payload, exclusive of 170 lb pilot and 45 min fuel
reserve is 1588 kg. to get 300 nm it's down to 1361 kg.
http://www.cessna.com/MungoBlobs/746...n_Brochure.pdf
12 kitted soldiers is too much weight.
The MC-5 and MP-360 canopies used by the Marine Corps
Force Recon troops can easily handle 400 pounds. *They
have been tested at weights up to 700 pounds. *I don't
think they regularly jump anywhere near that weight, but
400 pounds divided between the Marine and his separately-
suspended duffel is probably not uncommon.
http://atairaerospace.com/onyx/ul/
(been there, wrote the software, but DIDN'T jump out
of the airplane----I'm a 62-year old ex-squid, after
all!)
Mark Borgerson
Test jump site looks like Marana...
The test site with visible cactus, known as "Area 52", is about 15
miles East of Eloy, Arizona. The dry lake bed is Red Lake, about
30 miles North of Kingman, Arizona.
Mark Borgerson
  #32
Old October 21st 08, 08:03 PM posted to rec.aviation.military,rec.aviation.military.naval
Ben Jeffrey
"tankfixer" wrote in message
In article , says...
Some Marine special ops (Recon ) guys told us they could put a platoon
in there and parachute out the back. How the heck they did that, we
never figured out.
In the back of an OV-10 ?
Actually, Tinkerbell, there was a version that had the space to do
exactly
that. Not a platoon but a few troops. It was a leftover from the A1E
specs.
Did you note below I specified around a three man team ?
Very unlikely.
Actually, it was never done operationally that I know of but the
capability
was always there.
Maybe a three man team..
You should see a doctor for that knee jerk problem of your s Daryl.
Meddle ye not in the Affairs of Dragons, for Thou art Crunchy and taste
I was a member of 3rd Recon BN back in the late 70's, although I was
parachute qualified, I was in a non-jumping staff position. We did insert 4
man teams via OV-10. They set facing rear like peas in a pod - the aircraft
typically would fly knap of earth and pull up near vertical over DZ. The #1
jumper would let go and all 4 would exit the aircraft. This was done both
in daylight and at night.
Ben Jeffrey
  #33
Old October 21st 08, 08:10 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
BlackBeard
says...
Peter Skelton
Weights:
Empty Weight
1,746kg
3,629kg
Maximum Load
1,900kg
Fuel Capacity
1,267l
3,985kg
all!)
Mark Borgerson
The test site with visible cactus, *known as "Area 52", *is about 15
miles East of Eloy, Arizona. * The dry lake bed is Red Lake, about
Mark Borgerson
Thanks, I knew it had to be Az. but it didn't look like Yuma which was
my first thought. I didn't know about Area 52. Who runs it?
BB
I guess everybody has some mountain to climb in their life.
It's just fate whether you live in Kansas or Tibet.
  #34
Old October 21st 08, 08:52 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jack Linthicum
says...
beds. *Not much room left after all that gets shoehorned in..
Peter Skelton
Weights:
Empty Weight
1,746kg
3,629kg
Maximum Load
1,900kg
Fuel Capacity
1,267l
3,985kg
all!)
Mark Borgerson
Mark Borgerson
my first thought. *I didn't know about Area 52. *Who runs it?
BB
http://www.lasvegasnow.com/Global/story.asp?S=7340352
  #35
Old October 21st 08, 09:03 PM posted to rec.aviation.military,rec.aviation.military.naval
tankfixer
says...
says...
never figured out.
exactly
specs.
Very unlikely.
capability
was always there.
Thanks.
Did't think it would be much more than three or four in that fuselage.
Must be cramped too
Goode with Ketchup.
  #36
Old October 21st 08, 09:52 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Mark Borgerson[_2_]
In article 97fa8971-07c4-4fc9-8394-926cc5f518a3
@g17g2000prg.googlegroups.com, says...
says...
Peter Skelton
Weights:
Empty Weight
1,746kg
3,629kg
Maximum Load
1,900kg
Fuel Capacity
1,267l
3,985kg
all!)
Mark Borgerson
Mark Borgerson
Area 52 is the local name for a few square miles of leased grazing
land East of Eloy. The owner of Skydive Arizona has negotiated
limited testing rights there. We do a lot of testing with them
because they have Short Skyvans----which have back ramps and can
handle up to about 4000 pounds per flight.
http://skydiveaz.com/_facilities_dat..._aircraft.html
Skydive Arizona does a lot of military training, particularly now
that they have a vertical wind tunnel. Walking into the bar
there can be quite an experience---you can run into long-haired semi-
hippie free-fall junkies exchanging stories with German special
forces soldiers. One time we arrived for a drop at dawn---when it's
only 70 degrees---and saw a blond guy in tight shorts with an all-over
tan jogging down the road dragging a tire behind.
The van driver turned to me and said "It looks like the Germans
are here."
I can see the attraction for the military---you can probably get
10 troops and gear to 12,000 feet for under $500. You can't
get a C-130 off the taxiway at Yuma for that. Skydive Arizona
also has spare aircraft. I've had whole days of drops canceled
at YPG when the Air Farce broke their airplane. Granted, when
things work out, the AF will take you to 17,500 feet, while
Skydive tops out at about 12K.
Mark Borgerson
  #37
Old October 21st 08, 10:42 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
BlackBeard
On Oct 21, 12:52*pm, Jack Linthicum
says...
Peter Skelton
Weights:
Empty Weight
1,746kg
3,629kg
Maximum Load
1,900kg
Fuel Capacity
1,267l
3,985kg
all!)
Mark Borgerson
Mark Borgerson
BB
Thanks Jack, I've been to Tonopah more than once. I was referring to
the site Mark mentioned in Az.
BB
  #38
Old October 22nd 08, 12:26 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jack Linthicum
says...
Peter Skelton
Weights:
Empty Weight
1,746kg
3,629kg
Maximum Load
1,900kg
Fuel Capacity
1,267l
3,985kg
http://www.cessna.com/MungoBlobs/746..._Brochure..pdf
all!)
Mark Borgerson
Mark Borgerson
BB
Thanks Jack, I've been to Tonopah more than once. *I was referring to
BB
I used to have a cite for the location of all of the "areas". As I
understand it Area 51 is now partially in Tooele Proving Ground.
  #39
Old October 22nd 08, 07:22 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Mark Borgerson[_2_]
In article ab5f457c-92f8-4016-9d19-ef56508e44f0@
79g2000hsk.googlegroups.com, says...
says...
Peter Skelton
Weights:
Empty Weight
1,746kg
3,629kg
Maximum Load
1,900kg
Fuel Capacity
1,267l
3,985kg
http://www.aerospace-technology.com/...an/specs..html
all!)
Mark Borgerson
Mark Borgerson
BB
BB
I remember---but can't find---a reference to some black aircraft
programs moving to a site in Utah. In any case, the area 52 to
which I was referring is very much a local nickname. On the
Skydive Arizona web site they call it their own Area 51.
http://skydiveaz.com/filmoffice.html
Mark Borgerson
  #40
Old October 22nd 08, 04:55 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
frank
says...
Peter Skelton
Weights:
Empty Weight
1,746kg
3,629kg
Maximum Load
1,900kg
Fuel Capacity
1,267l
3,985kg
all!)
Mark Borgerson
Mark Borgerson
BB
BB
programs moving to a site in Utah. *In any case, the area 52 to
which I was referring is very much a local nickname. *On the
Mark Borgerson
I'd heard Area 12 as the new place to be.
Part of the problem is its not just getting the airframe there (and if
you're lucky its something you can load into a C-5 under a tarp) but
all the support. You want telemetry, maintenance, security, it adds up
fast. Janitors, toilet attendants.
Though with the way technology advances, it makes as much sense to
just start from scratch every decade. We were using an Atari to put
flight test data up on the monitor. Started as a 'proof of concept'.
Of course it worked, so nobody wanted to change it.
Utah had test and training range (UTTR). I think Edwards had better TM
and other data support. At least at the time, they were a step child.
Though they did have better camera setups. Tonopah had best stuff for
nuclear drops. Better operators. Probably better angles around drop
site.
Huge ****ing contest late 80s, Edwards wanted to get part of the
action. Just couldn't follow release and keep cameras trained on the
items.
Eglin had their own specialties, mainly weapons as opposed to
releases, all the aircraft specific tests.
Uncle Sam sure does have the real estate tied up to move though....
Flying Car Spotted at TIW C J Campbell[_1_] Piloting 9 May 30th 07 03:30 PM
APG-65/66/68/70 simultaneous track/attack capability Bjørnar Bolsøy Military Aviation 0 November 9th 03 12:15 AM
Question on airplane's IFR capability Slav Inger Instrument Flight Rules 10 July 12th 03 03:48 PM
New RAAF Air-To-Air Refuelling Capability Errol Cavit Military Aviation 11 July 2nd 03 06:43 AM
